Question about Siemens 24 in. SE55A560 Built-in Dishwasher
Siemens SN 37304CN
The dishwasher stop in the middle of rinse . I can go to the end if switch to another program. Also, water doesn't circulate intencive enough to wash.Sometimes it does wash well, but mostly not.
    Genius:
  • 1,003 Answers
REPLACE THE TIMER
Posted on Jan 18, 2008
Dishwasher not cleaning very well.
Hello do it heat up ok is the water Hot please
Nov 13, 2015 | Siemens Dishwashers
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
Hi - my Viking dishwasher has developed a problem where the pump runs continuously, whether the power switch is ON or OFF. After the power is turned ON, the troubleshooting guide indicates that there is...
if you open the kick plate, you'll see the pan below the motor and check for leaks. The leaks will trigger the sensor to pump water out. Once you dry out the pan, the pump motor will stop and you should be able to reset the program.
Oct 15, 2010 | Viking DFUD042 Built-in Dishwasher
Have a shu 4322 dishwasher it fills with water and drains but the spray arms do not spray. have not tried anything yet.this dishwasher is not hooked up. it was given to me by a friend who replaced all his...
Welcome to FixYa.
There was indeed a recall involving the control replacement nearly two years ago now if I recall.
As for checking into the present issue ( it doesn`t sound like anything to do with the control based on your description ) it sounds like the pump impeller may have become stuck. Did the dishwasher sit idle or in storage unused for a period of time ?
I have a service bulletin I could send you via email regarding remedying that issue of stuck impeller if you contact me at macmarkus@live.ca
I`d suggest you run the dishwasher through a diagnostic, but either procedure will require hooking it up.
To do this test/diagnostic on the SHU4322 series machine, it is as follows...
To start test program, press and hold both REGULAR WASH and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ "20" = version 0 without jumper).
When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone).
Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start button is pressed.
To start testing, press both the REGULAR WASH and RINSE & HOLD buttons a second time.
When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ "6" = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
2 = Heating fault
4 = Filling fault
i.e.
If water level switch has failed (opened), display will show fault code "4" and unit will continually fill and drain where testing won't be completed. If flow switch has failed (opened), display will show "0", water won't heat (to 150?F) and water won't stop circulating. If NTC probe has failed (opened), display will show fault code "8" immediately and testing will end shortly after water has started circulating.
What needs to be done to solve the problem will depend on the results/findings of the dianostic, so let me know what you find and we can go from there.
Either way keep me in the loop and I`ll assist you the best I can. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Oct 10, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Year old Bosch SHU33A0UC won't start. Lights on
Light's on mean you have power.
Initiate the self test program by doing the following -
ON/OFF button.
RINSE & HOLD = NTC (temperature sensor) fault – note circulation motor stops shortly after it started
during an NTC fault
where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150ºF) and water won’t stop
Let me know what you figure out. I can repair these boards most of the time.
Dec 18, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
together, (e.g./ “6” = faults 2 + 4).
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Not drying
These dishwashers have no heater for drying dishes. It has a fan to circulate warm air. It is very important that your water temp is at least 120 degrees. It is the combination of hot water and air circulating that dries dishes.
Nov 19, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
Siemens 24 in. SE55A560 Built-in Dishwasher Logo
338 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
