Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
The USB connector broke!
I had my flash drive (a 2gig Micro-Cruzer U3 from SD) in our desktop and was swiveling in my swivel chair when my knee hit the flash drive and broke off the usb connector from the wires that run from the memory to the connector. I have many school files on it and desparately need them. And before you say "Back them up next time!," I was in the act of backing them up when I accidentally broke it. Please help me!!!
  • 3 Answers
I did the same to the cruzer as tedthehobit, and here's how I fixed it.
1) Split open enclosure with screwdriver alone edge. The small key-ring will come off when enclosure is separated. (Safety glasses, please). Circuit board is attached to plastic base--the piece for sliding the connector.
2) To see amount of damage and trace connection, remove the plastic as follows. Two notches are on each size at socket end. The other end has plastic bar across on-top. Use needle-nose piler to chew away top of notches, slowly and carefully to avoid stressing board and damaging surface. This makes it easier to move the notches to the side to lift the board up and out.
3) Look at pads where socket was attached. Fairly clean break, surrounding circuit trace and pads are intact. So, it is worth to continue.
4) The socket connection side has no large pads to solder wiring. The D+ and D- traces were lifted off slightly, but too thin to attach wire. Look at the other side.
5) Use flashlight as backlight, and follow traces from connector pads to ends of closest chips where it is big enough for soldering. [I have jpg of connection points--where to post it?]
6) Use wire-warp (hair-thin and pre-stripped) wire and small-tipped solder iron and work under bright light. Tin wire with traces of solder and remove excesses solder from iron tip. Connect wire to chip, melting and using the solder already there.
7) Solder other ends of wire to the correct tabs of the usb socket.
8) Plug usb socket into a socket extender to plug into PC. Extender is optional, but it will help to deteach from PC later.
9) Did not work the first time because 5V-line solder at circuit was not good (eventually came off). Re-solder. Plug back into PC, and cruze lit up and PC can access the file.
Posted on May 02, 2008
  • sandiskcruze May 02, 2008
    Left is Gnd, then D+ , D-, and +5 on far right. (Same for connection order at board and socket.)
    Brigadier General:
  • 6,966 Answers
There are only four (4) connection points to the USB: +5VCC, Data -, Data + and GND. This link provides illustrations and some explanation. You need to solder back the sheared off connector back to the wires or the PCB. If for some reason the connector can no longer be soldered back, try using a USB cable with the small end cut off and the wires exposed/stripped. You need to splice/solder the expose 4 wires of the cable to the appropriate connection points/wire of the flashdrive. Alternately, if you can get defective flashdrives or WiFi dongles, their USB connector can also be removed and used in yours.
This of course would require that you be a bit familiar with electronic components/circuitry, use of a DVM and a low wattage soldering iron. If you are successful but would have difficulty making your PC recognize/access the repaired flashdrive, you may need to do a onetime data recovery to be able to salvage your files and copy to your HD or another flashdrive.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 16, 2008
Unlock micro sd password
If this is a SD card, slide over the 'Lock' switch on the side.
If a USB flash drive - try RMPrepUSB - Drive - Clear Read Only Status.
Sep 19, 2013 | Verbatim 2GB Swivel Drive 96836 Media
Sandisk U3 Cruzer Micro 4Gb Cant Format
With your computer on and the SD Flashdrive fitted correct side UP in the USB port, go to 'My Computer' on the desktop and select the flash drive. The computer will ask you what function you want to perform on the drive and you must select 'format.' You did not say what kind of operating system you are using or I could give you more information. Let me know what happens,
Sciencewoman
Apr 01, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive My Drive is Empty How Do I Get U3Smart The Drive To Factory Settings. My Model is SDCZ6-4096A10 SN# BH0701l5B
According to Scandisk:
As of October 1st 2009, SanDisk started shipping the Cruzer Micro (SDCZ6-XXX) product line without the U3 software pre-installed on the device.
During the transition period, there may have been a small number of devices that were packaged in older packaging that states the device includes the U3 software. If you purchased one of these devices and would like to use the U3 software, please download and install it.
http://kb.sandisk.com/app/answers/detail/a_id/4425/kw/SanDisk%20Cruzer%20Micro%20USB%20reset%20factory%20settings/r_id/101834
Jan 14, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk U3 Cruzer Micro 8Gb Cant Format :S
rite click on it in mycomputer and click propertys to see if your thunb drive even has memory on it could have ben fried by sum and has no memory now
Nov 07, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Information on downloading file from a micro cruzer flash drive
if it is a regular folder just right click and copy and past it to a desktop my documents anywhere.if it is a program folder for u3 then it will only work for the flashstick.programs for u3 can only work on a flashdrive.please explain a little more what the downloaded file is.and what you want to do.if you got any questions please email me at gamecrazy944@yahoo.com
Aug 03, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cruzer program no longer on flash after viruses were removed
New ones avail:
  1. Microsoft and SanDisk team up on U3 replacement - Engadget Microsoft and SanDisk team up on U3 replacement .... is actually pretty good, but they charge you extra to be able to install any program not on their list. ...
    www.engadget.com/2007/05/11/microsoft-and-sandisk-team-up-on-u3-replacement/ - 99k - Cached - Similar pages
  2. GnU3zer U3 LaunchPad replacement (download torrent) - TPB Oct 28, 2006 ... GnU3zer U3 LaunchPad replacement ... The windows CD autorun function can execute ANY program specified in the autorun.inf file provided it ...
    thepiratebay.org/torrent/3547144/GnU3zer_U3_LaunchPad_replacement - 16k - Cached - Similar pages
  3. Microsoft, SanDisk to Replace U3 Drives Microsoft and SanDisk on Friday announced a technology-sharing agreement that will produce a replacement for SanDisk's U3 line of USB smart drives by the ...
    www.physorg.com/news98193946.html - 55k - Cached - Similar pages
  4. Microsoft and SanDisk still working on StartKey - the new U3 ... Mar 7, 2008 ... Microsoft and SanDisk still working on StartKey - the new U3 replacement ... Microsoft and SanDisk Expanding on and Replacing U3 Smart ...
    www.u3-info.com/sandisk/microsoft_and_sandisk_still_working_on_startkey_the_new_u3_replacement - 13k - Cached - Similar pages
Jan 13, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk flash drive
Strange... Vista does seem to have a problem with everything Sandisk...
Anyway, this should be all you need:
Launchpad Installer
Launchpad Uninstaller
Mar 19, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk flash drive
Is the account that your tying to access the drive with an Administrator account? If not, Log in as Administrator and try to access the new drive. If you ARE using Administrator privileges on the vista machine, the problem lies in the U3 smart driver. Try downloading and installing the drivers for the XP SP2 os on scan disks website, If vista rejects the install package off of the scan disk website, let me know and i'll extract the drivers and build an install for them for you.
Nov 29, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
870 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
