Question about Cyberhome CH-LDV 707B Portable DVD Player
High Def disks
Is there a way to play HD disks on my 707B? It doesn't read them.
    Sergeant:
  • 280 Answers
No! This player is not equipped with the blue laser and format to read HD. Currently there are two format es for HD. Blu- Ray and HD/DVD. Only these are capable of reading HD disk. Blu-Ray is going to be the industry standard
Posted on Feb 22, 2008
Picture problem on panasonic Vierra plasma tv
It looks like you are saying standard definition pictures do not cover the screen like HD pictures do. Standard def is formatted 4:3 and high def is 16:9. They are not the same so your high def screen is made to display the not as tall but wider high def picture. In order to fill the screen with the taller and not as wide 4:3 aspect ratio std def picture you must tell the TV to stretch the picture or otherwise fill the screen.The TV will have controls you can exercise for this purpose and you can set it up to always show std def in a particular manner. The alternative, if you want the standard Def picture to look true to form, is to view standard def in Letter Box form. It's appearance will then include black panels on the sides of the picture. So the problem is not with the TV but in accepting older format pictures playing on newer format displays (TVs.)
Mar 11, 2014 | Televison & Video
Picture problem on Panasonic Plasma tv
Mar 11, 2014 | Audio Players & Recorders
I have an Apex digital 32" LCD TV Model LD 3249 and Serial #36056009262 Is this a high definition TV
Yes. 720p High-Def capable.
Remember you have to have a High-Def signal source to actually view High-Definition video. This means local broadcast TV in HD or digital cable TV with HD service and a HD channel or satellite or a Bluray Disc.
Mar 15, 2011 | Televison & Video
Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Toshiba DVD/HD Mod:#sd-H802A ''Cannot read high def dvd movies...
Hi there.
If it's just a case of you not being able to watch HD films, but you can watch normal dvd's, then it sounds like you need to reinstall your High Definition video codec.
What software are you using for your dvd playback?
Tim
Apr 22, 2009 | Computers & Internet
What does HDMI mean?
Only If you Play high def or blue ray disks on the player///regular disks will look even better then before but not quite as good as a high def or blue-ray disk!
I hope this fixes ya up!
(please use the rateings so we can keep this site FREE!)
Dec 14, 2008 | Hitachi 57F500 57" Rear Projection...
Dvd player, hd dvd movies
If this is just a regular DVD player, then no. You need an HD DVD player to play HD DVD discs. Now the HD DVD players should play regular DVD discs.
Feb 12, 2008 | LG DR787T DVD Recorder
Hi-def dvd
This is not a High Definition DVD player, it does upscale a regular DVD to HD resolution, but that's just an electronic trick.
Also, Toshiba has abandoned the HD-DVD standard (did you find the discs on sale?), you'd need to find a BluRay player (like the Playstation 3) to play high definition DVD's.
Dec 05, 2007 | Samsung HT-Q100 System
Hd ready?
On any High Def TV, the reciever you need for this set, which does not have a HD receiver in it, is half the equation. Most HD channels have some HD content mixed with SD content on the same channel. SD content on HD signal from cable or satellite tends to be slightly blocky due to the native signal resolution and the resolution of HD (1080i/p or 720i/p).
Apr 30, 2007 | Akai PTH5498 54" Rear Projection...
Cyberhome CH-LDV 707B Portable DVD Player Logo
74 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
