Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
KitchenAid fridg compressor heating up
Hi. My KitchenAid fridg stopped cooling...getting power, but not cooling at all. I checked the coils, and they were a bit dusty, but nothing to prevent total failure. I noticed when I pulled he rear cover off that the compressor was smokin' hot. Any thoughts?
    Sergeant:
  • 288 Answers
If the compressor is very hot, it sounds like it may be locked up. Is there an external fan next to it that is not running. this will cause the comp. to overheat, like a dirty coil, which it sounds like you checked out. There is a thermal overload on the compressor. Its underneath the little plastic cover that the wires go to. It protects the compressor from a meltdown. It also has a relay in there. If you have an amp meter you can check this by waiting for it to cool off and clamp it on one of the compressor wires.when it clicks on, If the amps soar over 20 very quickly, and then stops. Its a locked compressor and the thermal overload is cutting it out. If you don't have a volt/amp meter, then try replacing the relay as its pretty cheap. But I would bet on the comp. as long as the fan is running.
Posted on Jan 16, 2008
Over temp light on and refrigerator/freezer not staying cold.
Extended warranties usually are not worth the cost. My guess is that KitchenAid wants you to pay $73 out of pocket even though it should be absorbed as part of the warranty replacement of the refrigeration system.
Mar 08, 2017 | KitchenAid KBRC36FMS Bottom Freezer...
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 11, 2012 | Refrigerators
Describe your Superba Architect KSCS25INSS Side by Side Refrigerator Problem - fridge has power - lights on - but not cooling freezer or fridge - no noise coming from fridge -
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | KitchenAid Superba Architect KSCS25INSS...
We are experiencing a heat wave. My new Kitchenaid fridge does not seem to be cold enough, and the items in the freezer area are not freezing. I have turned the temperature for the freezer down to -4...
heatman101
Aug 14, 2011 | KitchenAid Refrigerators
Fridge stopped cooling
heatman101
Jul 26, 2011 | KitchenAid Superba Architect KSCS25INSS...
Freezer coil keeps freezing up,defrost coil not staying on long enough.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | KitchenAid Refrigerators
Neither the freezer or the fridge is cooling. We replaced the defrost control which had a burned out section, but nothing. We have noticed for a little while that the fridge made this strange sound like...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
May 03, 2011 | KitchenAid KSRD25FK Side by Side...
There is no cooloing effect
the coolling in a refrigerator occurs when the compressor forces freon thru the system and the expansion of gas in the coils of the freezer takes heat away thus cooling the fridge. if no cooling is happening then the compressor is not running, the freon is to low on the charge, or the small "cap" line from the compressor to the cooling coils is blocked. Unfortunately the compressor is the most expensive part of the refrigerator and if it has stopped this can be a expensive problem. there is a few other things that can make the compressor stop. there is an overheat protection device on the side of the compressor that once in a while opens up thus no electrical power to the compressor and no cooling. the other part that can fail is the cold control thermastat. if this opens up the fridge can't start the compressor because the open condition of the cold control never "calls for cold". the other simple thing that can stop the cooling is a totally frosted up coil condition. the air can't circulate around the coils so no cold gets to the inside of the fridge. simple test step one unplug the fridge for 10 minutes then plug back in. Do you hear the motor in the bottom run? If it runs wait ten more minutes and put your hand into the freezer compartment. Do the sides feel cold? if the motor (compressor) in the bottom runs but freezer doesn't get cold then the system is defective and there will be no easy fix. If the freezer does show cold then the problem could be with the "evaporator" fan that circulates cold. this is an inexpensive part and can be replaced at a reasonable cost.
Apr 22, 2011 | Whirlpool Refrigerators
The fridge is not getting cold. I have cleaned out the coils and the fan runs but, does not cool upper area. Any ideas.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Dec 31, 2010 | KitchenAid KBRS22KG
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
266 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
