Question about KitchenAid KUDS24SE Built-in Dishwasher
Whirlpool Dishwasher Door Latch Broken
Door latch made loud sound when I tried to open and remove clean dishes. Door seems to be locked and I cannot get it open. Cannot retrieve Model number because its on the INSIDE of the dishwasher. Have tried everything. Any suggestions? It's an OLD Whirlpool.
  • trwmaple May 06, 2009
    door latch on Kitchenaid KUDS24SE is broken and I cannot open the door. Any way to get the door open?
aborcass
  • 2651 Answers
SOURCE: dishwasher door latch
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
Posted on Feb 22, 2008
  • 1314 Answers
send me an e mail at b4829@yahoo.com i may have something that will work on whirlpool and kitchenaide maybe westinghouse too dont know
Posted on Mar 30, 2008
SOURCE: Kitchenaid Dishwasher Latch Broken
GET A FLAT HEAD SCREWDRIVER TRY TO PUSH THE LATCH TO OPEN THE DOOR...
Posted on Nov 02, 2008
SOURCE: BROKEN LATCH MODEL GLDB958JB
PART NO LONGER MADE. WILL SEEK ALTERNATIVES.
Posted on Jul 18, 2009
SOURCE: Dishwasher door wont open. Broken handle latch?
I have the same issue, did you get an answer ? Save the plates !
regards
Andy
Posted on Mar 09, 2011
Older model (unknown) Whirlpool Dishwasher. Door latch failure. Dishes trapped inside.
You may have to break the little handle off to open it and order a new door latch mechanism. Just be careful. This is a lip latch so it wont be hard if you can get to where the latch connects. Use the internet and model to order new one.
Jan 23, 2012 | Whirlpool Dishwashers
My Whirlpool GU2455 dishwasher door stopping latching all of a sudden. I press the Start button. It just blinks and nothing starts up. Seems like the door latch lost its grip and hangs loose when you touch...
the door latch actually has usually 2 microswitches on it that connect to the timing device ie: timer or control board:: if the door is not latching properly then it will not power the control board and the blinking light is a failt code telling you that... it sounds like the door latch is broke and needs replaced... i would order a new latch very easy to replace. you remove the inner door panel of the dishwasher and then will see the door latch mechanism made of plastic of course isint everything these days.... replace it and reconnect the wires ...obviously i would suggest turning your breaker off to dishwasher prior to operating on it....a few good reputable sites to order parts from
www.sears.com
www.repairclinic.com
www.apdepot.com good luck to you
Feb 11, 2011 | Whirlpool GU2455XTS Built-in Dishwasher
Dish washer will not latch
Latch is locked, but the door is open, panel will not light up. Tried to close door after loading, wouldn't close, water started running, tried to figure out what was wrong, something in the way, etc, but nothing. Then water sprayed all over, started pushing buttons, and finally it quit, now latch is locked, but the door is open.
Jul 01, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
Feb 15, 2009 | KitchenAid KUDR25 Dishwasher
Nov 02, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
Dishwasher door will not open.tried running it another cycle and still nothing.It is a GE profile with the latch that you just push in. The latch/handle seems stiff.
The plastic latch release inside the door handle is broken. Most likely one of the pins holding it in place has broken.
First go to your local dishwasher supplier and look at a similar brand (GE Profile in my case) and see how the mechanism works. Next, get a thin pair of siccors, pull the dishwasher handle down and slid the siccors into the opening above the handel and push the tab holding the door closed up so it will release.
Once the door is open, remove the inside of the door to get to the latch. Remove the plastic latch release and order a new one.
Sep 28, 2008 | Dishwashers
Dishwasher door latch
Its very east to open. Take the top cover plate off the appliance, undoing the screws at tha back and it will reveal the latch.
regards
george
Mar 30, 2008 | Dishwashers
Dec 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light blinks
Raise the temperature of your water supply. To reset computer open door,within 3 seconds hit hi-temp scrub then energy saver then repeat this. Close door and latch, push cancell button.
Jun 10, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool ADP5966 washer tablet stiil in door
probably that spray arms are not rotating - to check, open the door when in operation and see if arms move. if not moving, usual cause is debris in spray arm jets. (arms only rotate thro water coming out of angled jets at end.) remove arms and clean for which you need patience
Apr 20, 2007 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashers Logo
769 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
