Question about LG WM-2277HW Front Load Washer
LD WM2277HW message problem
New washer stops with LE code..what's that?
    President:
  • 1,294 Answers
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Use powders for 'front loading machines'. And pl rate me if helped.
Posted on Jan 16, 2008
I have a LG front load washer model #59WD1653 LG WM2277HW I keep getting an error message of LE I have misplaced my Manuel. What does that mean
Google is not your friend, but can still be helpful.
https://www.manualslib.com/manual/409239/Lg-Wm2277hw.html
May 30, 2017 | LG Washing Machines
LG Tromm WM2277HW will not spin both directions, LE error.
clean filter check that its drained all the water out any blockage and the machine will not spin
Nov 28, 2011 | Washing Machines
LG Tromm WM2277HW will not spin, LE error
the pressure switch is jammed on meaning the water has not empty le reading the is excessive water in the machine
Nov 28, 2011 | LG WM-2277HW Front Load Washer
I have a Lg WM2277HW front load washer. I replaced P/N 6501KW2002 (hall sensor), unfortunately still recieving error code LE. I even ran normal wash cycle no spin and 3 rinse and spins w/ no spin to...
Make sure hall sensor is snapped in to correct location and is secure. Take a look at repair videos from repairclinic.com or appliancepartspros.com for guidance. And the error code is "LE" for sure not "tE" which is sometimes confused between the two.
Apr 29, 2017 | LG WM2277H Front Load Washer
GETTING AN ERROR CODE - LE ON MY WM2277HW
A common reason for an LE code is choosing a high spin speed on a bulky/ very heavy load. Try a cycle with a lower spin speed. If you still get the LE code, especially if it does not even do the wash tumbling, then replace the Hall sensor on the motor.
Feb 01, 2011 | LG WM-2277HW Front Load Washer
Lg washer wm2277hw le code comes on think it is the hall sensor where is the location of it
Hi
Thanks for using FixYa. You are right, the 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the Hall Effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 07, 2010 | LG WM-2277HW Front Load Washer
LG Washer Model #wm2277hw
It is a motor error
• The connector in the LEAD WIRE ASSEMBLY is not connected to the connnector of STATOR ASSEMBLY Reconnect or repair the connector • The hall sensor is out of order/defective. Replace the STATOR ASSEMBLY
Apr 19, 2010 | LG WM-2277HW Front Load Washer
LG front load washer WM2277HW. ''LE'' Error code
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Jul 03, 2009 | LG Washing Machines
LG WM2277HW - ERROR CODE "LE"
Hello remrama,
Please use this link to access the service manual on your display code message ( page 18 ) elaborates on the cause of that message. You should be able to determine which of the few causes may be the culpret,... http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Hope this helps you..
Regards,
Rick
Feb 22, 2009 | LG WM-2277HW Front Load Washer
Turned on my washer a TROMM LG wm2277hw and at every cycle turn it beeps LE
LE means a faulty motor. The motor is called the "stator" in this machine. Located behind the back panel. Pretty easy to replace in this machine. Replace the stator and it will work like new!
Apr 07, 2008 | Washing Machines
LG WM-2277HW Front Load Washer Logo
288 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
