Question about Averatec 6200 Notebook
My screen will not light up
I can see faintly that the pc is turning on but I can not see the screen. I connected another moniter to it to if the problem was more than the screen.
When I did that the moniter had an error message: The moniter is in save energy mode, activate from PC. What do I do?
  • ostad Apr 09, 2008
    i have the same problem and i ordered an inverter and replaced it but the problem is still there, cable checks ok too. does anyone know the input voltages to the inverter? or which component supplies the input to the inverter? thank you so much
  • Rick Beda Sep 16, 2008
    Same issue-screen changes shades of black on startup-but nothing can be accessed-any suggestions?
    Genius:
  • 1,003 Answers
Turn power off and back on your moinitor and laptop this should do the trick
Posted on Jan 16, 2008
Black screen / works on external moniter
When you turn your laptop to different angles can you see extremely faint graphics? Try shining a bright light at it an turn it at a 60 degree angle to your eyes. If you can see any graphics then your inverter board is bad. It it located just below the screen in front of the keyboard. The inverter itself is very inexpensive (about $12). Having someone install it shouldn't take more than 45 minutes. Let me know if this helps you.
Apr 25, 2010 | Toshiba Satellite A135-S4527 Notebook
When I hook up my moniter it does not work like other moniters.
ok sounds like you have a broken pin on your cable if you look in the end of the cable plug the part thet goes into the box but also check both ends if they are there
failing that take monitor to roof and heave ho away it goes
Jul 25, 2009 | Compaq P 1220 22" CRT Monitor
Moniter says no signal
You may need to replace the moniter cord or check the video card on the computer.
May 31, 2009 | Acer Aspire™ T180 PC Desktop
When i switch the moniter on i see faint lines running up my moniter ( very faint ) as if they are some kind of interference lines, my colleagues are using the same screen on the tables next to me but have...
Hi this shows your monitor has a interference by:
1) by screen refurbish frequency you may try to change this frequency from PC, go to screen setting go high level setting click monitor and change the frequency to 70(or other than 60) ,also you may try from your monitor.
2)stil trouble there, your monitor has a problem with power supply,
the capacity wave filter not very good condition. need to change 5V wave filter capacity (two),should be solved.
Dec 22, 2008 | HP L2208W Monitor
My Acer LCD AL1711 went off after seconds of turning on.
This monitor has "back lights" that are essentially like flourescent lights. These are high voltage lights and can easily fail. since you are getting some light initially, I would suspect a defective part that heats up a bit right away and then fails. I would try to replace the entire backlight board. This is the small board on the side (usually).
Dan
Mar 27, 2008 | Acer AL1711BM (Black) 17" LCD Monitor
Hi: My Acer LCD moniter has started its problem two weeks ago, when I turn it on the screen comes a seconds then went off but there is still faint screen you can see. the green botton light in...
have you try to use another monitor? when its working there's must be a problem to your LCD monitor, but if does not.. there must be a problem to your video card..
Mar 26, 2008 | Computers & Internet
Amilo pro, Fujitsu (siemens)
sounds like the LCD lamp burned out.
Nov 04, 2007 | Fujitsu V2000 (9052026) PC Notebook
Averatec 6200 Notebook Logo
63 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
