What to do
I have a HP pavilion a320n, and the problem I have is that I press the button to turn it on and the fans come on but the on button light doesnt and the monitor doesnt come up. I have tried a monitor i know that works and I have put in a new Power supply. what other options do i Have???
  • 1 more comment
  • bushman39 Jan 16, 2008
    How would I test the mainboard and processor???
  • bushman39 Jan 17, 2008
    How would I be able to tell if the motherboard is bad or the processor is bad??????????????
    Genius:
  • 1,226 Answers
Try remove and clean the memory and fix it back.
we know if the mainboard and processore are working because it beeps when you start the system without the memory.
In the case that if ever the u can't beef at all then try to examine the mainboard and the processor.
Posted on Jan 16, 2008
  • Anonymous Jan 16, 2008
    In the case that if ever the u can't hear beef at all then try to examine the mainboard and the processor.
  • Anonymous Jan 21, 2008
    you can test the mainboard by inserting a known good processors and boot the system without memory. board is good if the hear a long beeps.
    U can test processor by inserting it to the known good motherboard ans start the system without memory..if hear long beeps mean processor is good.
6ya staff
SOURCE:
Sm bus controller for hp pavilion a320n
chipset related driver, get it from Windows update.
Apr 04, 2014 | HP Pavilion a320n PC Desktop
I have an hp pavilion a320n desktop and once turned on it boots through the bios and then stops leaving a cursor blinking in the top left corner
Have you tried your onboard diagnostics? Stop the boot process after your machine boots through the BIOS, with F12 (I believe) You want to get to the boot menu. There you should see diagnostics. Run that.
The other possibility is a bad hard drive. You can test it with the onboard diagnostics. The easiest way to do it is to get into your BIOS and have a look at your boot devices. Your hard drive should be the first device.
Apr 17, 2012 | HP Pavilion a320n PC Desktop
My "hp pavilion a220n" won't power on. ... I was
Pull the power cord out and press the power button on the PC to drain the power for 10 seconds. Then plug the power cord back in and turn the computer on. If still does not work, then the power supply may be blown out and needs replacement.
Dec 23, 2010 | HP Pavilion a220n (DK218A#ABA) PC Desktop
On pressing power button blue light comes on for a split second then goes off and fan runs and CD drive and HD drive runs initially, pc continues to run but nothing on the screen. What might be the...
Bad Power Supply. Weak voltage power rail. Enough power to light LED lights, and spin fans, but not enough to turn the Processor on.
1) ALL of the LED lights on at once use less than 1 Watt of power
2) Each fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts. Depends on what Processor it is.
HP Pavilion a320n?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00039102&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=364171
Uses an AMD Athlon XP 2800+
(2.08GHz maximum frequency rate. {2083MHz actually}
Socket A processor socket. Socket A is also referred to as Socket 462)
Can use up to 68.3 Watts
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors#Athlon_XP_.22Barton.22_.28Model_10.2C_130_nm.29
Uses a 250 Watt power supply that is the > short ATX form factor.
Approximately 6 inches Wide, 3-1/2 inches Tall, and 4 inches Long.
You may be able to squeeze a full size ATX power supply in. Measure to see.
(6 inches Wide, 3-1/2 inches Tall, 5-1/2 inches Long {5.5 Inches)
Added specs,
http://www.premiumgeeks.com/desktop/hp/hp-pavilion-a320n-specs/
Part Replacement Instructions, (How to replace parts, and open the computer case),
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&docname=c00039102&product=364171&
Click on >
Part Replacement Instructions (7.3M)
Computer on a table, unplugged from power, computer case open.
OBSERVE Anti-Static Precautions.
Also would advise using a can, or two of compressed air for computers, and cleaning the inside of the computer out.
Use Q-tips to dislodge the heavy 'Gunk', then use air to remove it.
Plus would advise removing the Ram Memory module/s ('Sticks'), and cleaning the gold plated contact pins on the bottom.
Use a pencil eraser.
If you are Not using a solid eraser, and the eraser on the end of a pencil, refrain from letting the metal band contact the Ram memory contact pins.
Remove the eraser dust with air.
You can use a can of air, or air pressure from your mouth will be sufficient.
For further questions post in a Comment.
Regards,
joecoolvette
Nov 28, 2010 | HP Pavilion a320n PC Desktop
HP Pavilion a320n PC Desktop - won't turn on
usually the power supply is bad if no lights com on...
May 29, 2010 | HP Pavilion a320n PC Desktop
Describe your hp pavilion a320n blue light Problem
then your motherboard is dead you will either need to replace the mother board or replace the whole computer.
Apr 20, 2010 | HP Pavilion a320n PC Desktop
Computer won't boot. power supply ok. removed memory and got long beep. mobo or processor? Fans run, blue power light on for 2 seconds, then off.
have you tried known good memory? if u remove the memory and u got a long beep, definitely its not a mobo issue. the problem is the processor.
Mar 29, 2010 | HP Pavilion a320n PC Desktop
The computer will boot but there is not thing on
There was a proble with RAM or motherboard,
  • press the power button and see keyboard (num lock) light (right side of keyboard) is blinking thats means RAM problem in your system
if you are able to open the system,unplug the power cable and open the side cover of CPU,four slod in your system check how many RAM's in your system.if you are using two RAM's of 512MB and than remove the one RAM vis a virsa and plug the power cable than start the system,
  • press the power button and see keyboard (num lock) light (right side of keyboard) is not blinking thats means motherboard problem in your system
please go good shop and replace it.
Thanks,
Dec 16, 2009 | HP Pavilion a320n PC Desktop
What do I have to do to get my integrated video working again once I remove my video card I have a hp pavilion a320n
Once you remove your current Video card you may have to re-enable onboard video through your BIOS, if it was turned off in the first place. Usually it won't be turned off unless someone did it manually.
Aug 11, 2009 | HP Pavilion a320n PC Desktop
Open Questions:
Computers & Internet Logo
97 people viewed this question
Ekse
Marvin
Marvin
