Front Loading Washer won't drain
I'm having trouble with my Frigidaire FTFB4000FS front loading washer. It is a little over a year old, and it is not draining. We checked the hose for clogs and it was clear. It appears the problem is somewhere between the washer and the hose. The problem is, we can't find where at in the washer to look for a clog.
  • 1 more comment
  • CleverPo Jan 16, 2008
    Any tips on how to remove the panel? I can't seem to find any screws or any way to remove it. Thanks.
  • CleverPo Jan 20, 2008
    Thanks so much! You're a lifesaver!!
  • Anonymous Mar 29, 2014
    Samsung front load The pump is new the hose is not clogged the pump is not getting power could it be the computer board ?
  • 447 Answers
The problem is most likely change in the drain pump and sump area (rubber boot going from tub to pump). It is axcessed by removing the lower front panel. Disconnecting and reconnecting the hoses to the pump are real tricky!!!!!!!!!
Posted on Jan 16, 2008
  • joey  shearer
    joey shearer Jan 18, 2008
    Yes there are two screws holding panel from bottom (almost under machine) Lean it back to axcess easire. I just worked on a machine like yours today and getting the hoses disconnected/reconnected from the drain pump was a real job. Also take the hose that goes from the tub to the pump loose at the tub (large clamp with phillips screw) inside this black hose/boot there is a plastic coin trap.
6ya staff
SOURCE:
Frigidaire front loading washer CRTF1240A won't turn/spin
I had the same problem, we opened up the bottom front panel and found a loose connection. Electrical connector had shaken loose.
Dec 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin
Check to see if the strainer before the pump is partially clogged.
Sep 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
Door will not unlock, cycle did not finish.
Unplug the power cord let it reset..It should unlock
May 21, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Loader Won't Drain
if your washer is digital or with elecronic control board check the the motor control board located at the bottom difiniely you have to call a tech to confirm that. other model like wd5595 and wd 8095 has the same problem and it is the motor control unit that always fails.
Mar 21, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer Stopped Spinning
My Frigidaire front loading washer is less than 2 years old and YES there is a belt, I am going to replace my 3rd belt this week.....the wheel on the back of the drum has moved enough, even after numberous times of tightening, that it has worn a HUGE hole in the back of the drum from the belts. I will NEVER buy another product from them again, due to not standing behind their product and sending a repair man to my home to fix it, then telling me that I will have to replace the drum....(ltf2940es0).
signed
DISCUSTED WITH FRIGIDAIRE!!!!
Dec 17, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Stackable Front Loader Washer
Jane, check to make sure that the drain hose has a air gap in the drain. Sometimes you will get a siphoning effect if you don't have the gap or it is pushed down to far in the drain. If this is not your problem, it's probably a timer issue...Catriver..post back
Oct 04, 2006 | Frigidaire GLGH1642DS Front Load Stacked...
Washing Machines Logo
370 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
