Question about Actiontec (GT704WG) Router
Actiontec GT701-WG doesn't recognize a DVR on the LAN
I logged on to the Actiontec modem/router with 192.168.1.1 so I am assuming the Gateway is the same. My DVR has a static IP of 192.168.1.200 and a streaming port of 8000. When I connect my laptop to the LAN, the Actiontec modem sees it. However, when I connect my DVR, it does not see it.
I created a port forwarding rule and now I want to assign that rule to the DVR. However, Actiontec (apparently) only allows me to assign the rule to the recognized devices shown in a pull down. Am I able to create a device with a static IP Address or how do I get Actiontec to recognize my DVR?
The DHCP range used to be from 192.168.1.64 thru 192.168.1.254, so I changed the end range to .100 but the DVR still didn't show up.
I have another Actiontec modem that allows me to create my own devices with an IP Address.
Since my laptop appears and disappears (Actiontec recognized devices) when I connect it to the LAN, I did not reboot the DVR or modem.
Please advise.
Thank-you
Andrew Kidd
  • 4 more comments
  • Andrew48 Jan 16, 2008
    Backu,
    Thank-you for your willingness to help. The modem is actually a GT704-WG. My laptop is set DHCP; the DVR has a static IP. The PC and DVR are plugged directly into ports on the modem. There are also wireless PCs and they show up on the Network as seen by the modem. My goal, of course, is to be able to see (Telnet) the DVR from the Internet.
    Thank-you, Backu, for any assistance you may provide.
    Backu,
    The DMZ host screen on my GT704-WG has the same pull down selection menu. I rebooted the DVR and the modem. Perhaps, I need to update the firmware? Maybe I just need to get a new modem.
  • Andrew48 Jan 17, 2008
    The firmware rev is 3.20.3.3.5.0.9.15
    Thanks
  • Andrew48 Jan 18, 2008
    Backu,
    I want to thank-you for patience and kind support. I figured out how to port forward to my DVR using the GT704 Actiontec modem. GT704 will show all the DHCP devices but not static, even though the IP Address is of the same subnet. I configured the DVR to DHCP and it showed up as part of the Actiontec network, listed as "unknown".
    "unknown" (my DVR) showed up in the pull down menu along with the other DHCP devices.
    Then under Security/Applications/User I created a new rule for the port set in my DVR. (Port Forwarding is called a rule). Using the pull down menu of DHCP devices, I was then able to assign the rule to my DVR. Then everything worked.
    Since Actiontec assigns rules to a Host name and not to a specific IP Address, it doesn't matter if the device IP Addresses are reassigned during a reboot of the modem.
    Thanks again, Backu, for your consideration and taking the time to respond.
  • smogara Oct 12, 2008
    I seem to have the same problem.
    I have an Actiontec GT704-WG and I am trying to make my Tivo HD work with the unit. I have tried to create a port forwarding rule, but I DO NOT know the syntax.
    EXACTLY how does one go about setting up the rule? The ports that I need to open are: TCP --> 37,443,2190,4430,7287,7288,8000,8080-8089,8101,8102 & 8200. UDP --> 123 & 2190.
    All computers & Tivo's use DHCP to connect to the GT704-WG router. The Tivo DOES show up in the "Security --> Applications --> (pull down).
    For example, to open TCP port 37 I entered a user defined application rule with a rule name of "TivoTCP" and Port Start = 37, Port End = 37, and Port Map Start = 0 (which seems to change it to 37).
    Yet after adding all of the ports (TCP & UDP) and applying the rule to the Tivo connection, it will still not communicate with the Tivo servers. I must manually turn off the firewall in order for it to communicate.
    Any help would be great.
  • Ryan Trumbull
    Ryan Trumbull May 11, 2010
    2 items that I need clarified,
    1) Is your Laptop using DHCP?
    2) How is your network wired together?
    Clairification on whether you have a GT701-WG (as you have posted) or GT704-WG (forum it's posted in) would be nice, but the 2 devices seem to have the same screens as my own DSL modem.
    Scholar:
  • 42 Answers
I think the screen you may be looking at is the Application layer forwarding screen, the drop down box being populated by DHCP clients, that's why it isn't seeing the DVR. The DMZ Hosting screen doesn't have a drop down box, it only requires an IP address to be entered.
Hope this helps!
-Backu
Posted on Jan 16, 2008
  • 1 more comment
  • Ryan Trumbull
    Ryan Trumbull Jan 16, 2008
    What is your current firmware rev?
