Question about Hitachi 43GX01B 43" Rear Projection Television
No audio changed audio ic no cure
  • Hitachi Master
  • 8,617 Answers
Is This The Hitachi GX01B? You probaly have a capacitor or transistor not within tolerance in your audio circuit. If you would like a service manual and unlimited support for your set to help diagnose it. You can go to the following link they have the46GX01B which is the same chassis as the 43, for 10.99 and they offer free unlimited support with purchase of manual. then if you go back to the site and click on the contact us link and provide your email address they will email your manual to you instead of mailing it. They will also email instructions on how to enter into the free chat sessions. Heres the link. I am one of their support techs.
Posted on Jan 16, 2008
Audio output only out of one output
hello sir,
often this is sound IC fault, if one IC there change it and it will fix the other audio output, as the sound IC have two outputs and one of it doesn't output the audio,
if two sound IC's, it's a must one of it is faulty, you better change both for long run of the audio amplifier
good luck
Oct 18, 2015 | Car Audio & Video
Kenwood kr 5050 volume stuck on high cant change
These days the circuit of the volume control is controlled by an IC in modern amps. These can go faulty preventing adjustment of the sound by the volume control. The only cure is to find the IC and replace it. You can start in the area where the volume control is located. If it's not mounted direct on the PC board, follow the connections to the board. Hopefully the board might have writing on it to indicate the area where the faulty IC is.
Aug 04, 2015 | Kenwood Audio Players & Recorders
I have a 27" Toshiba television, I'm having problem with the sound. I've changed the sound output but nothing happen. Please help.
Jennifer Castillo
Here are some possible locations where to look to :
( Since I have no model for your TV or additional details which you have
a) switching IC ( these IC switches the TV to Audio Video In)
b) muting circuits ( there could be one )
c) Check the audio out coming from the Jungle IC (also unknown)
d) check the supply lines of the audio IC (could be +12V, typical)
e) Check the headphones out (if available)
If there is an audio Out, connect an external amp to test.
If audio is present , check again for solder joints to main amp.
Use these as a guide in troubleshooting :
Computer Speakers
Your input is the Jungle IC, search on line for datasheet about it.
same with your Switching IC and Audio IC.
On some audio IC, volume control is included on it.
Let us know what you find or needs further assistance.
Oct 02, 2012 | Toshiba Televison & Video
Whats wrong when my lenovo ideapad speakers start distorting every now and then when sounds are playing? How do i fix this problem or get it to stop?
Try turning down the volume, small speakers in general can't handle a lot, if you still have trouble, the speakers may need to be replaced or the audio output chip. Hook external speakers to see if that will cure it, if no change! replace the ic chip.
Apr 08, 2012 | Computers & Internet
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Sound but no picture.
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
I got a panasonic stereo for my birthday about 3 years ago. I had a party over the summer and we had the stereo sitting outside playing cds. Then all of a sudden the stereo shut off and then everytime i...
f61 is a protection code. it means theres is a fault with audio output ic, usually there is dc on one of the speaker output rails, replacing the audio output ic will usually cure this but check speakers and leads for shorts before reconnecting to the unit.
Thank You
Sep 07, 2010 | Audio Players & Recorders
Roland SPD 20 shows analog test error at power on.
I am having the same issue with a SPD-11 that ahd brought from Japan. Please let me know if you get a resolution for your issue.
Dec 25, 2009 | Yamaha RX-V659 Receiver
F61 error message
F61 IS THE ERROR CODE FOR A FAULT IN THE AMPLIFIER STAGE OF THE UNIT, if the power fan or supply is okay then THE MOST LIKELY CULPRIT IS THE AUDIO OUTPUT IC, WHICH IS A MULTI LEGGED DEVICE SCREWED TO A PIECE OF METAL USED TO COOL IT, IN PANASONICS ITS PREFIX WILL PROBABLY BE "RSN" BUT IT COULD BE "STK", MAKE A NOTE OF THE NUMBER AND SEARCH ON LINE, DONT FORGET TO CLEAN OFF THE OLD HEATSINK COMPOUND ON THE HEATSINK AND REPLACE WITH FRESH.f61 means theres is a fault with audio output ic, usually there is dc on one of the speaker output rails, replacing the audio output ic will usually cure this but check speakers and leads for shorts before reconnecting to the unit
Sep 28, 2009 | Panasonic Televison & Video
Sony TV KV-X2973E uk model: no sound in SCART or AV1, AV2.
Do you have its schematics or service manual? This kind of problem needs detailed schematic diagrams of related product. Let me know, are you Tech-Person or TV-Repairman?
Aug 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi - and thanks in advance - first time here - have Panasonic model CT-2769SW - audio is either happening (coming thru or mute) or not - inconsistent - any ideas ? Mike :)
Could possibly be a defective audio output IC. I would try re-soldering it first though as that often will cure an intermittant audio problem.
May 04, 2008 | Televison & Video
Hitachi 43GX01B 43" Rear Projection Television Logo
70 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
