Question about Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Even new remote won't work
When my old remote stopped working (yes, I changed the batteries) I bought a new remote (not a generic but an actual replacement), and it does not work either. How can I tell if it actually the remote(s) that don't work or if it's the sensor on the TV that isn't picking up the signal?
    Genius:
  • 1,003 Answers
when you purchased the identical remote did u ask the supplier if you have to program the new remote or was it preprogrammed at the factory I would start here first.
Posted on Jan 16, 2008
Why isn't remote working after battery replacement?
As long as the battery produces what the remote needs it should work. However the remote itself could be faulty. Or the remote sensor on your device could be faulty. Check that the old battery has not leaked and messed up the contacts. Plus the new battery is actually touching the contacts!
Feb 25, 2016 | Audio Players & Recorders
Logik remote control won't work
It sound that your remote control need serivce. In most cases, claning it will rectfy the problem. You can get more details about how to reapair,test or clean the remote control by entering this site "Electro-help". Search for it in Google.
May 02, 2012 | Televison & Video
My Maestro IR remote no longer works after 10 years
The infrared (IR) LED / remote may have stopped working. Since it emits IR light when used, you won't be able to actually see the light with the ***** eye. This makes it difficult, but not impossible to determine if the LED / remote is working or not. You can see if it works by pointing it a night time security camera - the type that has it's own built in IR LEDs to light up the area and does not need visible light to shine on the area (some video cameras can also "see" this light when playing back video taken of an active IR light source). Either record or have someone watch the display while pressing a button on the remote and aiming at the camera. You should be able to do this in broad daylight it will look like a flashlight shining into the camera.
If the LED in the remote is proved to be functioning, the IR receiver in the switch, or some other internal part of the switch may have failed. Since the receiver doesn't light up - there's no way to determine if this is the case without actually replacing the switch. It doesn't matter really, as there are no user replaceable parts in the switch - it either works, or it doesn't.
Ultimately, the best way to troubleshoot will be by replacing components with known good types. Use a battery that tests "good" on a tester, in a new or known to be good remote, used on a new or known to be good switch. You'd would deal with the situation by swapping only ONE component at a time. Once you change the device that allows to circuit to work, replace the new components with the old - except to last one; as this was likely the component that caused the failure.
Try taking the remote to a Home Depot, Lowe's or other similar store with a display of these switches. Do what you need to do to your remote to see if you can control any of the switches/ lights.
Apr 13, 2012 | Electrical Supplies
Logitech z906 remote stopped working
Sometimes the battery terminals become pitted and don't make good contact, get a Q-Tip and rubbing alcohol to make sure it is spotless. If there is no change! take it to a TV tech. to verify it is the remote, if yes he may be able to repair it.
Mar 24, 2012 | Logitech Z906 Speaker System
I was watching T.V. and when I went to change the channel, the remote control wouldn't respond. I changed the batteries (generic) & the new ones didn't make the remote work either. I hit the power...
You won't be able to see the light from remote's LED (Light Emitting Diode) because it is IR (Infra Red) which is invisible to the human eye.
Try re-entering the code for your tv to see if it works.
If that doesn't work, the remote might have just died. It happens.
Get yourself a new UNIVERSAL REMOTE for less than $20 and just program it for your tv.
Good luck and post back to let us know how it works out.
Jan 24, 2011 | Televison & Video
I have a Grundig GU22DVD TV/DVD combo and the remote has stopped working even with new batteries. We,ve just moved it to a new house and need to tune in the digital channels without the remote. Is this...
Take out the battery an hour,put in back in,have the same problems.The remote is dead.Try website like Remotes.com to buy an exact remote.Yes,u can use the manual control buttons on right side of the tv,but a little hard.
Sep 06, 2010 | Grundig GU19WDT 19 in. LCD TV
My remote for my akai pdp42z5ta stopped working
Stevenson
Yes, I can help you either fix the original or get you a brand new one. By the way, did you change the batteries. I know you did, but this procedure is the first step. If you change the batteries and the remote doesn't work, the problem can be inside the remote, specially if it happen to be dropped. Or the sensor in front the tv may be bad if does not respond to the remote. The best way to check the remote control is with infrared checker, an special equipment I have at the shop. I can ckeck it with that for you and fix it as well. Please e-mail me at Stevebuy31@hotmail.com
Dec 03, 2008 | Akai PDP4225M 42 in. Plasma Television
Toshiba TV Remote Control not working
i have bought universal remote controls and they do not work. what can i do? i have bought rca universal philips universal remote,
Nov 17, 2007 | Toshiba 36HFX71 36" TV
Remote sensor
Bad connects at sensor inside TV or bad sensor.......
Toshiba part # 23009490............T.
Sep 21, 2007 | Toshiba 36A60 36" TV
Emerson EWC27T3 27 in. TV/VCR/DVD Combo Logo
140 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
