Question about Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b Wireless Adapter
No longer being assigned a valid IP address by routers
I've used my Intel 3945ABG wireless adapter for a year without issues. However, I've recently encountered problems and I can no longer use my wireless connection.
I'm on a Windows XP system laptop and it has always connected to the right network. However, within the new year, my IP always ends up being assigned as 192.168.0.1, which isn't right. The Intel wireless troubleshooter has several logs stating
"A potential problem with the 802.1x supplicant was detected. The current connection is broken."
Does this sound like a driver problem? A hardware issue? I don't remember changing any settings and I don't think I disabled any related services, so I don't think it's software related. Firewalls are not the problem either.
Any help would be appreciated. I haven't found anyone else with this problem.
  • 1 more comment
  • Matty_G Feb 03, 2008
    It turns out that a setting was corrupted and I was being given a static IP. I changed it to dynamically grab an IP and it started working again.
  • Anonymous Oct 03, 2008
    I am hitting the same error. What steps did you take to fix the problem?
  • Sachin Thatt Mar 08, 2009
    Is there a solution to this problem? I am facing the same problem on my Intel wireless connection.
    The wireless network connection is setup for dynamic IP. So that can be ruled out as a potential issue.
4 Suggested Answers
6ya staff
SOURCE:
sandrew
andrew pester
  • 2961 Answers
SOURCE: Intel 3945ABG 802.11a/g/b Wireless Adapter Problem
look in your routers settings and see if there is an idle time setting and set this to '0'
Posted on Feb 14, 2007
ziraffa
chris grams
  • 827 Answers
SOURCE: Vista Wireless Problem: Intel Pro/Wireless 3945ABG
Hi Pete,
You sound like you know what you're doing, so forgive me if these suggestions seem foolish or patronising..
Does your laptop have a wireless button?
When you go to Internet Options and click the Connections tab, have you checked 'Never Dial a Connection'? This is essential..
I have exactly the same ethernet card and network adaptor, but haven't had any problems, and we have 2 laptops and 2 pc's here all detecting our router okay so..
It's definitely not MAC filtering on the router, as you would still see the network in your list..
I can only suggest uninstalling the Intel Pro Wireless driver and downloading a fresh one from here.
That'll reset default settings at least..
Hope this helps
Let me know how you get on.. If I face this problem I want to know how to fix it too!
Chris (ziraffa)
Posted on Dec 27, 2008
Anonymous
  • 25 Answers
SOURCE: cannot connect wireless
My best suggestion is not to use the Intel wireless manager. Please go into the wireless manager and take off the "check mark" where it says the Intel Manager manages the wireless card.  This will disable the Intel wireless manager from managing your wireless card and give control back to Windows.
-Right-click "Recycle Bin" and choose "Explore"
-Right-click "My Network Places" and choose "Properties"
-Right-click on wireless network (should only be 1, maybe 2) and choose "View available wireless networks"
-Click on the wireless name from the list that belongs to your office Access point.
-If it needs a key, enter the key when prompted (it will ask you to enter it twice, one for each line).
-Once you complete this step, you should have wireless access once again.
-Intel will keep prompting you if you'd like for it to manager your wireless, I suggest you ignore this message from this point forward and only use the Windows wireless manager (built-into all Windows OS). :)
Posted on Jun 29, 2009
Wrt54g2 dhcp problem
You must enable the DHCP setting on wireless router if you've configured the computer's wireless adapter to obtain an IP address automatically. If not you will get the "failed to acquire an IP address" error when you try to connect to wireless network! Also don't forget to configure big enough IP range on router's DHCP setting, because the router won't be able to assign IP to 6 computers if you only configured 5 IP space on router.
May 18, 2011 | Computers & Internet
How do I set D-link DIR-615 router to issue IP
You will need to visit the D-Link and check the virtual videos to help you set up the D-link for static addresses. this is what you will need to do.
May 30, 2010 | D-Link DIR-615 Wireless Router
My Intel(R) PRO/Wireless 3945BG Network Connection , has a limited connectivity to the internet
Sometime when you switch on the computer and the wireless router (if you turn it off after using it) the computer does not get an IP address from the router in time when the computer finishes booting up. This problem may not occur all the time.
When you get the limited connectivity error, then right click on the wireless connection icon on the Task Bar and click REPAIR. This will get the wireless router to issue the wireless card an IP address.
Then you will have proper Internet connection.
Mar 09, 2010 | Intel PRO/Wireless 3945ABG Network...
When my wireless network is unsecured I can connect fine and browse the internet fine, but the moment I try to set up security I get a "limited or no connectivity" message from my wireless network. What's...
You must ensure that you have enabled the router as a DHCP server and the client PC network connection is set up to "obtain an IP address automatically". If the computer is not obtaining a valid IP address from the DHCP server (i.e. the router) you will get the limited or no connectivity error. You can easily check to see if you have a good IP address by opening a CMD prompt window and running ipconfig.exe. Generally, the WBR-1310 will have assigned an IP address like 192.168.0.xxx. If you have an IP address like 169.254.xxx.xxx you router is not assigning your computer a valid IP address. Powering down the PC and/or the router will usually fix this, but not always. There are other, more compliated, steps that can resolve the problem if the above steps do not work.
Oct 10, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Linksys USB adapter not working
Check your device setting on the adapter and make sure they are set to get IP automatically. The check the router and verify that it is set to assign address by DHCP and that you have not exceeded your capacity. Some providers may have set a limit and the new device is not getting an address because there is not a free address. Your other option would be to assign the IP manually and connect. You might also try changing the channel your router is using to communicate on. This has been an issue with channel 6 on Cisco routers and HP machines in my area.
Aug 23, 2009 | Computers & Internet
Intel Proset wireless just drops connection
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jul 02, 2009 | Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b...
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
Wireless router
My suggestion would be to first disable any encryption on the router to make your wireless network simple first to try and troubleshoot these problems. check if any MAC or IP Address filters are active on the wireless router, you can either enter the IP address of the slingbox wireless adapter or its MAC address if you HAVE enable filtering, but again, try diagnosing without filtering or encryption enabled. Also ensure your slingbox wireless adapter has its settings set to 'automatically assign IP address (enable DHCP)' so it gets its address automatically.
May 04, 2008 | D-Link Wireless
Compatibility between linksys WRT54G Router and Intel PRO/Wireless 3945ABG Network Driver
from what you say, it sounds as if you have your wired and wireless card connected at the same time. This will confuse the router as it is trying to give two different ip addresses to the one pc, which it cannot do. If you are using the wireless adapter, make sure you dissable the wired adapter as the router will continually look for the wired ip address while allocating your wireless adapter causing instability. Next ensure you have a good clear signal from router to notebook as this can obviously cause problems. Lastly ensure that the wireless cards TCP/IP properties are set to obtain ip address automatically, especially if your router is DHCP enabled to allocate ip addresses automatically.
May 17, 2007 | Linksys Wireless-G WRT54G Router
Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b Wireless Adapter Logo
1,379 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
