Question about HTC Touch P3450 Smartphone
It appears it went dead?
I had just made a phone call and placed the screen into sleep  mode. Now I can not even get the screen to reactivate or power down the phone using the power button. I have also tried the soft reset feature and this didn't work either. I have also tried removing and installing both the battery and the storage card. This didn't work either. So what is there to try next as the battery indicated a full charge prior to the phone going dead.
  • 3 more comments
  • edcal3a Jan 22, 2008
    I also have an HTC touch phone. It is not responding anymore. I keep getting a black screen. When trying to reset (bottom of the phone) it does not respond either. When tying a full reset (by presing the talk and stop buttons in combination with the reset, it gives me a message, however does nothing beyond this. All this happened so sudden. Pls your guidance!!!!
  • amit9449 Feb 06, 2008
    i had a similar problem of my htc touch geting hanged very often even when i tried deleting almost everything from the storage card and also shuting very programme off but 2 days back it got hanged and i tried switching it on by taking out the battery n and reset but the fone is not responding ..... nothin is happening to the fones screen .... can u plss help me on this ..... its been jst too months since i bought this fone and its already troubling me so much.... i m too much worried how do i get my started again ??
  • Chippychowa Feb 11, 2008
    It wont turn on and I try to power it on and it doesnt and I only had it for like 5 days
  • edcal3a May 11, 2010
    1 Other User Has The Same Problem
    Comment by edcal3a, posted on Jan 22, 2008I
    and stop buttons in combination with the reset) it gives me a message,
    beyond this. Should I turn it in? Or is there any hope? This was not
    caused by any tampering. There was indeed something with memory
    however does nothing beyond this. Should I turn it in? Or is there any hope? This was not caused by any tampering. There was indeed something with memory shortage.
KNUT solved the problem by doing a complete battery discharge charge cycle. If your are familiar with Ni Cad (nickel cadmium) batteries they build up a memory from the charging cycle and go dead just like the phone did. To correct this problem I did a full cycle on the battery ( i.e. discharge followed by a recharge). The lithium ion battery used in the phone is suppose to be less likely to acquire battery memory. I believe the battery on my phone did just that; build a battery memory from the charging. Having done the battery cycle the phone returned to service. I then proceeded to shut down all none essential operating programs as Guest described. The phone has now been trouble free for several days working as advertised.
Posted on Jan 24, 2008
In the top right corner of your phone is the task manager. When your phone is using to much memory it is possible for your phone to go unresponsive. My suggestion would be to make sure you check this once in a while and verify your phone isn't using to much memory. Also make sure your phone settings are set to shut down programs whenever you hit the "X" to shut down that prog. I've also found the best way for me to get my HTC to resopnd after this happens (going unresponsive) is to take out the bettery. This way you dont have to do any kind of system reset, hard or soft.
Posted on Jan 23, 2008
My monitor won't come out of sleep mode
when the computer enter the sleep mode, it is possible that the computer remove the check mark from this output activation.
When you have multiple ouptut like a internal LCD and output on a monitor, when going into sleep then waked up, laptop reactivate the internal LCD without reactivated the secondary monitor.
you could need to go in desktop property and reactivate the secondary monitor with the check mark listed : Activate.
If you only have one monitor but still a dual output card or two separate video card same thing can happend. try to connect the monitor on the second VGA or HDMI output and see if the video goes there.
then reactivate your secondary output and make it principal.
Does also happend when your computer is connected to a UPS power and your monitor is directly on the sector. (laptop issu also)
if a brief power outage arrive then the monitor shut down (no power) and the computer continu, as there is no monitor on the output any more Windows will automatically deactivate this monitor. when power goes back, this output is no longuer providing video. I suggest putting the monitor on a UPS as well.
Jan 03, 2014 | Westinghouse Electric L1916HW 19" Monitor
The monitor will go into sleep mode, and when first booted up will not register anything and goes to sleep. Have tried re-booting, checking the chords, plugging and unplugging them in. To no avail it...
No pc stated just monitor. (not even desktop or laptop) stated.
no OS stated, ether.
so ill answer in wide generic ways....
all computer are a problem, since days of Mr. Allen Turning to now.
ive done 43years of them just puters.(and other big systems MIL)
no person on earth can answer that common question
gee no pc stated,! nor can we lay blame until its fixed can we. ever.
3+billions of transistors. mine here typing now.
4,800,000,000, and friends, lots of other things to fail even LCD
its not a toaster or 4 banger calculator, at all.
its COMPLEX but 1 of those 2 boxs or cable are bad. sure.
(viewed in the MACRO)
sleep? how do you know it is sleep.
the screen showed that. text said SPEEP?
is the screen totally dead. (that is not sleep if true)
is the screens OSD button dead?,
the only clue i have here is one word, REGISTER (good word just too few)
so the screen never ever shows any text or HP logo ever
booting with monitor on for 5min. power on PC, see words?
no text
then push the monitors.
Select menu buttons on front of monitors. and the OSD pops does it , it must....!!! see image below (mine is Viewsonic, near new)
there are many simple tests here.
  • try you monitor on any other PC
  • or try you pc on any other monitor
easy no.?, just 1 or 2 tests and bam, who's bad.
called the process of elimination..
but OSD is first. no matter what,.
if the screen tests ok,, (display tests and its buttons)
then the PC is problematic, (1/2 the battle won)
the first thing to do (tell me what pC) but turn off all sleep
do that first. if you can even get the screen to work.
