Question about Refrigerators
Burning smell followed by failure to freeze/chill Whirlpool sbs
This unit had a burning hot metal-plastic smell that could have choked a horse! The next afternoon I found everything had defrosted in the freezer and it totally stopped cooling. When I'd left in the morning it still had the cold that was present when "it" blew....
this is a 3 year old unit - really disappointed that I'm having to deal with this mess. I've been on bagged ice for a week and found my papers tonight that have a 2-5 year warranty --what's the chances this is going to be something outside of the warranty? I've got an option to purchase a warranty repair service and have them fix it or give me $$ toward a new one if it exceeds $500....trying to hedge my bet at this stage.
  • gail0906 Jan 17, 2008
    Thanks, it was the relay - black and melted. Cost with labor $157 vs 900 for a new 25cft unit.. Guy was terrific, helpful and everything he told me, I'd already read about on this site. So I was able to agree to a repair with some knowledge base - instead of not knowing if I was being taken or not. Thanks for the help and your service to the public.
  • 447 Answers
Sounds like it was just the Compressor relay failing. Sometimes when they fail(and they all do)-- they fail shorted......not open(the compressor just wouldnt work) and they melt down. Sometimes it ruins the terminals on the compressor. But it is a relatively simple repair and a 3yr old unit should be worth the repair.
Posted on Jan 16, 2008
  • joey  shearer
    joey shearer Jan 18, 2008
    Im glad i could help out and you have the unit repaired. Tell all your friends about Fixya!!!! Thanks
Dryer smells like it's burning
You probably have lint build up in the lint houing, you need to clean dryer by take dryer apart ,you may need to call services tech.
Feb 18, 2015 | Whirlpool Dryers
Engine died burning smell
If the smell is like burning oil or really hot coolant. you may have killed the motor. If it smells like burning plastic ,look for shorthing wires around the exhaust manifold battery, alternator or place that a wire could be burnt. If a rubber smell check for belt failure.
Jan 19, 2013 | Toyota 4Runner Cars & Trucks
My dryers smells like its burning and inside when drying gets really too hot. The air vent going outside is clean. I took off the casing and cleaned the inside of the dryer. The belt seems like its ok....
Lint burns quickly and rarely holds a flame long enough to cause a fire hazard. Metal burning would probably indicate friction on spinning metal, like the motor shaft, or the drum rollers. Plastic/rubber are usually parts that are intended to wear, and can usually be replaced.
Along with the belt, you should also check the idler pulley that takes up the slack in the belt, as well as any drum rollers or nylon glides on the top of the dryer door where the drum rides. Metal, plastic, and lint have distinct smells, and you should be able to determine which one(s) you have by smell.
Lint is a common burner in dryers, and it seems you've looked in some of the obvious places it can accumulate. When you have the cover off, pay special attention to the burner area, and any ducts from the lint screen area. Also, any gaps in insulation where air flows could cause hot spots in the unit. If you can see the flame while its running, make sure its size is not excessive. Flames should not be too low or too high, and should not escape the burner housing.
If you notice soot buildup, your gas/air mixture is off. If you've switched from natural to bottled gas or vice-versa, you may need to swap the burner orifices to match the different pressures of the gas fuel.
May 18, 2011 | Kenmore 74632 Gas Dryer
Hot plastic smell and the wall between freezer and fridge is very
This is most likely due to an overheating condenser. I have put together some instructions on how to check and repair this. Follow the link below and let me know if it helps.
May 11, 2010 | Samsung RS2630SH Side by Side Refrigerator
A burning smell and steamy smoke come out when we open the door.
Normally, the last part of any cycle involves using the heater element inside, and at the bottom of, the dishwasher to give dishes a final hot rinse. Possibly some small plastic-type material has become melted and stuck to the element - which will remain hot even after all water is discharged. Hence the smell.
Nov 17, 2009 | Whirlpool 24 in. GU980SCG Built-in...
There is an idler pulley near the drive pulley under the engine. It is made of plastic and is a common failure. It freezes up and doesn't want to let the belt move. Have you noticed the smell of hot/burning plastic? You can replace it with an original, but it is still plastic. Metal replacements can be had. I think I got some from so try there. They are a great resource. Shipping is fast and inexpensive and they have everything a guy could want.
May 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Dryer smelling hot and smoke detector goes off
clean the venting going to the outside and the dryer really ahould be taken apart and delinted to avoid a fire if the unit is older
Mar 21, 2008 | Whirlpool LER5636P Electric Dryer
Refrigerators Logo
290 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
