Question about GE Advantium 120 Convection/Microwave Oven
Power Out Same thing. Baking fish at 375 in 2 1/2 year old Advantium 120 volt when it completely went out. Cord and elec. outlet okay. Need solution.
  • aldente Jan 28, 2008
    I was preheating on oven cook @ 400 to cook a frozen pizza when it went completely out.  I'm perplexed!  My oven is also about 2 yrs old.  I checked the breakers, GFI and cord and outlets.  All fine.  What's up?
Common problem with the Advantium. Culprit is a thermal cut off (TCO) for the cavity. Other posts detail where it is. I ordered a replacement at the link below.
http://www.mouser.com/search/ProductDetail.aspx?qs=i1kXDmddXkNuE3oXZkbuYw%3d%3d
Posted on Mar 17, 2008
Our Advantium 120 oven (model # SCA1001KSS 02, Manufactured June 2008)is not working. Began w/ time not coming on when cooking and just a little green microwave light shows while cooking.
Typical of a control microchip failure caused by a power surge. With a microwave as old as yours, it is safest to simply replace the entire oven rather than attempt to fix it, as older magnetrons are likely to fail.
May 05, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
My SCA 1000 completely shut down and won't come back on
There is probably an internal slow-blow fuse,they will electrically fatigue over time.It will require the cover to be removed to replace it,look for an inline fuse holder on the hot lead where the power cord enters the housing.
Dec 19, 2012 | GE Advantium 120 Convection/Microwave Oven
My Advantium over is approximately 9 years old. I heated up broccoli last night for dinner and then it just went out. There is completely no light on showing the time and I checked the breaker switch. Do...
check the wall socket to make sure you have electricity to the plug. Secondly then check to see of the appliance "fuse" has blown, simple repair. If not, you have a costly serious issue.
Oct 07, 2010 | GE Advantium 120 Convection/Microwave Oven
My advantium 120 died ( shut down completely) when I was baking a pizza, I checked the outlet it is fine, I unplugged to oven and tried it again, it didn't do nothing, i don't have any light in the control...
I can't solve your problem, but mine did the same thing. I had the repairman look at it. I have an extended warranty so the call was free. He checked the fuse it was good.
I can't remember the exact words he used but it amounted to the brain of the microwave was broke.
They said it would cost to much to replace so they gave me my prorated purchase price.
I am going to call them Monday and ask exactly what the problem was.
I will get back to you.
It could be the same thing.
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
I need a bakeing guide for Advantium 120 comb microwave speedcookingHow can I get one???
The owner's manual covers baking and much more.
If you've misplaced yours, you can download it here.
May 14, 2010 | GE Advantium 120 Convection/Microwave Oven
G.E. ADVANTIUM 120 JUST WENT DEAD NO POWER AT ALL.
Bill,
I have the same unit. It just happened to me. DId you find a resolution?
I was using it on the oven mode and it just stopped working. It's completely dead.
Thanks
Bob
Apr 11, 2010 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 oven: Was boiling water and oven completely powered off. House circuit breaker is OK and not tripped. Plugged into another working outlet with extension cord to see if display came on. It...
You will need to remove the top grill vent first, then you can remove the screws coming in from the top of the grille vent then that will expose a screw holding down the control panel at the top. Remove the screw and remove the control panel. The fuse is located in a little 1" fuse holder just behind the front panel near the top.
Feb 05, 2010 | GE Advantium 120 Convection/Microwave Oven
Was baking at 450 degrees and entire unit went dead. Confirmed outlet power is ok. Took off front grill but can't see anything obvious. Can see a fuse, could that be blown??
Yes! The fuse is usually the most common problem. It is usually a 15 amp Cerramic fuse (white in color). Appliance parts places usually carry them, for a buck or two.
Best of luck.
Jan 20, 2010 | GE Advantium 120 Convection/Microwave Oven
No power, i have power to the outlet but nothing on the unit works.Is there a fuse?
remove the cover ... look on the floor of the unit near where the cord enters the cabinet.
Oct 12, 2009 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 Complete black out
Since you've already checked the fuses, my next suspects would be the thermal cutouts (or thermostats or thermal fuses, depending on your exact model number). One would be located on the right side of the chassis right above the magnetron. The other would be located on the left side of the chassis. It's the flame sensor. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Advantium 120 is not actually the model number - you have to look on the tag around the door or inside the cavity for that. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk I appreciate your thoughtful rating.
Apr 15, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
248 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
