Question about GE 32GT740 32" TV
Why is my tv doing this?
Can you please tell me what could be wrong? When I press the power button, I hear constant clicking sound like it's trying to come on but never does. Can you help?
  • Anonymous Oct 31, 2008
    samr problem. just clicks several times but won't come on.
  • rsturdy Oct 31, 2008
    Same problem. Just clicks several times but won't power up.
  • 525 Answers
Short circuit of the transformer T1401
Posted on Sep 23, 2008
  • 979 Answers
Power supply problem. Usually caused by incorrect or missing feedback voltage...accordianman
Posted on Feb 19, 2008
What's wrong with my will not com on with power bottonlaptop
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 29, 2012 | Computers & Internet
Constant clicking sound when turned on....no picture....looks like TV isn't on. You only hear the constant clicking. You have to cut power to stop it.....hitting the power button on the TV doesn't...
Sounds like bulb is burnt out. Have replaced its the cheapest way to go. It may be a power board but if its out of its warrenty, then you may just want to buy a new set.
Aug 02, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
When i turn on my samsung 62'' inch rear projection tv(model#HLR6167WAX/XAA) it begins to whine like a fan working overtime, I will get a picture for about 5-8 seconds, and then it will cut off and the...
Hi.The ballast may be defective if you hear constant clicking sounds after you've pressed the power button.
If there are no clicking sounds after you press the power button(3-5 clicks every 2-3 seconds), this will confirm optimal ballast performance and, it will also confirm a major issue that concerns the Power distribution board. There are several weak or damaged components on the board that have failed.
The replacement of the power board is recommended in this case.
Jul 08, 2009 | Samsung Televison & Video
NO PICTURE, NO SOUND On My Plasma TV.
Should have been 3300 UF 10V caps that were bad? Shouls have been replaced with 3300UF 18V. 50V is huge. If it was replaced with a 50 the polarity may be wrong or the cap it too big to be seated property. Sometimes the caps just dry out and even a normal looking one will be the culprit of no OSD. Are you getting an LED fault code blinking? That should be a red led. Do you hear the relay clicking.? When you replaced the caps did you charge them? Just plugging in the set without trying to power it on for about 20-30 mins. I may be able to help you
gysgt2u1@yahoo
Mar 05, 2009 | Philips 50MF231D 50 in. Plasma Television
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
System sound not working on Dell Inspirion 6000 laptop
There are two sides of the problem. Hardware and software. To check whether the hardware is defective:
Try running the Pre-boot System Assessment (PSA):
1. Shutdown system
2. Press and hold on the "Fn" key.
3. Press the power button to turn the system on while holding on the "Fn" key.
4. Run the PSA until you get to the "colored bars". Then press "N" to say no.
5. Should you hear the beep codes, that means that the sound card is working fine. If you don't hear anything, then you need to replace your motherboard.
Now if your hear beeps that means that there's something wrong with the driver and audio settings. Do the following:
1. Right-click on My Computer then click on Properties
2. Click on Hardware then Device Manager
3. Click on the (+) beside Sound and Audio Devices
4. Right click on Sigmatel then click "Uninstall".
5. Go to support.dell.com
6. Click on Drivers and Downloads
7. Enter the Service Tag of your system (found at the bottom of your laptop)
8. Then download the audio driver. Just save it on your desktop first.
9. Restart the computer.
10. Install the driver.
11. Go to Control Panel -> Sounds and audio
12. Make sure that Sigmatel is the default sound device.
Please rate this solution if this helps.
Thanks,
ArnWuLF
Jun 23, 2008 | Dell Inspiron 6000 Notebook
Help
Hi there!
May be a power supply fault, Line stage, loose solder points or regulation( 5V to the CPU) to trigger switch on. If not familiar with electronics, please refer to a repair technician. Regards, JUS004
Jan 12, 2008 | GE 32GT740 32" TV
Clicking off and on sound
The power supply is in the protect mode. There is probably a short in one of the areas on the circuit boards. It is also very likely that there is a scan failure. The set would have to be properly troubleshooted to determine that exact failure.
Jerry G.
Jan 06, 2008 | GE 32GT740 32" TV
Power problems
Something wrong with the power switch? Does it stop if you press any buttons on the TV (including the power button)?
Aug 17, 2007 | JVC AV-32D305 32" TV
GE 32GT740 32" TV Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
