Question about RCA F35317 35" TV
Rf connector broke off
I have a RCA tv and the rf connector broke off. I'm not sure what to do to fix the problem. Do you have any suggestions?
    Sergeant:
  • 395 Answers
Your in luck the set can be repaired. a replacement F connector is available pt # 215543 from any RCA parts disributor. Have a tech help you with the replacement it can be tricky. in the mean time if you have a VCR use that with the compsite video hookup to the tv and let the VCR be your tuner.
Posted on Jan 16, 2008
I accidently knocked my satallite box down, which pulled out and broke off the VHF/UHF jack. Is this something that would be expensive to fix, or is it something I can fix myself?
The repair to replace the RF connector can be a long and complicated one. You should probably take this to a TV tech for repair. Or in another case, if you have a video one or a video two connection, apply RCA cords from the satellite box to the TV. Save a the price of a repair. Thanks for asking and give me a few hands!
Sep 13, 2010 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Magnavox sdtv tuner i set it by mistake in setup in rf and now i get nothing but power light i cant get back to setup to fix what i did
If you have a friend with a TV that has yellow/red/white connectors, for composite video and left/right audio, connect using the RCA plugs to that TV. Then you can see the 'menu' settings.
You could also connect the Y/R/W connectors to a VCR that has those inputs {most} and connect the VCR RF output on channel 3/4 to the RF {cable connector or 300ohm converter} input on the TV. The VCR would convert the RCA jack stuff to channel 3 or channel 4.
tom
Aug 11, 2010 | Televison & Video
I have an analog tv (coax cable) and a new dvd (av plugs) player. How do I inexpensively connect them? i saw the solution posted about the rf modulator. I have a digital to analog tv convertor. Is this...
NO. An RF modulator and your digital-to-analog (DAC) TV converter are 2 different devices. The DAC will convert over-the-air (OTA) digital television signals from your antenna to analog NTSC format so your older analog TV can receive OTA broadcasts. The RF modulator converts base-band video (composite cable/RCA connector, or S-Video cable connector) to channel 3 or 4, so you can watch video/audio on your set. To use both the RF mod. and the DAC converter to the same TV, use an A/B switch for F-connector coax, or follow the directions for the RF modulator to make the correct connections.
Jun 12, 2010 | Televison & Video
Rf conector broke
You have two choices, you can: Take the set to a repair shop and have the tuner replaced. (expensive) Or you can use a VCR or other device with a tuner and fees video and sound in through the RCA jacks on the TV like you would to connect a video game console. Some shops that are worth a darn will actually repair the broken RF connector. You might ask the shop about what options they offer for that repair.
Apr 05, 2010 | Sanyo DS19310 19" TV
I have a 36 in Toshiba 2003 TV, model # 36A43. The cable connector on the back of the TV snapped off, Is there an easy fix? Can I buy another part? Any suggestions?
There is really no easy fix...but patience is on your side if you have some. You will need to buy an RF connector at a electronics store..Please visit a commercial dealer, Radio Shack is to limited! Pull the tuner out of the tv board, open the cover that contains the solders. Lets hope the board is not cracked. and be sure one of those small coils are not pulled out..Donot even think about touching or moving these coils if you open the wrong side ot the tuner shield. Reconnect the tail of the RF connector through the board. You sometimes will have to cut the tail length wise for a fit. [You better buy two RF conectors just incase you make a goof. Then solder the a ring around the RF connector to the tuner box. Reinstall into the tv board! Hope this works!
Nov 29, 2009 | Toshiba 36A43 36" TV
The cable hook up on the TV broke off.
Yes...You may have to buy a new RF connector and replace. This will take some very good patience or purchase a new complete tuner. If you are not in a hurry for the tech shop. Use the rca jacks on the tv to a cable or satellite box. Just be sure when you power off you tv, that the tv is really off. A blank raster will look as if it is shut down for the time being! Good Luck!
Nov 29, 2009 | Panasonic PT-50LC14 50" Rear Projection...
The antenna/cable in threaded piece has come out of the back of the tv. How can I fix that. I tried to put it back but it won't stay. I think I need a new one.
These sets have what is known as a on board Tuner. This means that the Tuner is not replaceable without replacing the entire Board. The good news is that you can replace the Cable/RF connector as long as the shield it attached to is not broke or too bent. Most of the Cable/RF connectors used in these sets have PCB mount . You will have to remove the Signal Board and unsolder the center connection of the broken connector left on the Board. Remount the new
Connector and solder the center connection. You may need a collar nut to secure the Connector the the shield.
I hope this helps,
Skyassoc
Nov 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have model F25190SE, old 1992 tv, Chassis CTC177AC. No signal coming in from rf connector, television all snowy. Can use the rca connections, still has very fine lines in picture. I've replaced the rf...
cristal and IC to be replaced and solderings on all grounds in the tuner unit. maybe costly for a tv of that age, for the fine lines there are 2 ajustements on the back of the tv set, one is focus and the other one is sceen, that ajustement is too high , just turn the ajustement counterclockwise. the tv will become darker
Jun 30, 2009 | RCA Televison & Video
Cannot connect vcr to Lc-32AF3X aquos tv
To my knowledge, most VCR units would have a yellow, red and white connectors commonly called RCA. What is required then is a triple RCA to RCA connector as shown below. The yellow is normally connected to the video, while the red & white are for the R & L of the audio. An identical set would be on the rear of the TV unit henceforth the connection would be OUT from the VCR to the IN of the LC-32AF3X. Thereafter, the TV must be set to A/V, V1, Video or Aux.
In some instances, a single cable is used to connect some models to the TV. This is called an RF patch cord and would look something like below. This would come form the RF OUT of the VCR to the RF/CABLE/ANT IN of the TV. Pls make sure that the style/form fits your units. Additionally, the TV must be set to either Ch 3 or 4 or whatever the VCR is using as its RF output channel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Sharp Televison & Video
Rca tv
It is called and RF connector. Unless you are very skilled at removing the tuner from the SSB (small signal bd) identifying trace paths and soldering I would reccomend a qualified service provider to replace this part. Another option would be to simply replace the tuner (the rf connector is pressed into the tuner). If you provide the service # from the back of set I can provide the part #'s.
Mar 01, 2008 | RCA HD52W59 HDTV Projection Television
RCA F35317 35" TV Logo
122 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
