Question about Dell Dimension 3100 PC Desktop
Dimension 3100 Won't Boot
I turn on my computer and I receive this message:
Drive 0 not found:Serial ATA, SATA-0
Drive 1 not found: Serial ATA, SATA-2
Drive 3 not found: Parallel ATA, PATA-1 (PRI IDE Slave)
Strike the F1 key to continue, F2 to run the setup utility
When I strike the F1 key I get this message:
No boot device available
stike F1 to retry boot, F2 to set utility
It work fine Sunday evening, I came home from work Monday and this is what I get. Any assitance would be greatly appreciated.
Michelle
  • 1 more comment
  • Michelle72
    Michelle72 Jan 21, 2008
    I tried Backu's solution and it still didn't work. I was afraid the hard drive maybe damaged. I do appreciate all the help I have receievd here & I will be using the site anytime I have any other questions or issues. Thanks.
    Michelle72
  • Anonymous Dec 27, 2008
    This was extremely helpful! It worked like a charm!
    After upgrading a failing hard drive in my Dimension 4700, I encountered this message, and although the BIOS looked right, there was something causeing this problem. Upon resetting to the defaults in the BIOS, all was well with the machine!
    Thanks again!
  • Anonymous Apr 01, 2014
    On boot up it gives a black screen F1 to continue and F2 to enter set-up
    New Friend:
You may need to replace your hard drive. But it's adviceable you ask a technician to support you since its a little technical.
Posted on Sep 17, 2011
    Genius:
  • 1,226 Answers
Try remove the hard dirve and then fix it back. and if the system prompted you to strike F2 then go . In the bios setup. load the " setup bios default and press "F10" to save and exit. the computer will restart.
Posted on Jan 16, 2008
  • Anonymous Jan 21, 2008
    if the Backu suggestion is not working? There is no other solution on that matter because it was the only solution regarding your problem.
    If you do backu answer and it don't work. it is probably sure that the your harddrive is damage. however if you not done yet and afraid on fixing inside the system then let someone do it for.
    You can test your harddrive by connecting it to your friends computer. You are happy if the hard drive work in there computer and you can backup your important files, in case you harddrive working in your friend's computer, then we tackle further issue in your computer otherwise. if this not work then, its time you to provide another harddrive. I hope that your harddrive got a warranty in the store.
    Scholar:
  • 42 Answers
Make sure your HD Cables are all firmly plugged in, and that all drives are starting when you turn on the computer. You can tell with harddrives as they will slightly whine, and have a small, steady vibration to them. If they are all starting, and all cables are fully seated, check in your Setup utility that the drives themselves are Auto-Detect. If none of this fixes your issue, you may have to refer your computer to a computer repair shop.
Hope this helps!
-Backu
6ya staff
SOURCE:
I have a HP Asterope Motherboard The Sata HDD or the Sata CD/DVD cannot in not detected in the BIOS and the computer can not boot-up When I use a IDE drive on the Ide port, It works But I have a...
Reasons a sata device might not be recognized in BIOS:
(1)Serial ATA disabled, enter bios and enable SATA.
(2)Serial ATA cable defective
(3)Serial ATA drive defective
(4)Serial ATA cable defective
(5)Serial ATA device not plugged into power.
(6)Serial ATA power adapter defective.
Feb 26, 2011 | Computers & Internet
On boot up on my Dimension 3100C I receive the following error message: Drive 1 not found:Parallel ATA, PATA-0 (PRI IDE Master) Alert! chipset heat sink not detected System halted!
first off your going to ewant to hit f2 or f12 to get into setup and you are going to want to change boot oder to your hard drive. i then would open the comoputer up by taking the side of the case off and checking your cpu. u are going to wanna make sure there is a heatsink or fan securly on your cpu. if not this could over heat and burn your cpu up. heat sinks look like thisbadboy616.png
Jan 07, 2011 | Dell Dimension 3100 PC Desktop
I have a abit 1c7g motherboard intel 3.2ghz processor twin western digital raptors sata raid 0 config ... 1 sony dru 710a on ide 1 (slave) trying to install plextor 880sa dvd burner having conflict with...
Suggest you connect the plextor to the SATA port 3 and set it's jumper to Master. All SATA drives are seen as Master drives. (Check the serial number on your WD SATA drive "Primary".
Enter the bios menu. Within page 3-7 section 3-3 Advanced bios features. Check, 1st, 2nd and third boot devices.
Floppy disk drive as, 1st boot device. 2nd boot device, "Primary WD SATA port 1". 3rd boot device, CD-ROM drive SATA port 2, Plextor 880sa drive". Save and exit the bios. If you no longer have you're manual you can download it from the link provided below;
http://ftp.abit.com.tw/pub/download/fae/ic7-g_eng_v101.pdf
Check page 3-13. See OnChip serial ATA Mode. As noted, the RAID option is available when the item "OnChip serial ATA" is set as [Enhanced Mode].
Cheers'
Mike
Jun 27, 2010 | Abit IC7-G Motherboard
How do i hook up lg/gh22 super multi dvd rewriter to my dell dimension 3100 The cords are not the same
The drive you are installing is a SATA drive. The system came with a PARALLEL ATA or PATA optical drive, The motherboard has a SATA controller and the HDD is a SATA drive. So you need a SATA data cable and connect it to the SATA 1 port on the motherboard. There should be a SATA power connection inside the chassis that is not being used, that you can connect to the drive. Then go to system setup (F2 at boot) enable the SATA 1 controller and disable the PATA controller
http://support.dell.com/support/edocs/systems/dim3100/en/sm/parts0.htm#wp1043338
Oct 05, 2009 | Dell Dimension 3100 PC Desktop
DRIVE 1 NOT FOUND, PATA 0
One of your settings in the BIOS is set to look for a drive and it is not finding it. That is what that message means. If you have multiple drives in this machine then one of them has failed. If you only have one drive then the settings are set to look for a drive and it is not finding it. To fix this reboot the computer. When you see the DELL logo press F2 to get into setup. Then go down to Drives and turn off any drives that are set to Auto, except for your C: drive which should either be SATA 0 or PATA 0. Since it is not saying that SATA 0 is not found then I suspect your main drive is on the SATA 0 channel. Go to SATA 1 and turn it off. The instructions should be on the screen. Usually you select it by moving the arrows and then hit enter, you then use the arrows to select off. If your CD-ROM/DVD ROM is not on PATA 0 then turn it off as well. If you need more advice let me know.
Apr 28, 2009 | Dell Dimension 5100C (D51CL1) PC Desktop
Dell Dimension 5510
Normally you would set it up to boot from:
1. CD/DVD drive
2. Hard Drives
There may also be a floppy drive to add in whereever you want it.
This problem sound like some kind of drive controller or the drives are not being recognized in BIOS...check and make sure you see the hard drives when setting the boot order.
Mar 15, 2009 | Dell Dimension E521 PC Desktop
Is this hard drive sata or ide
It is SATA - Serial ATA (DELL Dimension 4700)
Jan 17, 2009 | Dell Dimension 4700 PC Desktop
Drive 2 and 3 not found
I keep on receiving the follwoing message "drive 2 not found parallel ATA PATA 0". How to solve this?
Sep 20, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Drive 0 not found;serial ATA,SATA-0
are you SURE you connected up the power connector in addition to the SATA connector? If so, you may have hozed your drive.
Feb 06, 2008 | Dell Dimension 3100 PC Desktop
Dell Dimension 3100 PC Desktop Logo
1,026 people viewed this question
Ekse
Clive
Clive
Alun Cox
