Question about Gateway M275 Tablet PC
Battery Power problem
The system works fine while poweered by the AC cord but it will not power up from the battery. I replaced the battery with a new and charged one and it still has no power from the battery
  • mmyles2001 May 10, 2009
    I have a Gateway m275, new battery. It will run on the battery for 10 to 15 min tops, then shuts down. Power monitor on screen shows 75% or more power in the battery, but the red battery light starts blinking, and it shuts down without any warning.
    I tried reconfiguring the a battery setting in the bios, that didn't help.
Change power batter.
Posted on Jan 24, 2008
My tablet wont charge unless turned on but battery is so low it wont turn on so cant charge it up.heeeeeelllllpppp
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
May 15, 2012 | Archos 101 Internet Tablet 16GB 10.1"...
Kindle fire has red battery showing. I have charged it but it wont work
It may be the power cord but it is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it started flashing a red battery symbol this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
May 15, 2012 | Amazon Kindle Fire
My laptop is not turning on. I recently purchased a new battery and ac plug. Everything worked perfectly for about two weeks. It worked fine in the morning but when I tried to turn it on for lunch...
1. Check ur Power Adapter, whether ur laptop get power or not.
2. if power cable and adapter ok. check system RAM
but u said it does not recognize power, So u have problem with either Power card or power plug inside laptop. and u said it deosn not recognize battery also, in this case check RAM, CPU and MB.
DO VOTE
Sep 24, 2010 | Compaq 2710p Tablet PC
My toshiba r10 laptop wont turn on the green power light to the front is on but the yellow battery light only comes onn when i plug in the power cord to it and it only stays about 2 seconds
Ok here's what you will do
1) Unplug the notebook from the ac adapter (charger power cord)
2) Take off the battery pack on the notebook
3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
4) After 15 seconds, let go of the power button
5) Now plug in the AC ADAPTER (OR CHARGER POWER CORD) ONLY (DO NOT PUT BACK THE BATTERY PACK)
6) Now press the power button once.
7) If the unit boots, the unit suffered a slight surge
8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
I hope this helps and let me know how it goes afterwards
May 03, 2010 | Tablets & eReaders
HP 2710P will not power on!
Try power draining your computer first. remove battery and ac adapter, then press and hold power button for 15-20 sec. Expect no response since there is no power source. After that, try if pc will now turn on. If it still wont, possibly it will be needing a motherboard replacement.
Apr 26, 2010 | Compaq 2710p Tablet PC - Intel Centrino...
After runnig on battery power it powers off
Obviously its a battery problem
Usually happens on old batteries.
A new replacement will fix this problem.
Usually a healthy baterry should last between 1 to 2 hours...some models even give you 4 hours working time.
Don't forget to rate this answer if it helps.
Dec 12, 2009 | Electrovaya Scribbler 2000 (SC 2000)...
Toshiba without battery
1. If the batteries are dead then there's no way that you can charge them again. You're better off purchasing a new one. You can purchase one online by visiting the ToshibaDirect website or by calling them on 1-800-316-09202.
2. Yes, you can use the power cords to run the computer. Just plug them in using the power cords even with the batteries removed and it should work fine.
3. Yes you can but you might experience some current fluctuations. This is negligible on a CMOS battery though.
Aug 14, 2008 | Toshiba Portege R100 Tablet PC
Fujitsu Lifebook T Series wont power on at all
1) Remove battery and power cord  2) press power button several times  3) Whack laptop on the bottom center 2 or 3 good times with the palm of your hand  4) Replace battery and plug  5) Power it up (may have to hold the power button several seconds)
Aug 06, 2008 | Fujitsu LifeBook T3010D Tablet PC
Battery problems Tc 1100
When the Batt is inserted and you are on AC power do you have a lit charge light? It's the one in the center of the three at the lower right when you are in landscape mode.
If your batt is at "end of mission" (**** up) then it's ability to hold and take a charge may be very limited. Calibrating the batt might help. You will need the toaster style charger.
If this is the issue, then the charge light may only stay on for a few seconds at a time when you first attach AC power, so be watching.
I could recommend a new batt (e-bay) if thats your only trouble. Nothing lasts forever. I'm in Missouri and will calibrate your batt if you want to mark it and ship it. Let me know.
B
May 05, 2008 | Compaq tc1100 Tablet PC
Travelmate will not boot up
Not booting
Laptops:
1. Unplug Ac power cord and take out the battery
2. Press and hold power buton for 25 secs (yes without cord and battery)
Desktops:
Feb 08, 2007 | Acer TravelMate C112TCi-SP2 Tablet PC
Gateway M275 Tablet PC Logo
286 people viewed this question
Top Gateway Tablets & eReaders Experts
Ricky Ostrom
Ricky Ostrom
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
