Question about Frigidaire ATF6000ES Front Load Washer
It beeps and beeps but doesn't turn on
We have had the absolute worst experience with this washer. It beeps any time, turns on and off ALL the time, and we never know if and/or when the washer will actually come on and wash the clothes. I've had to smell the clothes in the morning to see if it actually turned on over night and washed the clothes.
We have had it replaced once under the warranty and will have to go back to the dealer before the warranty ends to try and get a new/different model washer - one the WORKS.
Has anyone else ever had this problem?
  • Anonymous Jan 26, 2008
    yes ,new control board
Ours stopped no power no lights i am replaceing the control board on order
Posted on Jan 26, 2008
    no beeps now dead !
6ya staff
SOURCE:
What does beeping mean during dry cycle?
My dryer did the same thing, it was so distrubing noise in the middle of drying cycles, so I turned off the sound switch it went away, now it doesn’t peep any more.
Oct 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Ltf2140e
Hello Mike - Typically, if the water temperature combination is not appropriate for the cycle selected, the status lights will blink and signal will beep 3 times. Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the washer. Select a normal cycle and verify if the washer continues to beep. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the control board or could have a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
Apr 28, 2013 | Frigidaire ATF6000ES Front Load Washer
Emachine T5234 beeps 5 times and won't turn on
5 Short BeepsYour motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
Aug 15, 2012 | E-Machines eMachines Desktop PC
Spin cycle doesn't work
bad drain pump or clogged drain line. some units have drain trap you can clean,if so you can clean it out yourself but will make a huge mess if you don't pinch close the drain hose between the tub and pump.
Nov 12, 2011 | Haier HLP21N Washer
K70IO beeping blank screen. When you turn the laptop on it beeps 9 times and the screen doesn't turn on. The green lights are on.
It may be the memory issue or the motherboard/processor faulty issue.
Try to remove the memory and insert it again and try rebooting your computer.
Also check your motherboard and processor and also the power supply - SMPS
If you need online technical support, you may very well contact TheBestPcDoctor. I get my all issues fixed by them and it is a reliable support according to my experience. If you want you can also get in touch with them @
www.thebestpcdoctor.com or via 877-407-9229
Please Rate if you find it useful
Oct 12, 2011 | Computers & Internet
Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Apr 23, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Is there a reset button on the LG front load washer
No button, but LG customer service says unplugging the unit for 1 hour and then holding the power button while turning it on will reset the computer.
In my experience this does work, but I don't think it resets absolutely everything.
Another time I had a problem LG customer service told me to unplug the unit, hold the power button for 60 seconds and then plug it back in. I can't confirm if this works or not, but it is worth a try first (60 seconds is a lot shorter than 60 minutes...).
Feb 25, 2009 | LG WM2688H Front Load Washer
Kenmore Oasis no error code keeps beeping low -loud
If its the main board that you are having an issue with, honestly i will suggest to get a new one instead, might cost you as much as buying a new one if you are going to have it repaired.
May 14, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Frigidaire Affinity Front Load Washer
instead of replacing the door switch assembly, you may want to try this because it worked for me:
1. unplug
2. remove the door switch assembly
3. carefully take the cover off this (there are 3 plastic tabs to open it)
4. refer to this diagram http://www.applianceaid.com/ads/doorsw417.jpg and bend the contact towards the contact on the coil (away from you in this picture) with some needle nose pliers. Watch the white contact switch as it tends to pop out. before you re-assemble it, poke the switch and see if the contact makes actual contact. if it does reassemble the unit and go about your merry way. if it doesn't bend it a little bit more.
do not bend this contact any more than you have to as it will always read as door closed if it is bent too far.
Aug 08, 2007 | Frigidaire ATF6000ES Front Load Washer
P4vmm2 doesnt boot,Y?
Hi yansky, When you turn the computer on do you see or hear any of the following: -Does the power LED turn on and if so for how long? -When you turn you power on listen closely for any sounds like hard drives or fans starting up. -Does anything show on your monitor, if yes what exactly? -When turned on do you hear any beeping sounds from the computer? If you do listen for the pattern of long and short beeps and let us know what they are. If you see absolutely nothing you should try testing the socket the computer is plugged into. Fuses blow, power strips die cords develop shorts so unplug the computer and plug in a lamp to verify you?re getting power. If that doesn?t turn up anything let us know the answers to the questions above plus any other observations and we?ll try to help.
Jan 13, 2007 | EliteGroup P4VMM2 Motherboard
Frigidaire ATF6000ES Front Load Washer Logo
108 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
