Question about Acer AC711B 17" CRT Monitor
How to repair
When i switch on this type of monitor acer model ac711, there is a sound of continous clicking and i found out it was the relay and capacitor c812 xplode
    Genius:
  • 1,003 Answers
MY SUGGESTION IS TO BUY A REPLACEMENT MONITOR AN LCD BECAUSE IT USES LESS energy about 50% less and at a low voltage.
YOU PROBABLY CAN FIND ANOTHER RELAY AND CAPACITOR ONLINE OR AT A TV REPAIR SHOP electronics supply warehouse BUT IF THESE COMPONENTS WENT BAD
OTHER COPONENTS MAY BE BAD ALSO AS A RESULT OF THESE HAVING FAILED SOMTIMES RESISTORS,DIODES AND TRASISITORS LOOK GOOD VISUALLY BUT ARE NOT.
Save your self sometime and money by getting a new lcd monitor
even if you repair your monitor its still old if you replace this mointor with a new one you elimiate all risk because a new monitor will have all new parts and a warranty and save money on your electric bill because it takes less power to operate.
Posted on Jan 16, 2008
My Ibm monitor light blinks continously but nothing on screen and the is a clicking sound continously
There is a short within the HT section and this can be possible with the failure of the flyback transformer or the driver transisitor.
So if you are equipped please open the back panel and check for shorting on the driver, also when powered this can heat up which confirms that the flyback is shorted.
replace with the same type.
Oct 01, 2011 | IBM E74 17" CRT Monitor
NO AUDIO DEVICE ON MY ACER AC711
check whether the audio drivers are installed or not
Sep 08, 2009 | Acer Aspire 3000 Notebook
In lg studioworks 500g one capacitor blows off immediately after power on capacitor is 47 micro farad 160 v plss help
Before you open it test the input use analog multimeter for continuity testing,
if the pointer moves forward then turns back quickly your rectifier diode is good but the pointer is steady like this image below
Note:
Make sure this power cord connected to
your monitor before testing.
3721e99.jpg you have shorted semiconductor inside. check the thermistor, the bridge type diode & relay switch can cause of blown filter capacitor if you did not found these shorted at the primary section of power supply.
Gud luck..
Aug 28, 2009 | Computers & Internet
Yep mine too, I have no green light only flash and pop sounds.
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 22, 2009 | Acer AL1914 19" LCD Monitor
How can solve the blurriness
I have the same problem nothing can be done. The monitor is not focused anymore.
May 25, 2009 | Acer AC711B 17" CRT Monitor
LCD Monitor Acer AL1717 shtting down problem
Aside from the capacitor and IC, there's a relay that you need to change. You need to locate that defective relay on the PCB and replace it.
It would be best to consult the manufacturer of the LCD and get the exact part number of it.
Have a great day!
Regards,
Firesnake09
Apr 26, 2009 | Acer AL2216WBD LCD Monitor
CRT Voltage Pin Voltage
What is the problem? Can't fix without info.
Dec 25, 2007 | Acer AC 711 17" CRT Monitor
Acer 1912 monitor that ceased to function
My monitor started to flash for 3 or four minutes before starting up, this was after three good years of faultless service. (I've always found Acer monotors to be excellent value) I was just about to purchase a pair of new monitors online when I decided to take it apart, as I had nothing to lose. I found that 2 capacitors on the mainboard had bulged and leaked. A quick trip to Maplins and 79 pence later I was armed with 2 new 1000uf 16v capacitors and within five minutes had removed and replaced the damaged items. I now have my good old AL1912 back in service.
Oct 20, 2007 | Acer AL1912 19" LCD Monitor
No Image
Typical failure is High voltage supply. Can you hear a high pitch whine or the relay click on and off? You will need some test point reffence voltages for the board and confirm you do not have a damaged VGA cable. It is not easy to give step by step via forum. Google "monitor repair", there were a couple good general guides that are printable. If youe high voltage tranformer (flyback) is gone, do not go any further. Price of a monitor flyback is $65 to over $100 depending on model.
Apr 09, 2007 | Acer AC711B 17" CRT Monitor
Acer AC711B 17" CRT Monitor Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
