Duracraft Heat Giant Electric Heater Model CZ-2104
Had the heater at least 5 years or more. Date on the bottom says 06-06-97. You plug it in, the power light comes on, but the fan doesn't move. It can be moved manually w/ no problem, power on or off. If you turn the thermostat knob over the 1/2 point between cool & hot the caution light comes on. I opened it up to clean out the dust, and there was a lot of it. I used WD-40 to see if it'd help any. Still nothing. Any suggestions? The picture below is of the heater.
  • ckarnik Nov 19, 2008
    Same as above, except heater was not "dust-filled". The blower just died, I'm going to call the 800 number on the bottom and see if they'll sell me a new fan for a resonable price.
I have the same heater,04-08-97, have had problems with fan motor bearings, does the heater,Humm, when turn it on, this indicates loose motor bearing fan side.If so,unless you can find a replacement motor,as I have tried,your heater is on the way to the scrap yard.If you can find a replacement motor, please post it.
Posted on Jan 01, 2009
  • Mr Fine Jan 04, 2009
    I was able to repiar my unit using parts from a new unit,purchased yesterday, it is now running fine!
Since it's old and dust soaked, i'd replace it with one from walmart at about 30 bones.
it's safer to not try to revive it cause it's old and stressed out and has had juice running through it's poor, old wires for way too long.
i wouldn't take the chance on repairing it.  those are just the types of details you don't hear when someone burns to death via a faulty space heater.
Posted on Apr 06, 2008
Date of manufacture 81v400, serial r1194849014
1) Rheem 81V40 electric water heater ... manufactured pre 2009 ... posted serial number does not match manufacturer
http://waterheatertimer.org/pdf/Find-Age-of-water-heater.pdf
http://waterheatertimer.org/pdf/Rheem-Ruud-2009-water-heater-parts-by-model-number.pdf page 5
2) Possible date of manufacture 11-1994
Mar 05, 2013 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How can I find out what the Energy Rating is on my Reliance 501 w/h?
Reliance is AO Smith company.
http://www.reliancewaterheaters.com/prod/gas.html
http://waterheatertimer.org/Water-heater-manufacturers.html
1) Reliance does not post the 501 manual any more and I've written and asked for that manual, and they sent generic manual. Model 501 is both gas and electric.
2) That tells me the old energy factor is probably lower than .54 approximately, but it will be even less because energy factors are for new water heaters in perfect operating order under ideal conditions.
3) Energy factor is a measure of how efficiently the water heater turns energy BTUs into hot water.
Gas water heaters have higher energy factor because gas burner has more BTU punch than electric element, and can heat water faster.
4) However, energy factor is not measure of actual cost. It is merely a way to compare giant water heaters with smaller heaters, and gas with electric, without considering cost of heater, installation cost, repair costs, parts costs, life expectation of unit, disposal/recycling cost, or replacement cost.
5) You can improve your true energy factor by buying small cheap heater and maintaining it yourself so it lasts many years beyond manufacturer's warranty.
http://waterheatertimer.org/Replace-anode-rod.html
6) If someone buys a bigger water heater because it has better energy factor, it will not pay back the higher purchase cost. Same size to same size, the difference with higher energy factor is a few dollars per year.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
7) If you have sediment inside of tank, the energy factor is out the window.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 02, 2011 | Reliance Water Heaters
I have a comfort zone heater 1500W Portable Quartz infrared heater CZ-1500WT For the first two years it worked perfectly - two weeks ago the electric plug end that goes into the receptacle gets...
Unless you want a new house, stop using that heater immediately. There are severe internal electric problems with your heater. Since it's already 3 years old, I'm not sure it's worth trying to repair. With what you described, I'm surprised it didn't trip one of you circuit breakers.
Be safe, Don't continue to try to use this heater.
Jan 18, 2011 | Comfort Zone Heating & Cooling
The electric cord on our Duracraft heater model CZ-600 was very hot to the touch (closest to the plug) -- it burned so hot we could not touch it for more than a second. The heat was at maximum and we...
Look carefully at the plug's connectors to see if thewre is any scorching or otherwise burnt metal...electrical connectors tend to get hot due to the plug being loose(this causes more resistance and thus more heating). As a safe bet...the parts aren't expensive...I would replace both the power cord on the heater AND the outlet recepticle
Jan 17, 2011 | Heating & Cooling
OUR WATER HEATER IS BLOWING FUSES ..
1) Turn off power before touching water heater that is shorting or wet or was flooded.
2) Circuit breakers & fuses blow because of heat. A short will cause heat. Tighten screws on terminals inside box, listen for crackling sound/burning smell from loose-fitting parts.
3) Easy test for circuit breakers: move water heater wires to another same-size breaker. If same-size does not blow, then problem is breaker.
4) A short between fuse box and water heater could be gnawed electrical wire. Inspect wire.
5) Wires have size markings. 5500 watt water heater needs #10 wire. 4500 watt water heater needs #10 wire but can work with smaller #12 if distance is not long. See label on side of heater for wattage, voltage, etc. Element wattage is water heater wattage even with 2 elements.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
6) Short inside water heater can be elements or thermostat. Open covers and inspect parts for burning. Screws should be very tight against copper wire. Sediment could fill bottom of water heater cause lower element to short.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Sep 16, 2010 | Little Giant Water Heaters
Owner left a Duracraft air heater in home, model CZ 600. I am not familiar with it, and need instructions on how to use it. Does it require water, or can I just plug it in?
Just plug it in. Water is not what is inside of unit, Oil is inside. Put the dial at the amount of heat that you are wanting to come out. Very simple poroduct to use. I have owned my unit for over 10 years now.
Sep 06, 2010 | Heating & Cooling
I received a Duracraft model CZ-600 oil Heater. I don't know
I'm in the same boat..are we the only ones who have one?
Nov 22, 2009 | Duracraft DY-012 Tower Fan
Both togggle switches are broken
Go to the hardware store and match them up, they have toggle switch. Get the heavy duty 20 amp switch.
Oct 03, 2009 | Heating & Cooling
Heating & Cooling Logo
2,003 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
