Question about Kenmore Elite HE4 Electric Dryer
Kenmore HE4 Electric Dryer runs as soon as you plug it in, doesn't heat and display isn't lit
I just bought a used Kenmore HE4 electric dryer and as soon as you plug it in it starts running but doesn't heat or have any lights or anything at all showing up on the display. I did open up the back and found several pennys and dimes and you can also hear a coin jingling as the drum is spinning. Does anyone have any idea as to what I can check because I just can't afford a new dryer and taking 4 children to the laundry facility just isn't reasonable.
Thanks so much! CAM
  • 9 more comments
  • PrettyInPink
    PrettyInPink Jan 16, 2008
    I forgot the model number is 110.85871400 and the Serial number is M8150481. Thanks again.
  • PrettyInPink
    Is that a repair that I should consider or should I just save up for something else? I did check the power cord and everything is in check. Thanks again!
  • PrettyInPink
    I bought it from a local person who's roomate had left it behind. I paid $40 and it has the pedestal so I knew that I could at least recover my costs by selling the pedestal if nothing else. It was worth a try to see if I could get it fixed. I did open the back up and cleaned everything and checked to make sure nothing had just come loose but I haven't messed with that front panel which is where I'm sure the computer is...
  • PrettyInPink
    I guess I bought it knowing that it didn't work properly hoping that I would repair it for less than a new dryer. Don't know if that makes any sense but this past year was really hard for our family financially so I'm trying to do my best to help out. I'm sure to most it may seem like a senseless purchase...
  • PrettyInPink
    I was able to take off the rear panel after I had removed the top panel. I took it off and vacuumed out all of the loose lint and collected several more coins loose in the bottom. Mostly I was looking for any loose connections with the flashlight and any signs of it overheating such as smoke marks but it was in pretty good shape otherwise.
    Okay, I just took off the top cover again and when you're looking from the back to the front, I see a metal plate that covers the area where I can see two green circuit boards - one in the middle and one on the left - both behind the control panels respectively. I can see that there are two screws on top as well as two screws that are coming from the opposite side that will need to be removed. Is there a way to remove the front plastic panel so that I can access those screws?
    Also, I'm very curious because I've never replaced any major parts but are Kenmore and Whirlpool dryer parts interchangeable? I really appreciate you help.
  • PrettyInPink
    I'll be able to take that panel off in just a bit but just for reference - is there a way to tell by looking at it that it is the bad part?
    Btw... that was really interesting information about Kenmore and Sears because we have always bought Kenmore appliances thinking that they were superior to other products...
    Let me know how we can arrange ordering the part so we can get that in process. I don't know what your procedures are or if you have a site, etc...
    Thanks again!
  • PrettyInPink
    • This is the left side computer panel
    • This is inside of the front control panelThis is the back side of the front control panelThis is the front side of the control panelI haven't found a black l shaped panel so I wanted to show you what I'm seeing
  • PrettyInPink
    Okay, this is the inside of that control panel without that silver metal piece on it. Just want to make sure I'm looking at the correct part because appliances are not my strong point. I know how to work on my own car but for some reason appliances seem complicated... I also have a paypal acct. so let me know what ID and how much and I will send it over... I truly appreciate your help with this...
  • PrettyInPink
    Done deal. I just sent that over. I'll be waiting with excitement! :)
  • PrettyInPink
    PrettyInPink Jan 18, 2008
    I'll be keeping my eye out for it. I'll let you know as soon as I get it in. Will I need to reset anything or will it do it's own thing?
  • PrettyInPink
    PrettyInPink Jan 23, 2008
    Okay, got the part in last night and reassembled the dryer... This morning I got it down the hallway (I was working on it in the living room) and plugged it in.... WORKS!!! Thank you so much from my entire family! Your help has been such a blessing to us.
  • 447 Answers
Make sure that the cord is installed correctly make sure that the white wire is in the middle of the red and black wires. Other than that it sounds like a Main computer issue.
Posted on Jan 16, 2008
  • 7 more comments
  • joey  shearer
    joey shearer Jan 16, 2008
    Just curious... how did you purchase this dryer.....did it ever work???
