Wiring in a new thermostat
My t-stat went bad on my HVAC unit so I bought a new one. Problem is, the two t-stats don't have the same letters where you wire it coding what it controls. I don't know if there are "typicals" when wiring a t-stat eg red is common white is cooling transformer etc. If there is a universal way that's cool and that would help greatly. If not then I would need to know how to distinguish what each wire is ran to then I can look at the owners book to see how to wire it in. Thanks in advance for your help.
  • 288 Answers
On the usual 24v gas heat and cool system, the red is the 24v, or power from the transformer, the white is the heat, the green is the fan (the ON setting on the thermostat not the auto) and the cool is either yellow or blue. You can connect the red to rh or rc, if the new thermostat has this, just put a jumper wire between them. If your new thermostat has a c and o connections, you may have the wrong type.
Posted on Jan 16, 2008
I have a very old floor funace. Peobably around 45 years old. There's know fan, just induction gas heat chambers with a grate on top. The unit stopped working when the HVAC guy changed the Thermostat...
He needs to put the old stat back on...... The old stat is a Millvolt stat and the new Digital ones won't work. And I don't know if they make a digital for Millvolt.... The old floor furnaces used a power pile like a oversize thermocouple for the power to operate the gas valve.
Jul 22, 2011 | Montgomery Ward (223600UP) Heater
Outside condenser unit not functioning. I checked circuit breaker, not tripped. I can easily spin the fan with a pencil....
If the circuit breaker is not tripped (and you have line voltage to the unit) - and your inside blower motor is running - then your problem is with the thermostat/or the wiring from t-stat to outside unit.
Could it be you don't have the t-stat set on "cooling," or possibly not set at a low enough temperature to allow the unit to be turned on? Note: your t-stat must be set 'below' the inside temp, i.e. if the room temp is 78 degrees - you must turn the selector to below 78, i.e. 75, 74, so on.
Check your low voltage wire going to the outside unit - usually a thin brown wire which encases 2 smaller wires (usually red and yellow) that goes to the 'starter relay' inside the outside unit. Make sure a dog hasn't chewed it in - two - or someone hasn't cut it with a weed eater. If this is the case, turn the t-stat to off, and un-plug the inside unit (furnace) and splice the wires back together.
You can do this fairly easy with a pair of cutters and if the wires are 'color coded' you will know which wire(s) to splice back together. Note: this is 24V wiring but still you should make sure power is off - because 24V can zap you sometimes - AND you want the power off so you don't 'cross' the wires and short out the transformer.
There is a chance that the thermostat is bad - but it is not likely, and in any event you'd probably need a serviceperson to diagnose this.
Jun 15, 2011 | Ruud UAKB048 Air Conditioner
We are trying to install a HoneyWell programmable thermostat (model RTH6350) and the colors do not match up. We have an orange wire, blue wire and white wire without a connection. It says to wrap the O,...
T-stat wiring is commonly connected with the following color codes:
On a straight heat and cool system:
White = W on T-Stat
Yellow = Y on T-stat
Green = G on T-stat
Red = R on T-stat
On heat pump systems:
Blue = W2 on T-stat
There is no guarantee that your system is wired using this system so you will need to look in the furnace and see where the wires are connected to. You will have another set, probably 2 wires, going to your outside A/C unit. They are typically red and white but could be any color as long as they are hooked up to the same connections. I.E. blue on R at t-stat and to R on furnace would be OK, it just makes it harder to service the unit if you don't know what wire is for what.
Just check your furnace connections and connect the same wires to your t-stat no matter their colors.
Jun 14, 2011 | Honeywell Heating & Cooling
Unit doesnt shut off. Even when I turn off the power switch it still runs. When in energy saving mode it does the same thing. I have to unplug the unit to get it to shutdown completely. ????????????????
Remove the cover to the thermostat to get to the control wires. Now remove the red wire from the stat. If it shuts off, the stat is bad. If it continues to run, the 24 volt hot wire from the stat to the unit is touching the cooling or heating wire somewhere from the stat to the control section of the unit. You can also disconnect the stat wires at the unit to prove this. You will need to pull a new set of stat wires to your unit, or if you have a extra wire not used , find the bare one that is touching, and use the spare wire in its place.
A/C, & Heating Contractor
Feb 18, 2011 | Heating & Cooling
My heat wont turn off
Whan your room is up to temp or room is set at 70 and your stat is at 70 do you hear the stat click off .if not its a bad stat. you will have a little flam on your stat that should go off also
Dec 28, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
We recently bought a new house (to us). It has a Goodman heat pump and Goodman Electric backup furnace(A36-15) with a Janitrol stat. I switched the stat to emrg. Heat when the temp got below...
If you have a volt meter, check to see if you have 24 volts coming from the thermostat on the yellow wire.
If you do, and it is set on emer heat, you have a bad T-stat.
It looks like it is wired properly.
If you have no meter, you could try changing the stat, I reccomend Honeywell or white rodgers.
Let me know if you eliminate the Tstat as the problem and we can go from there.
Chances are its the stat.
Dec 06, 2008 | Heating & Cooling
Kenmore freezer quit working after power outage
simple stuff, you have a compressor a stat and power. check the receptacle to be sure you have 120 volts . then check the compressor with stat at max cold setting to see if you have 120 volts at compressor. if you do then compresssor is bad =new compressor or new unit. if no power to compressor then stat is bad= new stat. i always recomend new unit cause new stat or compressor wont fix a freon leak.... i have replaced a few compressors that died soon after due to a freon leak. good luck...
Nov 23, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
On the Goodman control panel each wire is marked (on the PCB board) Y, R, B, W, Br etc. These should also be letters next to the screws for the wires on the thermostat. match the letters/colors to both sides.
Nov 08, 2007 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
90 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
