Question about Saeco Classico Espresso Machine
V entilate? my royal espresso maker screen tells me to ventilate I've turned the black dial but nothing happens
  • 2,042 Answers
The machine come with a little pump put water in the pump and insert the pump inthe water hole and press the water in the machine try to ventilate fill the water tank cheers
Posted on Jan 16, 2008
6ya staff
SOURCE:
Saeco Royal Machine says "ventilate", but when we
Hi
For the Royal Pro there is a button that has a drop sign(water drop) on it. You have to push the drop button to flow water from the steam wand. This should clear the ventilate but if it doesn't check my other tips for "Ventilate"
Aug 02, 2011 | Saeco Royal Professional Espresso Machine
It says 'ventilate' and nothing works. I have tried to turn it off and back on but it doesn't work.
Hi
Like the Royal Pro machine and Royal Coffee, there is a water button on the Comfort that you need to press to run water. If when you press it and nothing happens you have a stuck solenoid, probably from scale build up. See what happens when you push the button with the drop of water or it may have many drops depending.
Dec 07, 2010 | Saeco Magic Comfort Plus Espresso Machine
'Ventilate' message with functional direct water supply
Hi You need to push the button with the drop under it. That will turn the water on. The dial is just for steam.
Jan 30, 2010 | Saeco Royal Professional Espresso Machine
No water coming from Saeco Royal Professional Coffee Machine
Check the end of the steam spout using a paperclip make sure it is not blocked.
Oct 06, 2009 | Coffee Makers & Espresso Machines
Royal machine ventilate
Open the hot water valve to allow the pump to prime.
Sep 15, 2009 | Saeco Royal Digital Plus Coffee...
VENTILATE appeared on the screen. machine stoped working?
Try open for steam, it could be that there`s an airbubble inside the fluidsystem. Or maybe check the manual if ypu need to empty the system after using the steam, I know some older models has to be ventilated after the steamprocess.
Jul 07, 2009 | Saeco Royal Cappuccino Espresso Machine
When i warm machine up the word ventilate appears and nothing
Run the hot water cycle for a few seconds, that will clear the air lock.
Mar 26, 2009 | Saeco Royal Professional Espresso Machine
My coffee machine says "ventilate"
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Jan 05, 2009 | Saeco Royal Digital Plus Coffee...
Saeco Classico Espresso Machine Logo
108 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
espressofixr
Level 1 Expert
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
