Question about i-mate Pocket PC
IMate Pocket PC
A general question.
I own a iMate Pocket PC with Microsoft Pocket PC version 4.20.0 os. Do you know whether this os version will support two bonded hands free headsets at the same time? I have only ever been able to get it to recognise one device even though both devices are bonded to the phone at the same time.
  • skippy110 Feb 03, 2008
    Honey,
    I understand only one headset will be active at a time. Unfortunately, the OS doesn't appear to support operational connectivity to either bonded device pending which one is switched on at the time. It connects with only one of the two devices and ignores the other even though only one is switched on at the time.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 146 Answers
Hi there
only one headset will be activated at one time,even if it is bonded with two headsets
Posted on Feb 01, 2008
  • Manjit Singh
    Manjit Singh Feb 15, 2008
    update the os and this will work...
    here is the link for windows mobile 6....
    RUU_BA_xplode_WWE_6.00.00.exe ! Password: ph20b
    for more details ...
    login to http://xda-developers.com ;and this will solve the problem of your PDA
    All the Best.
    Was this solution helpful? Show your Appreciation by rating it:
How to connect i-mate jam phone to pc with help of usb cable
to install Microsoft Active Sync 4.5 for your Imate Jam and a USB cable, You can download the Microsoft Active Sync 4.5 latest version
Jan 24, 2011 | i-mate JAM Pocket PC
Tip
Hi, i got new Imate-jaq. I am facing problem in synchronising the imatejaq with...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Dec 28, 2007 | T-Mobile MDA
My laptop can not recognize my imate PDA2K pocket PC because i lost the CD containing drivers and utilities. can you please help me where to find the usb driver driver for my imate pocket pc. thank you...
just download ActiveSync 4.5 from Microsoft download website. this software comes with all the USB drivers you will need to connect ans sync you PDA to your PC computer.
Jul 30, 2009 | i-mate PDA2k Pocket PC
Pc suite for imate pm10a
i have no cd for imate jam plz give me drivers
Jul 14, 2009 | i-mate JAM Pocket PC
From were do i get os of my i-mate jama
hi thanks for using fixya!!!
May I ask what Imate Jama you have? anyway, you may get the Microsoft Windows Mobile 5.0 fo pocketpc here Windows Mobile 5.0 SDK for Pocket PC
If you need anything more, let me know.
Pls. don't forget to rate my solution positively! thanks!
By the way, I tried to send it to your email, but it bounced back to me.
Feb 19, 2009 | i-mate Computers & Internet
Installing WM5 on Imate JAM
hello bro, i want to know whether i can install windows mobile 5 on my imate JAM. if yes from where i can find the WM5 file...?
Aug 21, 2008 | i-mate JAM Pocket PC
Synchronise and connection problem in Imate jaq
hello! pradeep
let me tell u if u r using windows XP as an operatin system
then activesync creates some problem it is better to download activesync 4.5 which is the latest one and your problem will be solved. you can download it from net...
Dec 28, 2007 | i-mate JAQ Pocket PC
Imate PDA2k
Contact the imate customer service, they should be able to help you. Or you could look on the site for the english OS. www.clubimate.com
Jul 24, 2007 | i-mate PDA2k Pocket PC
Language settings
Sorry but I have bad news for you. If you buy one product like PDA or Notebook you buy automatically OS with license. As far as i know Microsoft do not sell Pocket PC as retail product. I can not understund why Microsoft does not sell the different language as they do for Windows XP. Therefor, a German PDA may not be flashed with another language version. Only what you can do is make some updates in the installed language. If you want to have PDA with English OS you must ask your local dealer whether it is possible to order such one.
Sep 11, 2005 | Toshiba e400 Pocket PC
i-mate Pocket PC Logo
48 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
