Temperatures (for my science project)
What are the temperatures(in celsius) that are used to wash the clothes? please help me
    An expert whose answer gotĀ voted for 100 times.
  • 112 Answers
Usually, washing machines use the water from the water heater directly. Most water heaters are set to 120 Fahrenheit which is 48.85 celsius.
Hope this helps!!
Posted on Jan 16, 2008
  • Uplate Jan 16, 2008
    Maximum setting is usually 60 Celsius. Cold would be room temperature or approximately 22.21 Celsius. Warm would be an average of the two.
Electrolux ewx14440w washer dryer will not heat water
Hello - Hot water is most often 10 degrees colder when it arrives at your machine from when it leaves your hot water heater. In general hot water is 130 degrees Fahrenheit (54.4 Celsius) or above. Warm water is between 110 and 90 degrees Fahrenheit ( 43.3-32.2 Celsius). Cold water is generally between 80 and 60 degrees Fahrenheit (26.7-15 Celsius). If cold water is below 60 degrees Fahrenheit (15 Celsius), clothes are unlikely to be cleaned very well. After confirming information and it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a defective timer, temperature sensor, or water valve.
Oct 28, 2012 | Electrolux EW1000i Front Load Washer
What type of oil grade should i use in my 2001 audi 2.8 a4 quattro..this car came with no owners manual,and its time to change..thanks
Engine oil capacity with oil filter replacement = 6.0 litres.
Oil grade for 2001 Audi A4 Quattro 2.8
1. SAE 5W-30 / 5W-40, VW 502.00 - all temperatures.
2. SAE 10W-30 / 10W-40, VW 502.00 - all temperatures.
3. SAE 5W-50, VW 501.01 - all temperatures.
4. SAE 10W-50 / 10W-60, VW 501.01 - all temperatures.
5. SAE 5W-30 / 5W-40, VW 501.01 - bellow +15 Celsius degrees.
6. SAE 10W-30 / 10W-40, VW 501.01 - bellow +15 Celsius degrees.
7. SAE 15W-40 / 15W-50, VW 501.01 - above -15 Celsius degrees.
8. SAE 20W-40 / 20W-50, VW 501.01 - above -15 Celsius degrees.
LONGLIFE engine oil:
1. SAE 5W-30, VW 504.00 - all temperatures.
2. SAE 0W-30, VW 503.00 - all temperatures.
Please do rate my response. Thanks!
Jan 26, 2011 | 2001 Audi A4
What type of engine oil does a Peugeot 306 (1.6 petrol engine) need?
Engine oil specifications for Peugeot 306 1.6 petrol engine:
1. SAE 5W-40, API SH or SG, for temperatures between -30 Celsius deg. and +40 Celsius deg.
2. SAE 10W-40, API SH or SG, for temperatures between -15 Celsius deg. and +40 Celsius deg.
3. SAE 15W-40, API SH or SG, for temperatures between -10 Celsius deg. and +40 Celsius deg.
4. SAE 15W-50, API SH or SG, for temperatures between -10 Celsius deg. and +50 Celsius deg.
5. SAE 20W-50, API SH or SG, for temperatures between -5 Celsius deg. and +50 Celsius deg.
Jan 02, 2011 | Peugeot 405 Cars & Trucks
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to and going to owners center and typing in ur model number.......
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I want to use two independent Sub procedures: One to convert a temperature from Farenheit to Celsuis, and the other to convert a temperature from Celsuis to Farenheit
Save this as a vbscript (filename.vbs) and modify the language as needed. Should be pretty self explanatory let me know if that works.
Sub ConvertTemp()
temp = InputBox("Please enter the temperature in degrees F.", 1)
MsgBox "The temperature is " & Celsius(temp) & " degrees C."
End Sub
Function Celsius(fDegrees)
Celsius = (fDegrees - 32) * 5 / 9
End Function
Function Fahrenheit(cDegrees)
Fahrenehit = (cDegrees + 32) * 9/ 5
End Function
Apr 05, 2010 | Computers & Internet
How to convert celsius temperature into fahrenheit ino c++?
Try using the simple mathematics; - C: variable for the Celsius Temperature - F: variable for the Fahrenheit Temperature
Apr 17, 2009 | Computers & Internet
I have to do simple project in c. can you give me
There's a lot of things you could do. Maybe a count controlled loop which does arithmetic until the users sends a command to exit the loop? A program which organizes numbers for smallest to largest from an input file? Using an event-controlled loop to convert celsius to farenheit? Hope that gets you started, this is all stuff I learned in my first year of computer science.
Please rate, thanks!
Mar 14, 2009 | Computers & Internet
Wash temperature scale
If you want to change the temperature indication from Celsius (C) to Farenheit (F), proceed as follows:
Turn the main switch, off and turn it on again. Press the Enter button five times, then press the P2 button five times. These ten times must be completed within fifteen seconds. Within three seconds after pressing P2 the last time, use the < > buttons to select temperature indication.
Sep 22, 2008 | Asko W640
Switch from Celsius to Fahrenheit Temperature setting
Press cancel and bake buttons simultaneously for 3-5 seconds until C appears then use up/down buttons to change to Fahrenheit. Hope this helps!
Feb 10, 2008 | Magic Chef 31000 Gas Kitchen Range
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
