The radio code is indicated on many peugeot models on a small white sticker inside the glove box. it will be labeled "Anti-theft radio code". Enter this code using the preset radio buttons of your peugeot radio.
Peugeot car radios will normally contain a 14 digit serial number which can be found either printed on a label or engraved on the side of the unit. These serials are ...
If you have lost your Peugeot Radio Security Code then you are only a few clicks away from obtaining your code number via our Automated Servers. Affectionately ..
and acura -peugeot?
is this an engine swap,
no matter, if you lost the radio code , only the dealer can helpyou.
call them and ask ,its like #1 reason for phone bells.
if you go to honda.com , its all there , under help and service, read it.
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio. The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Peugeot servicecentre and get them to enter this code for you.
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a label somewhere on the metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
your radio alsohas a BARCODE SERIAL
+on a label somewhere on the metal
casing.
If not then it will only be available fromyour Main Dealer or a Radio Decoding Service or
memory chip (EEPROM) inside your radio
youll probably have to contact peugeot directly with vin# and theyll be able to verify a code for you , but expect to give other info to i.d. you as the owner of said vehicle and equiptment
