Question about HP iPAQ rx1950 Pocket PC
Locked out of my ipaq
Im locked out of my iPAQ
  • jerkface Apr 22, 2008
    my password randomly changed... i don't know what it is anymore. it's ridiculous.
  • ansewon May 27, 2008
    I have the same problem .I set my pasword and now I cant get in. can anyone help. and I will never set the password again.val
  • HP Master
  • 13,433 Answers
  • press and hold the Calendar and WiFi buttons
  • while holding those buttons down, press and hold the reset button for ~2 seconds
  • When the HP iPAQ screen begins to fade, release the Calendar and WiFi buttons first, then remove the stylus from the reset button.
  • Press reset again.  (Or, plug the device into the AC adpater.)
  • The Pda is now hard reset and restored to defaults stored in the rom memory. the password and everything else should be gone and it should work as if you had just opened it for the first time.
    Posted on Dec 22, 2008
    Hard reset of my hp ipaq 510 i forgot my password
    s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
    Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
    • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
    • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
    Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
    • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
    • Remove the battery of your iPAQ.
    Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
    1. Turn off your iPAQ by holding down the End key.
    2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
    3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
    NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
    Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
    How to unlock hp ipaq hw6920?
    The HP IPAQ HW6920 locked in which Country's Network ?
    You can Unlock it using the Unlock code from the website
    Superunlockcodes there you can get the Unlock code at low cost and unlock it,check code for your network lock,Country!!!!
    HP IPAQ HW6920 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your HP IPAQ HW6920 mobile phones. If you enter over a certain amount of wrong unlock codes on your HP IPAQ HW6920 mobile phone, your phone may get hard locked and sometimes become unusable.
    1 - Switch ON the HP IPAQ HW6920 with a sim card that is Not accepted.
    2 - The HP IPAQ HW6920 will prompt you for an unlock code.
    3 - Enter the unlock code, which you can buy from our website.
    *NOT ACCEPTED : We mean, to use a sim card from a network other than the network your HP IPAQ HW6920 is locked to.
    Each HP IPAQ HW6920 mobile phone has an unique unlock code. You can buy the unique unlock code for your HP IPAQ HW6920 mobile phone using the form above.
    May 25, 2011 | HP iPAQ hw6920
    Im download app into my hp ipaq,then it hang/jam...it not running like usual..
    For hanging/Jam problem, few factors can be involved, First of all you have to check, how much space is being left in phone memory after installing particular applications, To check the settings, Go to settings, Memory,
    Solutions:
    1. Soft Reset,
    Try resetting the device while hold down the End Key for few seconds, when the phone is switched off take off battery for few minutes, then try putting the battery again, It will clear the memory used by the softwares,
    CAUTION: Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.
    2. Hard Reset
    Hard reset will restore your Ipaq to factory default settings, Perform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.
    settings.
    NOTE: The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center). bilalseham_6.jpg
    if you require more assistance feel free to reply to this post
    Thanks for using FixYa
    Regards-BA
    Jan 27, 2011 | HP iPAQ 510 Voice Messenger Smartphone
    Im trying to access the internet through my ipaq 3800, can anyone hekp with this?
    hi thanks for using fixya!
    If you want to access the internet thru your ipaq, you should first contact your network service provider to send you the GPRS configuration and settings. From then, you may now enjoy the connectivity of your ipaq.
    Regards!
    Apr 22, 2009 | Compaq iPAQ H3850 Pocket PC
    Ipaq hx2410
    reinstall windows thats the best i've got...
    May 18, 2008 | HP iPAQ hx2410 Pocket PC
    Ipaq RX 3115 Stops at align Screen
    solia, I'm sorry, I didn't mean to close the chat session on you.
    Is your unit still under warranty? If so, check with the manufacturer.
    They can help.
    Mike
    Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
    Pairing nokia 6230 with ipaq
    No Need to pair IRDA with Ipaq PPC,s most models of Ipaq PPC have Infrared always active try to send a picture to your Ipaq directly from the gallery of your Nokia 6230 via IRDA its should work. U Can not pair Nokia Mobile phones to PPC due to nokia,s Software. But you can pair with a Desktop pc with a IRDA dongle
    Sep 19, 2005 | Nokia 6230
    Ipaq rx3115 doesnt turn on!
    I am guessing that you have made sure that it is fully charged. If it is, since you have only had it a week I would try a hard reset. I don't know if the 3115 has them but check to make sure that any battery door lock switches are locked.
    Sep 14, 2005 | HP iPAQ RX3115 Pocket PC
    Rx3115 locking up
    To execute a hard boot on the iPAQ rx3115, the manual says to "while pressing the two outside buttons on front of iPAQ, press the recessed reset button on bottom." Hope it Helps... Wirzan
    Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
    IPaq rx3715 locked up
    try leaving battery out overnight.
    Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
    HP iPAQ rx1950 Pocket PC Logo
    426 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
