My Toshiba Laptop computer will not recognize my mouse when it is plugged into the mouse port. Why not? hamouse.ve uninstalled and re-installed the drivers..no result..it appears to be there ,but not working.am not good an touch pad
-   my laptop tropix tt3 does noy recognise my mouse when it goes in hibernation or when it is switch off-   Guest
Aug 19, 2008
-   im on windows vista..i had this usb mouse conected..it worked fine..but one day i disconnected my mouse and the next time i pluged it it wudnt work..i tried conecction another mouse but still wouldnt work..please help-   franxis
Jun 12, 2008
-   everything fine then the wireless mouse stoped working batteries ok
-   jeepzandcatz
Try going to: Start, Control Panel, Mouse and under Devices select: Disable TouchPad/Stick when a USB pointing device is present
Was this helpful?
Yes
No
Solution #2
posted on Jul 06, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Well... where did you buy your computer? If you go to that store and tell them your problem the may be able to help you. Or you can call them. If its from circuit city you can go to:
1800-FIREDOG
Hope I helped :)
Popular Solutions for Microsoft Wireless - Optical -
my tropix laptop motherboard blacked out and can not display, yet when i switch on , the power light...
(More)
my tropix laptop motherboard blacked out and can not display, yet when i switch on , the power light lights, and the DVD rom runs, what can i do, and if the problem is on the motherboard, where can i repair it in Uganda, or how much does it cost. Gordon from Uganda
I need driver for my tropix web cam. The web cam is functional but not seen by the machine. what...
(More)
I need driver for my tropix web cam. The web cam is functional but not seen by the machine. what should I do?
On boot up computer stops and reports no mouse found, asks hit f1 to ignore or del to inter set up...
(More)
On boot up computer stops and reports no mouse found, asks hit f1 to ignore or del to inter set up keyboard and mouse both work ok but must hit f1 each boot up
