How can i install and format a hard drive - Computers & Internet
    Scholar:
  • 42 Answers
Install the HD into your computer case with screws, connect a ribbon cable and a power cable, ensure that your HD is set to master or slave, depending on where it is installed in your drive chain (IE: only, or first, device should be master, second device should be slave). Startup the computer. Windows should recognize it, but if it doesn't, Under WindowsXP and above, goto control panels, open administrative tools, open Computer Management, Select Disk Management, find the new disk in the lower portion, right click on it, and create a new partition.
Hope this helps!
-Backu
Posted on Jan 16, 2008
    Genius:
  • 1,226 Answers
You should provide a installation disc, a bootable installation disce (Windows or other OS) and and your will need a CD/DVD rom to boot your system in the ROM. see the site for more information on installing Operating system: http://support.microsoft.com/kb/316941
may this help.
6ya staff
SOURCE:
System formating
How to Format a Computer with Windows 7 Warning - Formatting hard drive information does not permanently erase the data. Even after a computer has been formatted, deleted files can be easily recovered. If you want to permanently wipe your hard drive by completely overwritting hard drive data, check out various programs that will ZERO out the drive.
To format your hard disk during Windows 7 installation, you'll need to start, or boot, your computer using the Windows 7 installation disc or USB flash drive.
  1. Turn on your computer so that Windows starts normally, insert the Windows 7 installation disc or USB flash drive, and then shut down your computer.
  2. Restart your computer.
  3. Press any key when prompted, and then follow the instructions that appear.
  4. On the Install Windows page, enter your language and other preferences, and then click Next.
  5. If the Install Windows page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start your computer from a Windows 7 installation disc or USB flash drive.
On the Please read the license terms page, if you accept the license terms, click I accept the license terms, and then click Next.
On the Which type of installation do you want? page, click Custom.
On the Where do you want to install Windows? page, click Drive options (advanced).
Click the partition that you want to format and click Format.
If you have more than one partition on this hard drive and want to get rid them to make one big drive again, then select a partition and click on the Delete option for each partition. Once you have deleted all of the partitions, select the Unallocated Space partition and click Format.
Pick the formatting option that you want.
When you've finished formatting, click Next.
Follow the instructions to finish installing Windows 7, which include naming your computer and setting up an initial user account.
If you do not want to reinstall Windows 7, you can cancel the installation at this point and keep your newly formatted drives.
This information has provided by, youc an also find instructions for other operating systems here: How to Format Computer
Jan 26, 2015 | Computers & Internet
Format hard drive
This is generally how your format the hard diskand install Windows.
First you need a Windows XP or Windows Vista installation CD and the productinstallation code, which is printed on the Windows label on the bottom of yourlaptop.
Boot up with the Windows installation CD start and follow the instructions toinstall Windows.
Next Delete the existing Windows partition.
Next Create a new partition.
Next format this new partition - Format the partition in NTFS not a quickformat. This will prepare the Windows for a clean install. Quick now if you only want to format the hard drive.
Mar 14, 2012 | Dell OptiPlex 760 PC Desktop
Good day. I bought this Netbook with Windows 7 installed. I need to format and reload Windows XP as I have software that I need to use that only works with XP, I have an external "USB CD Drive"...
Hi neil720...
Installing the external CD Player...
You will go and start up and install Windows XP by doing he following:
Plug in your external CD drive, and let windows install it into the system...
Once the CD is ready to go, shut down the computer.
You will first need to format your hard drive, I will give you instructions on how to do that.
1...To format your hard drive and install XP:
To set you computer back to factory fresh settings you will need to format the hard drive and install the XP operating system and the drivers.
1.Format the hard drive:
You do this by double left clicking on "My Computer",then double left click the main drive (normally C drive).
When the window pops open, you will choose "Format"
Keep in mind that once you format your hard drive you will loose all your files,programs,pictures,etc that you installed since the computer was new.
So make your back up on a portable hard drive,thumb drive,etc.
2. Once the formatting of the hard drive is complete you will need to install the XP operating system along with the drivers.
You will now insert the CD's into your external CD player starting with #1 first and continuing until all has been installed.
After all has been installed, shut your computer off and restart.
That will bring your computer back to Windows XP factory new condition as far as operating is concerned.
Please take time to rate me
Sep 15, 2011 | Acer Aspire One D255-2670
How can i format my laptop
Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
Step 2
Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating system floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
Step 3
Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
Step 4
Determine which file system is to be used. Windows XP will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
Step 5
Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
Step 6
Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
May 06, 2010 | Computers & Internet
How to format hard drive
To format any extended or external hard disk
Right Click the drive (example D:\ )and select the FORMAT Options
Click START to Format the Hard Drive. The time to format depends on size and the condition of the Hard Disk.
Feb 15, 2010 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
How i can format my laptop toshiba L300D can anyone tell me how to do it plz
If you have the windows install disk, just put it in and start a new install..there will be an option come up in the installation to format the drive.
If your laptop has a second hard drive listed that is very small that the recovery partition...go to it and run the recovery program
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 27, 2009 | Toshiba Satellite L300D-ST3501 Notebook
Windows XP OS installation
its not a virus as when you format your hard drive it would wipe it out ... how many hard drive do you have ? if you have 2 install a new instalation to the good hard drive and you should get to the part of xp that says do you want to format the partition on this hard drive by pressing ( f ) do this and when your pc has finished re-installing you can click on my computer in your start menu then right click on the bad hard drive and run a full format from there ...
hope this helps ... jedi-inc ....
Feb 09, 2009 | Microsoft Windows XP Professional
I can't farmat my hard drive
if you have a windows xp cd installer or win98 cd installer, install it, let it format your drive.
Jan 31, 2009 | Maxtor Hard Drive
HOW DO YOU ERASE A HARD DRIVE
Fastest, and most efficient way to erase an hard drive is by formatting it.
If the hard drive is the one in which the system is installed, then you will need to boot the computer using the system install disk (eg. Windows XP disk) to format the hard drive.
Oct 26, 2008 | Maxtor Hard Drive
Hard drive installation
You need to format the drive first before you can use it. If you are using windows xp, right click on the drive E and then click on Format. You can put a check mark on the box next to quick format if you like it faster and then click on start.
Please leave me a comment after you did what I said.
Feb 23, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
Open Questions:
Computers & Internet Logo
711 people viewed this question
Ekse
Marvin
Marvin
