Question about Garmin eTrex Legend GPS Receiver
PC will not detect Legend GPS
I have a newer PC that does not have a physical serial port. According to Garmin, a serial to USB adapter can be used. I have added one and assigned COM2 using standard serial settings but Web Updater not MAP SOURCE will detect the GPS. I have verified that the COM PORT is working properly and have also verified that GARMIN is selected on the interface screen. Any suggestions?
  • Mikelcollins Feb 11, 2008
    I am having the same problem.I have a newer PC that does not have a serial port, so I bought the USB to Serial converter and the PC will not detect the Garmin Etrex Legend.
  • Anthony Kisondella Feb 12, 2008
    I bought Garmin GPS ("Etrex"), have USB interface cable, it very disappointing that the PC detects it but can not implement connection; it laterly states that it need a driver to have connection; I have tried to look for driver invain. Can somebody help?
    Kisondella
Change the interface setting to NMEA Out and see if that helps. That is what I did on my Legend, bought in 2003. It still crashes the computer every so often, however, and I haven't figured out why.
Posted on Apr 12, 2008
Where do I find a 6 pin serial to usb adapter for the Garmin 421s? I can't find one anywhere on line. Does Garmin sell one? It's Saturday and Garmin's help center is closed. Their on line...
The 6 pin DIN plug found on the GPSMAP 421s data/power cable (Garmin part number 010-10918-00) is used for the sonar input.
Data transfer from the GPSMAP 421s is easily transferred by memory card.
Information about data transfer on the 421s is at about 50 seconds into this video.
http://www.youtube.com/gpscity#p/search/6/8ddIgvCAUmI
Real time NMEA data can be transferred using Garmin part number 010-10918-00 wired to a DB-9 serial connector (Instructions are on the cable).
It then can be adapted to USB using a serial to USB adapter.
http://www.gpscity.com/gilsson-serial-to-usb-port-4in-adapter-for-pc-and-mac.html
Sep 17, 2011 | Garmin 421S GPS Receiver
Cannopt download maps
Not surprised at that, don't know much about these units but from what i was able to find out they don't use a usb cable to load software they use a serial cable, and computer do not have a detection process for the serial cable, You need the cable as well as the software to load information up to or down from the unit. Quick check brought this to my attention and maybe something in here will help you.
https://buy.garmin.com/shop/shop.do?pID=173#accessoryTab
Hope this helps.
Apr 26, 2010 | Garmin eTrex Legend GPS Receiver
I have the garmin extrex legend and need to install the update for the freezing problem. I have the Garmin cable (9 pin to the 4 slide contacts) but, I'am using a dell mini with no 9 pin male...
you can buy a USB to serial adaptor at almost any computer store. it will install and show up as a com port, you can then update that way. i have the same GPS.
Nov 25, 2009 | Garmin eTrex Legend GPS Receiver
I hook up my GPS to the Com Serial Port to download maps from program and the program tells me its not connected. I'm wondering if this is a path problem with the computer to the port? How can I fix it?
What program are you using and what cables are you using? To hook mine up to my non-serial Mac, I had to get an adapter cable which needed drivers. With a PC, you need to make sure you have your settings correct. Often, the manual for the software you're using to download maps will tell you how to set it up correctly.
Oct 20, 2009 | Garmin eTrex Legend GPS Receiver
ETrex legend serial to usb cable problem
Have you tried using the cable with another device just to check it's working ok.. And try a different usb port also, they can be funny that way.
A Garmin rep I spoke to about this told me (off the record) to just go to my local electronics store to pick one up for app €15 as the same thing from Garmin would be about €75. So it's basically the same cable and should work. I tried it with a generic cable here in the shop and it worked in one usb port but not in the other two so a bit of trial and error is needed.
All that failing I'd bring it back to the shop and ask them if there is a different type you could try, possibly you need one with a higher data transfer capability.. But try the cheaper and easier options first..
Oct 07, 2009 | Garmin eTrex Legend GPS Receiver
How do I connect my garmin iii plus to my modern pc for downloads?
Looking for a way to connect a serial device to the USB port on your PC or Mac? Our USB High-Speed Serial Adapter provides a simple and reliable solution. This adapter is broadly recommended by serial device manufacturers due to its dependability and "Best in Class" compatibility.
http://www.tripplite.com/en/products/model.cfm?txtModelID=3914
$45.99
Mar 22, 2009 | Garmin GPS III Plus GPS Receiver
GPS to software communication issue
look in the options of the software ... choose auto or usb for communication with the garmin
Jan 10, 2009 | GPS
Garmin eTrex Legend GPS Receiver Logo
171 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
