Question about Refrigerators
Frigidaire side by side refrigerator, door ice dispenser switch stuck on
The above refrigerator has in-the-door water and ice dispenser. During one episode of getting ice, the motor driving the auger kept running and won't stop running even when the ice dispenser paddle in the door returns to its full out position. Opening the door of course turns the motor off. I had to pull the whole ice maker out of the freezer to shut off the motor. How do I remove the in-the-door dispenser to examine/test the switch?
  • 3 more comments
  • 4mike Jan 27, 2008
    Ice dispensor switch is bad, how do I replace it.
    thanks
    Mike
  • dbeaver2 Jul 07, 2008
    The ice auger motor keeps running even with the ice paddle is shut off. It stops, I assume when it overheats, then comes back on when it cools off.
    It will not allow me to switch over to cubes so it just keeps running and stopping continually. I tried cleaning everything and checking to see if there was something lodged in the entire area and found nothing.
  • MmmDee Jul 18, 2008
    Ha, had forgotten I left this question. Update: I removed the ice dispenser, as I recall one screw keeps the ice macker attached to the back wall of the freezer and unplugged its big plug from the back of the ice maker and left the refrigerator turned off for 24 hours. Upon putting everything back, the ice maker worked as it should, so presumably, ice got somewhere where it wasn't supposed to, then melted away.
  • pakiser Feb 04, 2009
    I have the same problem. I took the ice maker apart and unplugged the connector from the control/power board. I've left it that way for a year now. I will try the defrosting trick and see if that solve the problem. Note that I have almost the same model, it is a PB2 instead of a PW.
  • Anonymous May 24, 2009
    Auger keeps running. open door and it stops. After running for a while it will stop but will start running again all by itself.
SOURCE: RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Posted on Oct 26, 2007
  • 212 Answers
SOURCE: I have a GE side-by-side stainless refrigerator,
your auger motor could be bad. first i would check the micro switch that the lever hits inside the dispenser housing.
Posted on Jun 24, 2009
SOURCE: GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Posted on Jul 24, 2009
  • 112 Answers
SOURCE: I have a stainless steel Frigidaire side-by-side
the front cover will come off. if you dont see any screws then it WILL unsnap. look for a slot on the top or bottom of the cover. good luck some of them can be nasty
Posted on Oct 29, 2009
  • 2006 Answers
SOURCE: I have a Jenn-Air refrigerator
Yes it could be either, BUT I would go back and make sure that everything you did to stop it the first time is undone. Is everything setted correctly? Is the switches in the right place?
Neither the solenoid or the microswitch could cause the problem you had before, so I would suspect something is not right with the ice maker itself.
Posted on Jun 16, 2011
Frigidaire GLRSF266J side by side makes ice, but dispenser won't work, what can I do?
The part that holds the switch in the dispenser door may have allowed the paddle to no longer contact the switch correctly. Look for a discolored wire connector under the hinge cover on the freezer door. If it looks all in order the water solenoid located where the water line attaches to the fridge may be bad.
Jun 28, 2015 | Frigidaire Refrigerators
Ice dispenser frigidaire
Hello Friend, thank you for allowing me to assist you!
From what you have described it sounds like the issue lies with the door switch, auger motor, or a faulty ice door flapper (the flapper that opens to allow ice to dispense). In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your Frigidaire refrigerator. Best! - Z
Sep 04, 2014 | Frigidaire Gallery Side By Side...
Frigidaire side by side FRS24ZSG. Door Dispenser doesn't work
click on the wiring diagram and look at the circuit which powers the dispenser...it looks like the safety switch would be a problem to all the functions you listed above..such as the light not working.. no ice... no water
i would look for power to that safety switch..and if its getting power.. then i would check continuity through that switch.
also another possibility maybe its the wiring harness that leads to the dispenser.
Oct 05, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Jun 02, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire Side by Side Gallery Model Refrigerator
yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire side by side model:FRS26HF6BW2
Check the trap door where the ice drops through, it might be stuck in the open position, solenoid that operates the door may be bad.
Jan 27, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker water dispenser is stuck in the on position
The problem is fixed. I think the drinking cup jarred the push bar activator, causing it to be stuck in the on position. After pushing this activator, it cleared the problem. Thanks for your follow up.
Jun 21, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
In door ice and water dispensing
sounds like the paddle is hanging up or the micro switch that the paddle actuates is sticking if you can see the micro switch spray some wd 40 on it open the door and work the paddle a few times
Feb 15, 2008 | Frigidaire FSC23F7D Side by Side...
Ice dispenser only dispenses crushed ice
Pull out your ice bin. In the back of the bin you will see a rod protruding from one side. That rod goes into an opening in the rear of the freezer. There is a solenoid behind that opening that raises and lowers the arm on the ice bin giving you crushed or cubed ice. Check to see if that solenoid is froze up or if your rod got stuck under it. If all check ok then replace that solenoid.
Nov 05, 2007 | Frigidaire FRS26KF5C Side by Side...
Refrigerators Logo
1,267 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
