Question about Acer AC711B 17" CRT Monitor
Pls,i need asistance.
Relay cntnues clicking when i trned on the mnitor and the c801 cpacitor(22uf/50v) xplode. what is the psible cmponent which causes this kind of problem?
    Genius:
  • 1,003 Answers
A BAD POWER SUPPLY BOARD woul cause this type of problem IT IS MORE COST EFFECTIVE TO REPLACE ENTIRE MONITOR
Posted on Jan 16, 2008
Internal UPS fault. for br800i how to repair
Hi Edi, try to check the output relay of your UPS it might be stuck, thats always the case or sometimes the transformer.
Feb 16, 2013 | APC BR800I UPS System
My acoustic solutions tv turns itself off every time i switch it on, what could be the cause
It may be detecting shorted circuits in the power supply, backlight inverter boards, main board. You need to troubleshoot the problem starting at the power supply module first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 09, 2010 | Televison & Video
Tv wont stay on
Remove and check capacitors in power supply board with a multi meter. All capacitors should have +/- 20% of the uf rating. I've had a similar problem with my toshiba 35". I found a 50v 22uf cap that only read about 5 to 6uf, well below the 20% window. When I unplugged the t.v. and replugged it I could here the relay click but the t.v. would immediately shut off. After ordering and replacing the ten cent cap, NO MORE PROBLEMS!
Aug 10, 2010 | LG 52SX4D 52" HDTV
Toshiba TV32C50, chassis TAC9307, no start, but relay 'clicks'. No obvious electrolytic capacitor failure but power supply C801 (470 mfd, 200 V) replaced, no change.
Relay picking usually means the low voltage circuit is OK. You have a High voltage problem. Try changing the Horiz Out Transistor.
Mike
Apr 04, 2009 | Televison & Video
Standby mode
if you are a tv tech
check c639 22uf at 50V its on the primary side of standby power supply.
Dec 23, 2008 | Sony KV-32S42 32" TV
LG CT-29K30EX 29" TV plugged
LG CT-29K30EX 29" TV - We have the same symptoms as described. If you are a person who is not afraid of opening the back cover of your TV and replacing parts inside. this tip is for you. Contact a service person if your not 100% sure. Its actually easy, it involves replacing a small capacitor in the power supply section. You don't need to troubleshoot coz i've done that for you for free. Find this capacitor in the power supply. C801 with a value of 100uf / 35V. De solder and replaced it with the same value or a much higher Voltage rating e.g. 50V. Done! your T.V. is alive again. - Rey Tilles - New Zealand
Apr 06, 2008 | LG Televison & Video
Trying to get Capacitor Rating
RobCline,
What you have there is a VZ-2B chassis built in 1995. The caps you're looking at are in the regulator circuit 981 (22uf/50v) and 982/983 (47uf/50v) which is NOT the only problem you have there. I would strongly suspect that the regulator itself will need to be replaced and you might find anywhere from two to three dozen caps in that unit in need of replacement.
If you know how to ESR a cap and have the equipment go for it and let me know what you find. I would be surprised if you found even more than three dozen with high ESR.
If you're not that technically inclined take it to a repair center and have them estimate it before the work is done and discuss with them how many caps they find that are in need of replacement.
If they find less than 12 with high ESR they're not likely doing a very good job.
Bill
Nov 18, 2007 | Mitsubishi VS-5059 50" Rear Projection...
Nec px 42vp5
The fault is on the PSU board.
Replace D 28 on the PSU board. You have to use a fast diode (I used BYW 95). Replace also the
330 uF/35V and the 22uF/50V near to this diode.
After this the unit will work perfect.
Oct 25, 2007 | Televison & Video
Zenith TV B32A24Z
You have a power supply problem. On this set the entire board is available for exchange but it is most likely not going to be worth the repair as these boards run for about 120 to 145 bucks. Good luck
Jun 05, 2007 | Zenith B32A24Z 32" TV
Acer AC711B 17" CRT Monitor Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