  • joey  shearer
    How did you open the back up?? Nothing is axcessed through the back. The Computer is axcessed through the top. The lid comes off by removing 2 -- 1/4" screws on the back (the lid lips over the back) once screws are removed the lid can slide back then come up and off. The computer is on the left hand side (if you are standing at the front) under a black metal L shaped panel (you will need to remove screws securing panel). I am very interested in assisting your family in getting this dryer to work for you. I only hope that nooone has taken it apart and played with the wires, that would make it nearly impossible for me to figure out whats wrong via internet. Also if you are fairly certain that one day, when the previous owner had the the dryer, on its own wouldnt shut off and the display is blank --and now as soon as you plug it in it starts tumbling with no display--also the control on button doesnt respond when pressed even while its running ----the main CCU is the place to start. The part is whirlpool part number 8546219 and is $160 retail. I can offer to sell you that CCU for $100 which is my cost on the board (never offered this before but id like to help anyway I can), and probably $20 shipping, if you would like.
  • joey  shearer
    The computers that you are seeing is called the display board, and they are mounted to the back of the plastic control panel. I believe that these parts should be ok.....hopefully. The main control (ccu) is mounted under the black cover that runs front to back on the left side (standing at front). Under this panel is the computer that i believe needs replacement. Also Whirlpool does build this dryer for sears (kenmore) but sears has all the major companies build appliances for them (they dont make anything----just puts kenmore on the machine and the controls are a little different). But it would be whirlpool parts that you will recieve for your dryer even if you bought them directly from sears.
  • joey  shearer
    Yes Kenmore has a huge name reconization and they did use to be very good products because they worked very closely with whirlpool --and thats who built all the Kenmore Laundry products for 30+ years. Now they have all the brands building for them, including samsung (supposedly samsung is going to start building most of sears' products) and samsung is total junk. You cant get parts for them and their products are a joke to all in the industry. As far as looking for a problem with that board, look for a relay on the board to maybe have some burned spots, or any burned spots on the board, it definatly can look fine and be bad thought. I dont have a website and I usually dont offer part sourcing but I do have a paypal acct and would prefer that if thats ok with you. Also If it doesnt fix it feel free to send it back and i will refund the money.
  • joey  shearer
    The Left side computer is the one I will send --- I guess yours is not painted....sorry. Im hoping the control panel one is ok. For the paypal acct just go to paypal.com and click send money. My email is amasuperbike@comcast.net. Enter that and send $120 and ill ship it out.
  • joey  shearer
    Ill try and ship that out tommorow, I have a busy day of fixing these products but ill have to go to the parts store anyway so I should be able to.
  • joey  shearer
    joey shearer Jan 18, 2008
    I shipped the board out today. They said it should arrive tuesday. Let me know if it repairs it. -----Joey
  • joey  shearer
    Im hoping as soon as its installed ( you will have unlpugged it, of course) also make sure all the wires are connected proper and not touching any metal, plug it in and the motor shouldnt just come on like it does now as soon as its powered up without even touching the contol on button., and hopefully the display should come on.
  • joey  shearer
    joey shearer Jan 23, 2008
    Im very glad to hear that I could help. Tell your family they owe you, I dont think ive ever met such a intelligent, nice person on fixya. You are the only reason i took the time to do all we did.
    Thanks to you, as its people like you why Im on this website!!
How can i tell which cable red or black go where in the electronic bord 8546219 ccu
Posted on Jun 28, 2008
Kenmore dryer he4 elite dryer not heating model #95862402
using multi-meter need to check the heating element and the thermostats for continuity. you are getting a full 240 volts at the outlet right? if only 120 then u will be able to run the appliance but not the heating cycle.
Sep 25, 2014 | Kenmore Elite HE4 Electric Dryer
Not heating on kenmore elite he4 model 1108508
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 30, 2011 | Kenmore Elite HE4 Electric Dryer
Hello, our Kenmore Elite Dryer panel isn't working . I'ts getting power but the panel is not responding.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 21, 2010 | Kenmore Elite HE4 Electric Dryer
My kenmore elite he4 dryer is not heating up to dry the clothes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Kenmore Elite HE4 Electric Dryer
I have a kenmore elite he4 dryer and it is running but isnt getting hot. Need to know where the fuses are located to check them
heatman101
Sep 04, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
HAVE A MODEL KENMORE ELITE He4 ELECTRIC DRYER. IT
Check the burner tube and clean it out.
Sep 26, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer won't heat
The voltage first a unit needs 220v to heat but only 110v to run check for proper voltage at the plug first
Aug 15, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
632 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
