Home | JVC | KD-G720 CD Player | Faulty speakers or deck
JVC KD-G720 CD Player
Problem for JVC KD-G720 CD Player
By jombi on Jan 16, 2008
when i use my rear speakers (clarion) my deck(jvc kdg 720) stops outputing sound and i have to shut it off and unplug the speakers to make it work is it the deck or the speakers this is the second set of speakers that i had.
Clarification Request
Posted by pugsrule on Mar 21, 2008
A solution to these problems could be a number of things. Are you hooking up an aftermarket radio to a factory system that has an amp(s)? Jombi:it sounds like you have a short somewhere in your systems rear speaker wiring. Trace that wiring down and rewire if necessary. Cheyner: do you have an external amp in your system or are you using the internal one in the radio? If your speakers are connected to the radios speaker outputs then you'd be powering them off the internal amp. By saying you hooked the radio up with rca cables would mean that you are sending a preamp signal to an outboard amplifier. The speakers would then have to be wired to the speaker outputs of the external amp to get sound. Make sure you're using preamp outputs designed for the purpose at hand: Are you wanting fullrange sound or are you trying to power a sub? Check to make sure you're using the correct set of preamp outputs and check your radios menu to verify that they are turned on. Check your fader settings too and stay sane!
Same Problem
Apr 14, 2009
-   It worked today... This unit has been cutting out and lights on deck stay on. If i fiddle with volume nob it sometimes works? This started after driving over bumpy Michigan bumps, oh we call them roads...-   Guest
Mar 18, 2008
-   im about to take my deck apart, it will play the music, as in i see the level going as if listening to music, but not even static comes out of the speakers, i thought it was my harness but i hooked my deck up via the rca cables and its still the same thing, please somebody help, i literally only listen to musci in my car and this is making me insane-   cheyner
Solution #1
posted on Oct 02, 2008
Not Rated)
cheyner
Rank: Master
Rating: 90%, 3 votes
the speakers are probably grounding out somehow, check the connections or for rust, my door speakers were rusty and grounded out, i just wrapped some electrical tape around the parts that touched the doors and i havent had any problems since, good luck, i went 6 months befoe i figured it out, i hope tis helps
Was this helpful?
Yes
No
Popular Solutions for JVC KD-G720 CD Player
Questions and Unsolved Problems for JVC KD-G720 CD Player
Do you recommend JVC KD-G720 CD Player?
Answer
Answer
i own a kd-g720 and i bought a ks-u58 so i could plug my zune in. i plugged it in and pressed the... (More)
Answer
Hi I currently own a JVC KD-DV7205 model How can i change the AM frequency from 1602 to 1710 Cheers... (More)
Answer
i have and mp3 player and my jvc sterio will not support it and it suppotrs my brother's when he had... (More)
Answer
how do i select a different theme for the display?
Answer
i have a jvc kd g720 when i hook up my mp3 player it says i have no files
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For JVC KD-G720 CD Player:
Top In Dash Receiver Experts
Rank: Guru Guru
Solutions: 14132
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more In Dash Receiver Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
