Question about RCA TruFlat 27F520T 27" TV
Sound how do i get my sound back on my tv... i left it on mute for a couple of hours and now there's no sound but the picture is still there
  • aqueerius Jan 18, 2008
    did that and nothing happened
  • 29 Answers
Try unpluging the power from the tv for a several seconds.
Posted on Jan 16, 2008
My TV show good picture but had no sound for 3days sound came back for a couple of hour than went silent no sound. What seen to be the problem?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sep 13, 2015 | Televison & Video
TV not turning on.
Thats usually caused by the small signal board. You can get replacement boards from www.tvrepairworld.com
May 26, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
TV has power, but picture or sound will not come on.
It sounds like something in the set has failed. These newer TV's have shut down circuits that won't let the set come on if there is a short or excessive voltage somewhere in the set. Most failures in TV's occur at the moment the set is turned on.
Jul 09, 2008 | RCA F36650 36" TV
New Blue CRT installed now TV won't stay on
sounds like the HV lead isnt sealed properly either at the CRT or the Splitter I would have him come back and recheck his connections
Jun 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture and no sound
simply unplugging the TV and turning it back on if started to work.
if it doesn't then the Trying a new lamp first is reccommended.
After all, you will need another lamp eventually.
Samsung Parts
http://www.samsungparts.com/
model HLM507W as two different lamp replacement part. the LAMP for my TV was BP960224A. the replacement lamp listed on the Samsung site is BP960224C which was replaced by BP960224J. the difference according to my supplier is that A part has a brown power coupling and the J part has a black power coupling. hope this helps someone in the future. The couplings are different and a black LAMP coupling will not fit a brown TV coupling.
Replacement is simple, getting the right bulb is tougher. Make sure the TV is unplugged and the lamp has cooled. Looking at the TV from the back there is a lamp cover on the lower right. Remove the single screw, remove the door. There are two screws holding the lamp in, loosen these. Then flip the black plastic handle up at the bottom of the lamp assembly and pull the lamp assembly out.
Note the brand of the buld and the color of the connector (black or brown) and then call to order your parts from Samsung's parts reseller
With set off...mute + 1 + 8 + 2 + power.
Arrow down to "Options" push enter.
Lamp reset and lamp hours should be in there.
Power off 2 minutes or until fan kicks off to exit.
BP96-00224C LAMP ASSY./ PHILLIPS 40''-50'' $199.99
Jan 28, 2008 | Samsung HLM507W 50" Rear Projection HDTV
Picture but no sound
have u tried to unplug it maybe an hour.then plug it again..this is basic reseting the unit.thanks ...hope this help..
Dec 31, 2007 | RCA TruFlat 27F520T 27" TV
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Clicking Noise, Jumpy Sound, No Picture
The SMPS (switch mode power supply) is a bit tricky in this unit. Failures in the SMPS can give false impressions of what's actually happening with regard to the symptoms. You'll need to ESR the caps in the SMPS first. C525 250v/10uf is a good place to start. It sounds like the B+ voltages are present by the noise you're describing and that would indicate that the regulator circuit is probably okay. Next I'd check things like the HOT (horizontal output transistor) for short. NOTE: If you don't have an ESR meter the job is nearly impossible. Electrolytic caps don't always show any outward signs of damage. Only by checking their equivelent series resistance are you able to determine if a lytic is the culprit.
May 26, 2007 | Apex Digital PF3230 32" TV
RCA TruFlat  27F520T 27" TV Logo
47 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
