Question about Toshiba Satellite M35X-S149 Notebook
Motherboard replacement Toshiba laptop
My 2 year old toshiba laptop will not turn on with power button with either ac power or battery power , power button does not light up. I'm thinking mother board problem , is there a web site or instruction manual for this ? and a source for parts ? Thanks for any help
  • hockeysavant Jan 16, 2008
    yes , I checked w/multimeter , got 19.6 vdc
    Master:
  • 788 Answers
Are you sure the ac adapter is providing power to the system? You should check it with a multimeter first before ruling out a problem with the system.
Posted on Jan 16, 2008
  • Dean Joly
    Dean Joly Jan 16, 2008
    Then ya, probably motherboard. Ebay is the easiest place to purchase. As for site with help, unless you are or know an authorised Toshiba tech, it could be hard to find the proper disassembly guide. I don't have access to them, but you never know what a Google search can dig up.
    Otherwise you can just take it apart being very careful to note where all the screws and cables go. I like to make a sketch of each section and mark the size and position of all the screws. That way you can put it back together.
    Start with the bottom screws, then the keyboard, then the screen, then the palmrest, then the motherboard.
Reset bios password on toshiba equium a200-1vo
a 11 year old PC with XP> I bet.
asks at toshiba first, I bet not. and they are always first.
here are the steps.
and old vista laptop, (its not supported too well)
1: RTM , read the service manual.
2: on newer PCs , you must call them. (by law) 2012 to now)
looks like TOSH dropped support on this old dog PC.
did you try the all batteries out trick yet>? this is always first trick tried, coin cell out,big battery out, then AC pack unplugged
bingo now for no power, push power button for 30 seconds.
this discharges, everything inside, not put coin back, and AC pack only, run on AC, bios reset?
the RTC coin cell will be no good, after 11 years time.
replace it first.
here is place that stores old manuals, free, no tricks
http://www.manualsdir.com/search.html?q=A200-1V0
there is no real toshiba forum there at TOSH, (lame, that.)
only KB, jive. (near useless generic answers)
https://support.toshiba.com/support/navShell?cf=tais_kb
the KB even mixes Cell phone with laptops, useless answers. in KB
call them? using phone?
May 28, 2018 | Toshiba Computers & Internet
Toshiba Laptop Satellite C655 will not power up
Take out the battery and only hook up the AC Adapter into a normal working outlet. Push the power button and if it turns on then you know the battery is bad. If you still dont get the laptop to turn on then either you have a bad AC Adapter or the motherboard is bad and would need to be replaced.
Sep 23, 2013 | Toshiba Satellite C655-s5090 Notebook
I have a toshiba laptop about 2 years old. I didn't use it for a few days and now it won't turn on at all.
was it plugged in when you tried to turn it on?
if not, try charging it for a couple of hours. the battery must be completely empty
other than that I might need more details
Aug 07, 2011 | Toshiba Computers & Internet
My toshiba laptop wouldn't work well when connected to power source but will function well am using the battery
Laptop shuts off when AC adapter plugged in
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard
Jun 20, 2011 | Toshiba Computers & Internet
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Toshiba Satellite A305 AC Adapter
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
My Toshiba Satellite AS205-5000, will not turn on nor does the fan come on. When the low battery sign came on, I plugged in the AC adapter to charge it, and it shut down and wasn't charging. After it shut...
You Need To Replace the DC Jack..this involves desoldering the old/faulty dc jack from the motherboard, then cleaning the board, then soldering a new dc jack in place of the old...
But First, Test Your AC Adapter - use a multimeter (available at any home improvement store for under $7)...
Nov 14, 2009 | Toshiba Satellite A60 Notebook
Toshiba satellite m55-s135 won't power on even when plugged in
When the AC adapter is plugged to the wall, if it has an LED make sure it is on, remove the battery and connect the adapter to the laptop, does it power up?
Install the battery after charging, see if your laptop powers up.
If the laptop does not power up, the motherboard needs replacing.
I hope this helps to resolve your issue.
Good Luck.
Mar 15, 2009 | Toshiba Satellite M55-S135 Notebook
Battery discharges, and will not charge, computer wont run on AC
how long have you had your laptop? the toshiba laptop battery can be normal used in 400-500 cycles, that means normal in 2 years. if the age is over 2 years, the battery declines day by day. get a new one if it is unnormal
Dec 04, 2008 | Toshiba Satellite P35-S609 Notebook
Toshiba Satellite A105 no power
try looking at the DC input. My brother's 1st laptop had that same problem. All we need to do is solder it. Remember-1st dc connection, not the one on the MB.
Jul 30, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite Laptop Power Failure (A105-S1013 System Unit)
Okay, lets troubleshoot this:
1)Does your laptop run on battery alone ?
yes )test your jacks continuity to the motherboard using a continuity tester or Digital Multimeter.
a)test between the center contact and the motherboard.
b)test between the outside metal cover of the jack ,and the motherboard.
c)If either of these fails continuity,replace the jack.
2)does your laptop now power up on AC ?
yes)Stop
No)Try the BIOS upgrade.
Feb 10, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite M35X-S149 Notebook Logo
91 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
