Question about Orion STV2763 27" TV
Orion stv2762 and PS3
I can't get my Orion stv2762 to work with my PS3. The PS3 works with my Vizio HDTV but when I use the AV cables with the Orion, the screen is black and it's like the cables don't work. I looked at the book and it said that the tv might not support the output (or something like that). I guess I need to know what the output is? I'm confused.
5 Suggested Answers
  • 398 Answers
SOURCE: orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Posted on Jul 29, 2007
  • 74 Answers
SOURCE: orion stv2762
I serch the web and found this see if one of this is the one
a picture of the back of your tv can help may be I got it.....good luck and rate me
Posted on Jan 01, 2008
  • 520 Answers
SOURCE: I can not get my dish remote to work my orion tv , need codes
Try these codes.
908, 899, 834, 756, 754, 726, 721, 720, 694, 687, 227, 221, 220.
Posted on Mar 06, 2009
  • 26 Answers
SOURCE: Orion tv without input/output plugs
from the looks of the picture you have one audio video input port on the front of the tv. The connectors are yellow and red or yellow and white. Yellow is video and red or white are audio. Find those same connectors on the back or your dvd player, hook it up to the tv and there you go. You'll have to go to game mode or input 2 on the tv to see the dvd player.
Posted on Jul 01, 2009
Vizio E320-A0 ... no signal
It would appear your signal board was damaged so it will require replacement. . If you purchased s extended warranty on the set it may be covered under the accident provision. If not you can go to Vizios site with the model no and locate the replacement board . If your capable you can order it and change it your self or contact a local servicer to assist or replace the set which may be more economical
Mar 06, 2014 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
Do you have to have a HD cable to hook up a PS3?
There are two ways you can connect your PS3 to your VIzio. First, you can do it with HDMI cable. Here the HDMI output from PS3 goes to HDMI input of the TV. Second, you can do it with the AV multi out cable.Here the multi output from the PS goes to AV input of the TV. After doing this please select the source accordingly. Good luck.
Dec 30, 2013 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
PAL PS3 NTSC HDTV, HDMI Cables don't work, WHY?
I have the same problem. I get the "Mode Not Supported" message on my Samsung pn50b860 when I try to run the PS3 through the HDMI. Any solutions/suggestions yet?
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
Powers on but won't feed through to the tv
you either have the wrong channel
if you have a tv make sure you have it set on tv if you have an hdtv set it on hdtv.
or the AV cable is not plugged into the right colors or you dont have the VIDEO cable plugged in
also ask a friend who has a ps3 to borrow there AV cable your AV cable might not work anymore.
Dec 23, 2009 | Sony Playstation 3 (PS3) Console
HD cables not working on ps3
you can get hd picture only with hdmi cable
Jun 26, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Jul 11, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
S video
If your tv has S-video on the unit then yes you can plug it in from your S-Video out on your laptop. You will have to change the input on the tv. This will be done by hitting the TV/AV button on the remote, that is assuming this is an ORION stv2762. Otherwise it will be an Input, TV/Video, or AV button, or source . IF you have none of these then it could be as simple as pressing the Channel button down until you reach the AV channel. Make sure the laptop is on and then try changing through input's until you see the screen change to what the laptop shows. If you have more questions about this let me know.
Mar 15, 2008 | Orion STV2763 27" TV
Orion stv2762
Jan 01, 2008 | Orion STV2763 27" TV
Orion STV2763 27" TV Logo
109 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
