Question about Sony Cyber-shot DSC-W100 Digital Camera
My digital camera has a line through the screen... is that somethign i can fix?
Why is line flashing on monitor?
If the pictures have lines or marks in them when loaded up on a computer screen then it's a fault with the image sensor inside the camera, if they do not then it's a fault with the lcd screen on the camera, either way it's not an easy fix and will probably cost more than a new camera
Jan 11, 2016 | Olympus FE-340 Digital Camera
Can't see what I'm taking a picture of because the vertical lines/white screen
Unless you have a circuit diagram and have electronic knowledge the it is best left to an expert camera repair specialist.
The costs? Your guess is as good as mine. Camera repairers may charge a quote for repairing unless you go ahead with the repair.
Jun 09, 2012 | Sony Cyber-shot DSC-T70 Digital Camera
The problem with my W290 is that the lens is not coming out when I switch the power on. It seems that the lens is trying to come out but is not able to. Is there somethign I can do ?
lens unit is bad,so take out the lens unit do service,if needs replace the deformed/damaged parts,assemble and fix that u can do taking precautions.
Apr 11, 2010 | Sony Cyber-shot W290 Digital Camera
My fujifilm s5000 has purple lines coming up on the screen and when i take a photo. what could be wrong and is it easily fixed?i need to get it fixed as i cannot afford a new 1
If the purple lines only appear when you point the lens INTO the sun or light source, that would be why they appear in the photo. If you have the sun/light source behind you and the purple lines still appear on the screen and in the photo, it's time to get a new camera.
Aug 19, 2009 | Fuji FinePix S5000 Digital Camera
LCD screen has irregular lines and black spots but
Pls. be awair that if you do attempt to fix it by yourself the manufacturers warranty might not cover for any future problems.
Kodak Digital Imaging Support Centre can be contacted on any of the numbers below:
UK 0870 243 0270
International Toll line +44 (0) 131 458 6714
Jul 26, 2009 | Kodak EasyShare C743 Digital Camera
My camera fell
you could fix it but it would cost you probley more than what u paid for it,
Nov 19, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cybershot touch screen camera
maybe..it's have a picture tube problem..i think that you should go in a proffesional to fix your camera..that's only my opinion..thanks
May 20, 2008 | Sony Cybershot S650 Digital Camera
My camara screen has gone blurry
Lines on the Screen mean the CCD chip has failed, the camera cannot be fixed, My A345 is blurry too, but I don't know why.
Jan 24, 2008 | Fuji FinePix A345 Digital Camera
Cant charge camera on dock or print photos
the dock won't charge batteries that are ni-mh kaa2hr or Li-ion battery pack - so check that
about the printer's ability to recognize the cam, try this.. remove batt, put cam on top of dock (when cameras are on a dock, they can use the dock's power so you can print pictures without batteries) check if somethign will come up on the cam screen
if not .. either would need to be sent in for repair. a digital rep will advise you to send both so the repair center can check
Mar 09, 2007 | Kodak EasyShare CX7525 Digital Camera
Sony Cyber-shot DSC-W100 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Syzys
Are you a Sony Camera Expert? Answer questions, earn points and help others
