Question about Kodak EasyShare Z612 Digital Camera
Hi. We have a kodak z612 digital camera. It
Hi. We have a kodak z612 digital camera. It worked fine all weekend - yesterday afternoon it was used and then put away. This morning I turned it on and half of the screen is black and the other half has lines through it? Some are vertical and one is horizontal. The top black part and where the lines begin - there is a white jagged line?
It wasn't dropped, did not get wet?
    Genius:
  • Kodak Master
  • 1,099 Answers
If problem contiinues it is a repair.
If OoW. 88.04 pounds or alt. Trade up.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Dec 02, 2009
SOURCE:
Kodak z612 shutter button lost
That's amazing to me since most camera makers will send you a part free if it is cosmetic. consider ebay buying a broken one... If you opt for a new camera, consider Canon. Best brand IMO cost/quality.
Mar 18, 2012 | Kodak EasyShare Z612 Digital Camera
Kodak easyshare z612 ... when i take pictures indoors the pictures are fine. However, when I take pictures outside the pictures are all washed out. It looks like an over exposure but I have tried all the...
hi, you have shutter unit defective. indoor works fine but outside too much over exposure..due to shutter unit has oil contaminated on blade or sand damaged. your local repair shop could charge you around $45 to 65 if they are willing to repair. Good Luck with you!
May 21, 2011 | Kodak EasyShare Z612 Digital Camera
Z612 no power on. Battery klic8000 is ok fully charged. No led flashing. No sand, no water, no drop, any issue. Was working well until yesterday.
As per your description it seems your camera have internal fault (circuit problem) which only get resolved in Kodak Service Center but before that you can check following things:-
  • Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
  • Direction of your battery might be wrong, Check out and put it again.
  • Load new or fully charged battery.
  • Check whether Memory Card/Battery Cover is properly closed.
Thanks....!!
Rating the solution is highly appreciated.
Sep 12, 2010 | Kodak EasyShare Z612 Digital Camera
I bought a new 8GB memory card for my kodak easyshare Z612. However it's not formatting. Help!!
The Z612 works with SD cards, which max out at 2GB. It will not work with larger SDHC cards.
May 20, 2010 | Kodak EasyShare Z612 Digital Camera
EasyShare Z612 Digital Camera: I bought a new 8GB memory card for my kodak easysh...
May 18, 2010 | Kodak EasyShare Z612 Digital Camera
How can you format a SD 4gb card for the Kodak EasyShare Z612 Digi Camera
You can't. The Z612 uses SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card and is incompatible with SD devices.
For SD cards (2GB and smaller), you'll find the Format operation in the Setup menu. Press the Menu button, then use up/down to select the wrench, then press OK.
May 13, 2010 | Kodak EasyShare Z612 Digital Camera
How to replace the lcd screen on a kodak z612
open the case of camera using small screw driver
Mar 25, 2010 | Kodak EasyShare Z612 Digital Camera
Will a HP 4GB SD memory card work in Kodak
No. The Z612 works with SD cards, which max out at 2GB. The Z612 will not work with 4GB SDHC cards.
Mar 17, 2009 | Kodak EasyShare Z612 Digital Camera
Z612 software
Hi
Click on start, go to programs and check if you still have the z612 program on the list, right click on it and select create shortcut then drag shortcut to desktop.
Hope this helps
Nov 08, 2008 | Kodak EasyShare Z612 Digital Camera
Kodak EasyShare Z612 Digital Camera Error #803
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Apr 10, 2008 | Kodak EasyShare Z612 Digital Camera
Kodak EasyShare Z612 Digital Camera Logo
226 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