  • Ryan Trumbull
    Ryan Trumbull Jan 18, 2008
    Your very welcome Andrew, glad I could be of some help =)
    -Backu
  • Ryan Trumbull
    Ryan Trumbull Nov 21, 2008
    Smorga,
    Sad to say it, but Actiontec Modems seem to have a huge lacking when it comes to configureability of the firewall rules and multiple port forwardings. All my dealings with Actiontec have left me to believe that the firewall portion shuts down communications when a single incoming IP address attempts access to several ports. Actiontec even has a system for VPN Pass-thru, but even it got clamped. My only real suggestion on this matter would be to purchase a standalone firewall "brick", shutdown the firewall on the modem, and DMZ host the "brick" and let it manage all the traffic.
    -Backu
4 Suggested Answers
  • 13 Answers
SOURCE: actiontec gt701-wg Installation
You can use USB instead of Ethernet port but its not a common practise. Leave it empty then.
Posted on Dec 04, 2007
SOURCE: actiontec GT701-WG won't operate wirelessly
You'll probably need to turn on the wireless inside the configuration. go to 192.168.0.1 in your browser and head to advanced. From there you'll see it :)
Posted on Aug 30, 2008
  • 27 Answers
SOURCE: Use a Qwest Actiontec GT701-WG router with a different ISP?
Yes, if the other isp is also providing dsl services, but you will have to configure the device the other isp will not help you with that.
but its really not that difficult.
Posted on Feb 23, 2009
I have an Eyemax DV-9060 that I am unable to remotely view from my iPhone 6. I currently have the DVR set to a fixed local IP of 10.0.1.13, and have my router (modem/router combo unit from Comcast)...
If you are setting this up as a static IP then you need to have the router IP address input into the DVR to allow it to pass through. You also need to have a gateway set up to allow incoming and outgoing signals to the host site.
Mar 23, 2015 | Gateway Computers & Internet
Do they have any upgrades for a actiontec gt701 wg modems
here's the page, check the firmware in your router and see if it's older than these
http://www.actiontec.com/support/product_details.php?pid=71
Apr 21, 2011 | Actiontec (GT701) Modem
How can I disable my actiontect GT704WGR wireless setting? Verizon personnel has enable the wireless setting of my modem actionteck GT704WGR 2 days ago. Now I would like to disable it because I will use...
you can login to the Actiontec modem by typing the ip address of actiontec modem in the address bar of Internet explorer...
It will open the interface of actiontec modem...
In the Interface of actiontec modem you will have option for wireless...
If you look under wireless setting you will be having the wireless mode as 802.11b/g/n or just B/G/N....
Change this wireless mode to OFF...
Thats it you are done...
By default the ip address of action tec is 192.168.0.1
Dec 13, 2010 | Actiontec Electronics (GT724WGR) Retail...
Hi I want to know on how to setup the verizon Modem/Router I already have a Westell 6100G and i want to upgrade to the new one called Verizon Wireless modem/router model:GT704WG.
Are you on Consumer Verizon DSL? Fair warning if you are using Business Static- the Actiontec is a poor choice due to issues working on a static IP circuit. - I'd use a 6110 and a third party router! However, by default, the only thing you would need to do to setup the modem is go through the activation page when you plug the modem in. If you require an user name and password, it would set that up. Bar any problems, you can contact Verizon technical support since the Actiontec Gateway is fully supported.
Aug 28, 2010 | Actiontec GT704WG Wireless Router...
Trying to change from actiontec gt701 to actiontec gt701-wg. after new modem is hooked up, internet light stays red. switched by to old modem and all is fine. anyone know why internet light stayed red?
The reason why your internet light is red for the actiontec gt701-wg is because it is not yet configure. You need to access the gui of this router. enter the username and password for your internet connection. You can contact your ISP provider so they can walk you through for the steps on how to configure your new router.
The old router has green light because it was already configured by your ISP provider.
Apr 08, 2010 | Actiontec GT701WG Router (actiongt701wg)
To veiw on the web I have to be home how can I make it operate from whereever I am even out of state?? Thank you Dan Richardson
Setting up DVR to be used from remote location:
  1. Connect your DVR to your router
  2. Use menu on DVR to assign internal IP and gateway and port number.
    This Local IP must be in the same Gateway range as the Router. If you are unsure check the Router and locate the Status section, or goto the command prompt of your windows operating system and type in ipconfig.
