Question about Uniden CEZAI998 Phone
My antenna on my uniden handset phone broken, how and were can I purchase a antenne or just an antenna in an empty case of a headset
4 Suggested Answers
SOURCE: Need English documentation for Uniden Sireus 5080 phone & 0500 handsets
Here is the solution I found.
I also bought this equipment and also didn't find anything suitable in the internet, BUT a phonecall to the suplier EUROCOM brought the solution.
I called their service nr. 03-9029000 and got the English user manual as a PDF doc. by email.
Yssachar
Posted on Feb 15, 2009
SOURCE: can you buy headsets seperately for th uniden
yes just purchase a Plantronics M175 headset, a lot better than the one that Uniden offer.
Posted on Dec 16, 2009
ltp9735
  • 12 Answers
SOURCE: My antenna has broken off of the cordless handset of my phone.
if its warrenty still in effect or contact Uniden to ask them...thats my best bet ..
Posted on Apr 02, 2010
What is right size plug for corded headset for Uniden 6.0 cordless phone?
The cordless phone headsets use a 2.5mm plug.
The larger 3.5mm plug is used for the PC or
laptop computer headphone connections.
The model number for your cordless phone is
on a small sticker under the battery inside the
handset. Entering this number at
www.manualslib.com will allow you to
get a free copy of the original owners' manual.
Feb 01, 2016 | Uniden Cordless Phone
How adjust ringer on uniden headset
Pick the model of your Uniden DECT 6.0 phone from the list beginning at http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
Jul 07, 2014 | Uniden DECT 6.0 Cordless Telephone...
What does it mean when it says searching on my cordless phone
This usually indicates that the handset is having a problem establishing a wireless connection with the base unit.
Try placing the affected handset in the base charging cradle for a few seconds to let them sync to each other. Remove the handset and try again. If you are able to use the phone again, but only within a few feet of the base, there is probably an issue with the radio or antenna in the handset (assuming all other handset works fine). If all associated wireless handsets have the same scanning message and only work close to the base, then the problem is likely with the radio or antenna in the base, instead. You may be able to see a loose or broken connection if you wish to dig around - but if there's nothing obvious - you're probably better off leaving it alone and obtaining a replacement instead. Before beginning - be sure to unplug the AC power and telephone wire from the base and the remove the battery from the handsets.
Without a specific model number for your phone, only a generic solution can be provided. There may or may not be additional suggestions to help you solve the problem if you provide the Uniden model number.
Jan 09, 2012 | Uniden Cordless Phone
Coffee spilled into phone
If the phone is still not working after allowing to dry out for a few days you will need to purchase a new phone. If it was split on the handset and not the base station you only need to purchase a new headset.
Apr 19, 2011 | Uniden Cordless Phone
Phone say out of range
Verify the antenna, make it touch the headset and base antennas if they still report out of range is the headset antenna, take out the batteries of the headset for a wile, and put then in again, try to use it again, also verify if the base have a button to reset the used frequency to be sure the channel its ok.
Mar 29, 2011 | Uniden Lands Phones
Apr 02, 2010 | Uniden Cordless Phone EXAI985
Can you buy headsets seperately for th uniden
Dec 13, 2009 | Uniden Cordless Phone
Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Nov 25, 2007 | Uniden Lands Phones
Uniden CEZAI998 Phone Logo
166 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
