Question about Creative Labs ZEN V Plus MP3 Player
Forgot password on the restrict volume
Ok...my sister did sumthin on my zen v...she set the password on the restrict volume but then she forgot. i read the manual and it says that i should turn my mp3 off ,open it then clean my battery??well..im scared to open mine and im not very gud fixing things..is there any other way to solve my problem?please help me...im begging..please!tenx..
I have solution !!! You must turn up player!!!
then TURN ON WHILE HOPLDING PLAY BUTTON !!!!!!!
Then a screen goes on !!!!
You must choose CLEAN UP THEN REBOOT !!!
THEN IF IT DONT WORKED!!
THEN YOU NEED TO CHOOSE CLEAN UP THEN FORMAT THEN REBOOT !!!!
THATS ALL
BY DABDAB10
Posted on Dec 03, 2008
  • kiritv Aug 25, 2010
    so simple! Many thanks
  • Kieran Oneill
    Kieran Oneill Apr 10, 2017
    the clean up worked instantly took less than a minit to do it all and reboot with out restriction makes like 80% difference to sound thanks so much saved me binning it and crying :D
I had the same problem, and i solved it by reloading the firmware. u do it like this:
  • Press and hold the Play button while powering on your player.
  • When the player displays the Creative logo, release the Play button
  • Select Reload OS/ Firmware. U will need to download the firmware from creative's download section so u can put it back into the Zen.
    Posted on Jan 17, 2008
    • xhanewek09
      xhanewek09 Oct 08, 2012
      how about in zen neeon 2? its the same solution?
    Thanks soo much solution 2
    Posted on Jun 01, 2010
    How to off restrict volume
    Hi Cherry - that's not too hard.
    Restricting volume (password protected) is done through Creative Media Lite software.
    How to use Creative Media Lite
    After protecting the Volume Restriction settings with a password, the same password is required for subsequent changes.
    If you forget your password, reinstall your ZEN Neeon 2 firmware. You can download it from Creative Worldwide Support ZEN Neeon 2
    Jan 21, 2014 | Creative Labs ZEN Neeon 2 MP3 Player
    I forgot my password too but i don't want to reverse it i want to take it off!
    * Turn the volume down to 0
    * Change to a blocked channel (where it asks for V-Chip password)
    * On the TV (not from the remote) hold the volume down button
    * (While holding volume on TV) hold the '0' key on the remote for between 2-10 seconds...
    * The screen should unlock, and you should save no V-Chip restrictions.
    You can now use your manual to find out how to set the restrictions you want."
    Mar 23, 2011 | Orion1934 19" TV
    How to break volume restriction password ZEN XFI 2 ?
    Boot the ZVM into Recovery Mode and select Cleanup from the menu. This will reset any user defined settings, including the passwords.
    To boot the player into Recovery Mode, do the following:
    1. Insert a paperclip, earring stud, or other slender, unbreakable item into the reset hole located at the bottom of the player to press the reset button inside. You should feel a "click" when you've pressed the button. Press and hold the reset button.
    2. While holding the reset button, slide the power switch toward the power icon and hold it there. Let go of the reset button.
    3. When the Zen bootscreen appears, release the power switch.
    Mar 13, 2011 | Creative Labs ZEN V Plus MP3 Player
    Forgot password to remove restrict volume setting
    Hi you will have to format your player and reinstall the firmware so the player will be like it was from the factory. That will wipe on the password you set and you can just reset it to what you want.
    If you need any more help, parts or your player repaired you can go to my repair service web page and e-mial me, call me or contact me threw my Ebay user name at firehouse7777.weebly.com Thanks
    Dec 23, 2010 | Creative Labs ZEN Vision:M Digital Media...
    How to reset code for powering off restrict volume on my creative zen neeon 2
    Here is a quicker solution if you have already chosen Europe?
    Well, thanks to my investigations I have found there is a solution. Pressing reset will not work and installing new f/w is a pain.
    Instead, open your S9 system folder, and simply delete the "PARAM" file. Power off. Power up. (There is no need to change firmware at all).
    You are back at the original screen. 1. Choose your language. 2. Next DO NOT CHOOSE THE EUROPE setting. 3. Third, choose your radio setting - any will do.
    Jul 19, 2009 | Creative Labs ZEN V Plus MP3 Player
    Volume too low on zen
    Try going to System>Audio Settings>Restrict Volume on your ZEN. This is a password protected feature for parental controls i guess... If this doesn't work, get a hearing aid : )
    Jan 28, 2009 | Creative Labs Zen Digital Media Player
    Creative Zen V Plus volume control unresponsive
    someone probably put a password in the volume control thingy
    to change just go to settins and then where it says volume
    if you cant go in it might be somone changed the password
    Aug 12, 2008 | Creative Labs ZEN V Plus MP3 Player
    Forgot password
    push and hold the power button and at the same time prss the play button....a system recovery window eill pop up and select the first optiom "clean up" then turn it off and on again and its done!
    :D
    Jan 10, 2008 | Creative Labs ZEN V Plus MP3 Player
    Creative Vplus hangs while charging
    Zen V is dead
    "If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
    May 29, 2007 | Creative Labs ZEN V Plus MP3 Player
    Creative Labs ZEN V Plus MP3 Player Logo
    879 people viewed this question
    Top Creative Labs Audio Players & Recorders Experts
    Carlos L. Burgos
    Carlos L. Burgos
    Mohamed Ismail
    Mohamed Ismail
    Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
