Question about Whirlpool GGQ8831L Gas Dryer
The burner in the dryer will not stay on.
The dryer will operate for only a few moments, but then the burner will turn off immediately afterwards. I do not understand what part needs to be replaced.
Thanks-
    Sniper:
  • 88 Answers
Most common cause is poor airflow. Make sure your ductwork is clear, and that you have good strong airflow at the exhaust point outside.
If that doesn't help, it may be the gas coils that need replaced....not a terribly expensive part, you can usually get the pair of coils together.
Posted on Jan 17, 2008
6ya staff
SOURCE:
Dryer goes on, and will start burner but will not reach operating temp. Shuts burner off almost immediately. Will start burner again in cycle but then shuts off before it reaches operating temp.
What brand? You could have a clogged vent, or a stretched out belt, allowing too much heat inside the drum, triggering a safety switch.
Jun 22, 2010 | Dryers
Gas dryer does not get very hot.
the dryer dries after two or three tries
Dec 29, 2009 | Kenmore Dryers
Dryer won't stay running. It will start, run 10-15 seconds, then shut off. I can restart it immediately but get the same results.
i would check the door switch. it may be worn just enough that the vibration of the dryer opens the circuit for just a moment. then check for other loose connections. the fact that you can restart immediately usually indicates a momentary break in the circuit. a temperature switch usually takes a short time to reset. while it's still running, try rattling various switches or smack the door to see if it shuts off. (just a couple of simple ideas to start with).
good luck....jay
May 21, 2009 | Maytag Dryers
Kenmore Gas dryer (110.76742500) will not dry properly.
if the vent is clear then the problem is in the gas valve. Youneed to replace the coil set part number 279834.
Apr 06, 2009 | Dryers
Try to turn on but it wont stay on
If that dryer has a 4 wire start switch which simply twists a quarter turn to get off then replace it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 15, 2009 | Kenmore 62602 Electric Dryer
GGW9200 Dryer Does Not Dry. Status Light goes immediately to Wet
if the heat is only staying on for a few seconds and cutting out the vent line could be clogged,pull out the dryer,remove the vent line from the back and start it,if the heat stays on the vent is blocked,this is the easiest thing to start with,if the vent is clogged you can try a leaf blower and blow the lint out of the vent line
Aug 06, 2017 | Whirlpool GGW9200L Gas Dryer
Frigidaire gas dryer, burner lights but gets shut off immediately
ckd coils on burner /valve they are probably breaking down..be sure you have good gas supply sounds almost like low or no gas pressure but believe you'll find coils bad
Jun 18, 2008 | Dryers
Whirlpool GGQ8831L Gas Dryer Logo
53 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