A pc never boots to sleep so.....
the PC can have 2 VGA jacks on the rear.
the PC can have DVI jacks, using those are you
try them all yet?
if you test the PC and it works and the screen works the cable is bad.
omg that screen is new, its even sold now at walmart.
not cheap either, too much, kinda
this is a modern 22" screen, LED>
and do not just go bad, is the power pack there and correct?
if the OSD screen is dead, check power first.
this is the Monitors brain, it works even with the PC dead.
the button is marked menu or select. this is test1.
osd-1z31dkbg41o2owghj0fas5br-1-0.jpg on my monitor ,heck all 2004 up
it tells you SLeep mode when the PC goes to sleep mode
or shows Power saver mode. live on the screen.
screen power on first sure.
all ways to go black done here.
Jul 20, 2017 | HP w2207 Monitor
I have a problem with my iphone it is unlock and y dont now the password
Place in to forced recovery mode using itunes.Use the following steps to place your device into recovery mode. If the device is already in recovery mode, you can proceed immediately to step 6.
Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
While pressing and holding the Home button, reconnect the USB cable to iPhone. When you reconnect the USB cable to iPhone, the device should power on.
Note: If you see the screen pictured below, let the device charge for at least ten minutes to ensure the battery has some charge and then start with step 2 again.
Continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears you can release the Home button:Use iTunes to restore the device.
If you don't see the "Connect to iTunes" screen, try these steps again. If you see the "Connect to iTunes" screen but the device does not appear in iTunes, see this article and its related links.
When using recovery mode, you can only restore the device. All user content on the device will be erased, but if you had previously synced with iTunes on this computer, you can restore from a previous backup
Jan 19, 2010 | Apple iPhone Smartphone
My 15" LCD monitor TTX went to sleep mode and never return back
mike_garzan, Your monitor will need some work done on it!! Do you know the "flashlight trick" that every owner of an LCD monitor with "cold cathode-fluorescent-lamps" should know how to do when the BLACK screen of death makes it presence known? Do this test first! It is a very easy test to do. 1. With a KNOWN GOOD pc fully booted to the WIN-desktop showing on a GOOD Monitor have a friend tap the CTRL key on the keyboard every 30 seconds or move the mouse to ensure that the pc won't go into sleep mode. 2. Power off the good monitor and disconnect it from the pc. Now reconnect the TTX9151 to the pc and wall outlet power. 3. Then and only then turn on the monitor and make note of what happens. Did you see or not see the WIN-desktop appear?
4. Now for the flashlight test. Even though the LCD panel appears BLACK, shine a bright flashlight about 1" from the screen's lower left corner and make note if you can see the Windows START icon even though the screen appears to be BLACK. 5. Turn off TTX9151 or yank the plug from wall outlet, and disconnect from pc. TEST IS DONE. Reconnect good monitor to pc to get back online. The test was to evaluate the current status of the "switch-mode-power-supply" and the CCFL inverter circuit DC source. If you could SEE something on the BLACK screen then you know that half of the SMPS is working and sourcing voltage (+5 or +3.3v) to power the vga/lcd interface board! It also means that the SMPS is not in FULL SHUTDOWN mode and only has a problem sourcing voltage(+12v to +18v) to the CCFL inverter circuit which generates 800v to 1200v ac to light-up the CCFL's that are hung across the rear of your LCD panel to produce the WHITE LIGHT needed to see what is on the screen. Now, if you didn't see the WIN-desktop, then the SMPS is probably in complete SHUTDOWN mode trying to save itself from a CATASTROPHIC, NONRECOVERABLE failure! (eg. smoke and fire) Put the TTX9151 in a safe place and get back to me with results of the TEST. lmistyrel and on or do a comment to your original post above on fixya and I'll give you advice as to what you need to do about getting it repaired or other actions/options you as a consumer/user of LCD displays have open to you. Bye for now. 12fixlouie
Oct 27, 2009 | Elo TTX 9154 15 Inch LCD BLACK W/...
Computer goes to sleep before it even starts up
Hi there, it appears as though the Power Options are set too short a time and the PC is going into sleep mode. Go to Start menu/Control Panel and look for Power options. Set them all to "never" This will prevent her PC from going into sleep mode. Good Luck.
Oct 26, 2009 | Dell Dimension 4600 PC Desktop
Test mode on nokia 1200
Test mode is used by engineers to repair particular problems with mobiles. It would appear you would need to take this phone to a mobile repair centre and get them to fix the s/w on it.
May 25, 2009 | Cell Phones
IPhone keeps going from vibrate mode to audible
Try a hard reset:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 05, 2009 | Apple iPhone Smartphone
Dead sleep
happened to us many times, the sleep to death error
logic board problem. buy a new mac realy.
try this, reset prom
take out the power cord. press hold the power button
and plug the power then takeoff power button and press it again.
try this, press hold P and I and power on
Feb 21, 2009 | Apple iBook G3 Mac Notebook
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
No not sleep mode as in sleep mode it only will turn off power and when the power goes out the sleep mode resets. your problem is most likly in the standby power supply or maybe even in the main supply. If you know how to use a multimeter and about the powersupply circuitry in these sets you should be able to find the fault. If you havent a clue where bto start a tv set is not a place to be experimenting around inside of. Have it looked at by a trained tech
Aug 24, 2006 | JVC AV-36D302 36" TV
HTC Touch P3450 Smartphone Logo
80 people viewed this question
Top HTC Computers & Internet Experts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
