Question about OKI C5200n Laser Printer
Oki c5200 "Fatal Error 106" - OKI C5200n Laser Printer
  • Angie Castor May 15, 2008
    Service Call 106: Fatal Error
    Please Help
  • Anonymous Mar 25, 2014
    fatal error 984 su oki c 801
  • OKI Master
  • 1,113 Answers
From your service manual....main board issue
oki c5200
Posted on Jan 16, 2008
2 Suggested Answers
  • 9 Answers
SOURCE: fatal error 122 on a oki c5200 printer
YOUR DRIVER CD IS CURREPTED.ANOTHER DRIVER CD USE.
Posted on Jun 23, 2009
B430dn zeigt den Fehler: 106 Fatal Error 3819, was heiß das?
Error code 106 is Engine Control Error. Try replacing the engine control pcb.
Oct 09, 2014 | Oki Electric Industry B430d Laser Printer
My OKI printer is giving me a message which reads, "Service Call 106: Fatal Error".
YYYY
106: FATAL ERROR
An error has
occurred which
requires service.
YYYY = the general
cause. 106 = error
number.
Try turning off the
printer then turning it
back on. If this does
not remedy the
problem, write down
the message including
the error number
“106,” then call your
authorized Oki Data
Service Dealer for
service.
Note: If you see a
series of octets
containing letters and
numbers scrolling
across the display, be
sure to write these
down also and report
them to the Service
Fuser error. Replace fuser or if no-go, Main board.
Aug 26, 2009 | Office Equipment & Supplies
Fatal error 122 on a oki c5200 printer
Jun 23, 2009 | OKI C5200n Laser Printer
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Have OKI c5200 Printer Message window reads Service Call 030: Fatal error Mac Mini OSX system What do I do? Prior to Message  Black Ink cartride was low and replaced cartridge after message appeared
I had the same error with an Oki C9600N. Called OKI, and was told one of two things has apparently gone bad: a DIMM (in slot 1) or the controller board. I removed the RAM, cleaned the contacts, blew out the slots (w/canned air), and reseated the RAM. Printer is back up and running. Hope this helps someone.
Feb 02, 2009 | Office Equipment & Supplies
Fatal error 002
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
Take the printer off the network. (Remove the network cable) Then enter the menu and select network menu. You want to change the settings as described below:
Change the Hublink Setting to "100 base tx full"
Change the FTP Setting to "Disable"
Once done and machine says online, shut it off, reattach the network cable and restart the printer.
You may also want to change the printer's IP address.
If this does not help, or you cannot get past the 002 fatal error then the machine will require service.
Aug 08, 2008 | OKI C5200n Laser Printer
OKI C5500 Fatal Error 177
From OKI error log:
Lower heater temp state - Low
backup roller thermistor indicates low temp
seek service if turning off/on printer does not solve problem
Apr 15, 2008 | OKI C5500n Printer
Fatal Error
Did you try cleaning the led heads
Apr 02, 2008 | OKI C9600hdn Led Printer
C5200 printer
177 - Replace fuser
Dec 12, 2007 | OKI C5200n Laser Printer
OKI C5200n Laser Printer Logo
2,308 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
