Can you tell me which type of axle you have?
Full Floating Axles
To remove the drums from full floating rear axles, use the Axle Shaft Removal & Installation procedure in Section 7. Full floating rear axles can readily be identified by the bearing housing protruding through the center of the wheel.
Semi-Floating Axles
You may have to back off the automatic adjuster before you can pull the drum from the brake assembly
To install, reverse the removal procedure.
To install:
