Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
Door Springs Need Replacing
The door spring needs to be replaced. Kick plate need to be removed or the whole unit pulled out?
  • kgoeller Aug 23, 2008
    I have the same problem and the model # is GPDB998JCO series 900 year 2001. and removing the kick plate doesnt really give you enough access. It appears to me we have to dismount the unit and turn on its back to service effectively. Any hints?
I have a KitchenAid KUDS01FLSS2 and was wondering if it is normal for the door to fall open... what I mean is the door requires to be supported when opening. Otherwise, the door will swing down and almost...
Yes indeed that sounds exactly like the door springs being broken. The springs are fairly easy to replace, what needs to be done to replace the springs is remove the lowest service panel/kick plate and hook the springs on the tub support frame/leg and the other end goes on a notch in the door hinges. The part number for the spring is 8270182 they could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
apwagner.com
midwestapplianceparts.com
Even though only one may be broke its advisable to replace both at the same time.
Good luck,i hope i have been able to help you fix your dishwasher,
Gene
Aug 13, 2011 | Dishwashers
I need to replace a sensor kit on a whirlpool dryer model len2000pwo. should i go in from the back of the dryer or front/top!!! The part was in the dryer drum when i found it so im not sure the best...
Disconnect the power source to your dryer before you begin to open its cabinet. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Opening the cabinet for newer Whirlpool brand models starts at the control panel. Begin by removing the end caps found at either end of the console. Lift them from the back, and then pull them towards you. There will be two screws holding the console in place. Remove the screws, and then slide the console towards you and flip it up. You will find an additional three screws at the back of the cabinet top. Remove these and slide the cabinet top towards you and lift it off the unit.
Proceed by removing the kick-plate. There are two spring catches that need to be disengaged before you can remove the kick-plate. Each spring catch is found about four inches in from each side. Use a putty knife or some other thin and flat object to wedge in between the front panel and the kick-plate. Push down on the clips with the putty knife to disengage.
Open the dryer door and remove the screws that are holding the hinges to the door. Tilt the door up and pull on it gently to remove it. Continue the dismantling process by removing all the screws you find that are holding the front panel to the unit. There will be door switch screws, ground wire screws, and other screws holding the front panel to the bulkhead.
Reassembling the entire unit is basically the disassemble process in reverse. Replace the front panel of your dryer. Replace the dryer door, and then replace the kick-plate. Reattach the cabinet top and then push the control panel back in place and reattach the two end caps.
Dec 01, 2010 | Dryers
I want to fit a wooden door to a intagrated dishwasher stoves
If your dishwashermag-glass_10x10.gif door is not closing properly or has developed a leak, it may be time to replace the entire door assembly. Some other signs of a defective door include sagging, difficulty pulling the door back up into a closed position and a door that feels heavier as it drops open. Replacing a dishwasher door is not that hard, but includes several springs and hinges that must be aligned correctly or the door will not fit correctly in the opening.
  1. tep 1 Unplug the dishwasher and shut off the water before attempting to remove any parts. If you cannot reach the electrical outlet, you can turn off the breaker switch that controls the electricity for the kitchen. Remove the drain hose that runs from the dishwasher unit to the sink drain.
  2. Step 2 Pull the dishwasher out from the cabinet until you have clear access to the side of the unit. Ask a friend for help with this part if the unit is too heavy for you to slide out without straining your back.
  3. Step 3 Check your dishwasher's owner's manual to find out exactly how the outer door panels are removed. Some models have a two-panel door where the control panel must be removed before the lower panel will come off. Otherwise, the door panel should be one solid piece or a two-piece assembly that allows the lower section to be removed separately to access the springs and hinges.
  4. Step 4 Remove the springs at the bottom of the door. Depending on the type of dishwasher you have, there may be a tension adjustment dial or simply a series of holes at different distances from the edge of the unit. If you have a tension controller, adjust it to a loose setting to make it easier to remove the door springs. Unhook the door springs from the hinge plate. Some dishwashersmag-glass_10x10.gif may have a cable and pulley system attached to the door springs. Check your owner's manual for removal instructions if this is the case with your model.
  5. Step 5 Use pliers to gently pull back on the door hinge plate's tab until the slot opens for the hinge pin to come out. Take out the screws holding the door hinge plate onto the front of the door panel. Hold onto the door assembly while gradually opening the door. Once the door drops down, you should be able to remove it by sliding the door off the hinge pinAlways wear safety glasses when working with the springs and hinges involved with a dishwasher door assembly. These items can fly off at high speed and cause serious injury to the eye.
Nov 15, 2009 | Stoves 27 in. DW60 Built-in Dishwasher
The door springs on the dishwasher need adjustment - how do I do this?
The door springs are accessable through the toe kick. There will be 3 or 4 steps where the spring can be attached. With the door closed and latched, so it can't fall accidently, remove the toe kick panel and with a pair of channel locks move the springs (one on each side) to the desired position.
Nov 11, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
The door spring on my Kenmore Limited edition 8542516 broke what part do I need and how do I fix it
door springs usually don't "break" they iether get stretched over time or come off their mount...
springs are adjustable and can sometimes be set to a tighter tension without pulling the unit out but that may be necessary... they are generally located on both sides of the unit near the floor and can be accessed by removing the kick plate.
If the spring came off it's mount then you'll need to pull the unit out and put it back in place... there will be a bracket on the door itself with a hole to put one end of the spring and a jagged notch on the chasey to hook the other end and adjust tension...
If it's actually broken then you'll have to get a replacement spring and install as above.
Sep 02, 2009 | Kenmore Dishwashers
I have a frigidaire quiet clean I dishwasher model # MDB124BFS2 - the spring on the door has broken. How do I replace it?
Hi, The easiest way would be to pull the d/w washer out of the cabinet about 8". Try removing the kick plate below the door and see if you can access the springs ok. Here is the part # 154430501. I would replace both springs while you are in there.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Door spring change
Hi, THe door springs are located behind the lower kick plate. Just remove the four screws that hold the panle on and you will see the springs and cables that help hold the door up.
Vic
May 29, 2009 | Dishwashers
How do I remove the oven door on a Garland Range
Hi, is this unit a convection unit? usually you don't need to remove the door to replace the thermocouple, if it is convection unit, you will need to shut the gas off, remove the safety, and there are two metal plates covering the burner area, take those out, the next thing is to remove is the burner, it is usually just fitted in the back, once this is out, as the pilot is attached to it, you can replace the t'couple now, assemble reverse.
If you really need to remove the door, and you are really lucky, remember to undo the spring hooks holding the door so it does not snap the door closed during disassembly, usually you can just pry up on the triangle near the hook, releasing tension to unhook the door hooks, leaving the springs attached. You can just take the screws out that hold the top of the door, the bottom of the door, and I think the handle, then the door skins split, and on each side at the hinge, there is a set of bolts holding the hinge in place, remove these, and you should be able to remove the door, otherwise you need to take the bottom kick plate off, along each edge inside the door frame, are screws holding the outer channels in place, remove these, and down along the inside of the kick plate edge too. Easily pry these away from the oven body, older units had a solid piece from front to back, and you had to remove the entire side panels, or were spot welded altogether, all you can do then is pry them back best as possible, and hopefully they won't crease. Inside these channels are the hinge plates that the hinge goes into, unbolt them, slide the door out, and there you have a door in you hand. Garland has a kit to replace all of these parts as you go, if they are badly worn. I know, allot for a thermocouple. Hope that helps, and thank you.
Dec 21, 2008 | Garland H283 Gas Kitchen Range
Dishwasher Door Tension Adjust on Electrolux EDW5500DSS
I just adjusted my Electrolux DW springs. The springs are on the bottom sides near the back. They pull on cables that hold the door (via pulleys). The springs can be moved to five different holes to change the tension, but I needed to pull the DW about 2/3 out for side access.
Oct 26, 2008 | Dishwashers
Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Oct 06, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
167 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
