Question about RCA RC5215P DVD Player
Three Problems, Please.
Hi RCA Tech's I am a qualified Electronic Repair Tech. Repair Tv"s for 32 Yrs.Havent Attempted too many DVD's. But I bought an RCA,Above Model No.in a Yard Sale.It works somewhat, but the following #1 Power Up insert DVD disc. Display reads Play Unavailable, Because no disc is loaded.Pls. insert Disc. #2. Remove DVD disc,and insert Pre Recorded Audio CD, and it plays OK. But will not play Home rrecorded Disc's #3 Menu shows LOCKED, W/Pic of Padlock.I have a Users manuel,and it says will have to change Password. But the instructions on doing this is not clear.As it says use the Number buttons to type in Password, Since it does not show letters on these buttons. how does this work. The manuel also says it has a back door unlock feature, which I follow the instructions and I cannot get it to work. Would apprectate any tips you can offer me. Thanks. Larry Helton. VCR SERVICE REPAIR.
Dear brother Iam also a Technician like u I have also the same dvd player with me with missing IC104 in signal board under the lense mechanism,How ever the problem which u explaind in ur question I think it is problem from the lense,becouse I got so many DVD players (not mentioned player)for the explained symptoms and most of that when I change lense become good.
Dear brother I have a request to that to mail me the IC 104 number in follwing address.noushadkaruvally at yahoo.com
Posted on Feb 05, 2008
Hi. I have a small digihome tv about 4 yrs old. I can not remove a dvd, the eject button on the side of the tv does nothing. Angela
Take it ti a TV repair shop. Sounds like a DVD is stuck inside. If you are not electronic savy Take it to a repair shop. Good luck.
Jan 07, 2018 | Televison & Video
My rca hdmi do not work
Not unusual for RCA TV's to have problems. When I was in business (repair tech now retired) I would get many with bad solder joints, bad solder, which in many cases burnt parts before their time. Have a tech check it out.
Sep 07, 2012 | RCA L32WD12 32 in. LCD HDTV
My RCA 32" TV 2001 is black and white but the menu
Ours had a problem like that. The digibox and the dvd player (anything plugged in with a SCART lead) only played in black and white but the tv menu screen was in colour.
Also anything plugged in with those three little thingies, the red/yellow/white thingies, played in colour so we just bought a converter between SCART and the three thingies.
Sorry for how useless this was, I'm not great with all the technical language. Hope it helped in some way.
Dec 04, 2010 | RCA F32672SB 32" TV
My RCA D52W23 won't turn on
The set is in shut down mode due to a fault detected in power supply/vertical or horizontal deflection circuits.
The common problems with this model that will cause the symptom you describe are bad power supply capacitors, bad flyback, bad HV cap in horizontal output circuit and cold solders especially under flyback area.
These are only the most common problems and it could be any number of other faults.
If you have electronic (TV) repair experience check the items mentioned, otherwise it's best to seek a qualified RCA tech for an estimate/service call.
Reply to this post if you need more advice.
Dec 08, 2009 | RCA D52W23 52" HDTV CRT TV
I have a RCA model F32672sb chas.number CTC187cl3 that the picture has a hour glass display meaning the two sides are shrunk in.Everything else seems ok.
From your description you probably have a horizontal sweep circuit problem. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 13, 2009 | RCA F32672SB 32" TV
32" Sylvania TV/DVD won't work with my AT&T UVerse Remote
I bought a 32 inch sylvania LD320SSX TV/DVD and had trouble with a Media-Com remote. Finally got it to work using code 1864
Good Luck
Jul 22, 2009 | Sylvania LD320SSX LCD TV
Picture problems
Hello hack9, This problem is due to the possible malfunction of the convergence amplifiers, or the yoke transformers on the CRTs. Now this trouble is repairable, however it should only be attempted by a person knowing the interworkings of a TV receiver. I would suggest that you have a qualified TV Repair Technician repair this set due to the possible dangers caused by the high voltages and currents present. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
May 18, 2009 | RCA D52W19 52" Rear Projection Television
No picture with VIDEO INPUT, only AUDIO INPUT works
Hi ,disconnect the cable and leave the three RCA cables in.Switch off TV and DVD player ,then switch on tv and dvd player next .If you see the dvd picture and have sound then i think the cable box is overriding the rca channel.I normaly use a scart connection for the dvd to cable box then another scart from cable to tv.Hope this helps..
Feb 06, 2009 | Toshiba 37AV500U 37 in. LCD TV
RCA 37" with Xbox hook up.
Take in into a TV repair shop. DO NOT ATTEMPT to repair it yourself, TV tubes have a massive amount of electricity and could be fatal to a untrained person.
Sep 26, 2008 | RCA F32650 32" TV
Horizontal and Vertical Hold is malfuctioning and there is not manual adjustment
The fault is most likely in the sync amp section, or in the video detector section, or the area where the sync extraction is done. It is very common that some of the electrolytic capacitors in the mentioned areas become worn down with age.
An experienced TV service tech should be able to troubleshoot the sync areas, locate the faults, and replace the defective parts.
Jerry G.
Oct 10, 2007 | RCA 32V420T 32" TV
RCA RC5215P DVD Player Logo
130 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