    Look for Gateway. If the Gateway is 192.168.1.1, then you can make the DVR's IP anything from 192.168.1.2 - 192.168.1.255.
    Also you will need to use the same SubNet Mask, which is typically 255.255.255.0, and also use the same gateway.
  3. Next find out what port your DVR uses. The easiest way to it is by reading the manual of your DVR. Look for the network section of it.
    Also if it comes with network software, check out if in the connection area the software shows the port number.
    Also check the Server software/Programming (Network section of it) to see if the port is listed.
    In many cases it will be as simple as just Port 80, which is an HTTP port.
  4. Set your router to forward chosen port to internal IP address of DVR.
    To access the Router itself, use the Gateway you just located. If the gateway is 192.168.1.1, then enter that into the location edit box of your browser and then click the Enter button. A username and a password are typically required, but it depends on a router. For Linksys use "admin", "admin". By default DLink doesn't require any username or password (It is highly recommended to change the default password).
    Once you're logged into the Router, in the Applications & Gaming Section / Servers of the Router, you need to add a Server/Application. Enter the port number and select TCP only. Where it says Port 0 to 0 enter the same port number twice. Or if your DVR uses for example, ports 3550, 4550, 5550, 6550, and there is nothing else utilizing these ports in between, then you can actually just enter one line, 3550 - 6550.
    Enter the DVR/Cameras internal IP.
    Enable it.
    Quote: Originally Posted by Example If the port was 1024, and the Local IP is 192.168.1.200, then it would be:
    NAME = Anything you want
    Port = 1024 TO 1024
    TCP/UDP = TCP
    LOCAL IP = 192.168.1.200
    ENABLED = CHECKED
    OR
    Port = 3550 TO 6550
    TCP/UDP = TCP
    ENABLED = CHECKED
  5. Set up additional entries for as many ports the DVR uses, to the same local IP. Check your DVR manual and it's networking section for all additional ports required. Also check the DVR software itself.
    If your router has enough free entries, you can seperate them. Use it like DVR_HTTP for the browser port, DVR_AUDIO for the audio port, etc.
    If you are going to use VNC to a PC DVR, then you would need to set up port 5900, and perhaps call it VNC_DVR, for example.
  6. You have a static IP so you don't need to use sevices like www.dyndns.org . You just enter your static IP and your router forwards packets to your DVR.
This info is from Stream recording found on http://stream-recorder.com/forum/connect-dvr-via-internet-watch-cctv-cameras-t1996.html?s=16e8433689f2d55effb40b16d5588895&
Nov 29, 2009 | Samsung 4 Channel Dvr
Can a actiontec gateway wireless DSL router be connected to a comcast cable modem?I have an old DSL wireless router (gateway), can I use this as my wireless router with comcast cable internet, or do i need...
You could do it, but it's a bit of a pain in the ***** and probably not worth the hassle.
Actiontec DSL gateway was not designed to act as a "proper" router and therefore you won't be able to make it act like one permanently (well, unless there's a hacked firmware out there somewhere ;).
Of course, since it runs linux, you can telnet into it and manually set up the ip addresses on both wireless/wired interfaces and the necessary route between them. It will then work as a wireless access point for your comcast cable modem, but any changes will be lost every time you reboot the actiontec.
I've done it in the past with similar setup but quickly got tired of having to console the actiontec to add the ips and routes every time it crashed -and eventually got a proper wireless router.
So-it can be done, just not easily.
Have fun,
Raf
Nov 08, 2009 | Actiontec (GT701WG) Wireless Router
I have a dsl modem and an actiontec gt701-wg gateway
Yes this is a normal method to setup a wireless network.
To set-up and secure the wireless router from unauthorized access, follow these steps :-
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 31, 2009 | Actiontec (GT701) Modem
Need to change IP address for Actiontec router for verizon fios
definately you will need to change the IP address.
But you can also change the IP address of the wireless extender.
so instead of changing the IP address of the router, you can change the IP address of the extender.
For that you will need to connect the computer to the Extender.
assign a static IP to the computer 192.168.0.10 and Default gateway 192.168.0.30. that will open the set up page of the extender.
change the IP addres of the extender to 192.168.1.30.
that will help you.
For more info about networking click Here
Oct 21, 2009 | Actiontec Electronics (GT724WGR) Retail...
Actiontec (GT704WG) Router Logo
881 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
