Question about Jensen 8.5'' Overhead DVD Player Package (MVB85) Car Video Player
Chris i got a proplem puting the emergency brake wire
  • 1,586 Answers
You have to hardwire it to bypass the e-brake. Take the peach-colored wire and ground it to metal inside the dash. Put a toggle switch inline on the wire and mount it somewhere you can reach it. When you get the blue screen when starting a movie, open the switch for 3-5 seconds, then close it again to reapply the ground. Your movie will start up, and you can then drive away with it playing.
Posted on Oct 08, 2008
Emergency brake light on my 1994 Toyota Camry won't shut off even after I replaced e-brake light switch.
If you disconnect the wire(s) coming from the switch, does the light say on? If so, there may be a short to ground fro the switch to the lamp. You would need to replace or have the wire replaced.
Nov 09, 2017 | Cars & Trucks
1989 GMC SIERRA BRAKE LIGHT IN DASH STAYS ON [CHECKED FOR AIR IN BRAKE LINES-NO AIR] [BRAKE FLUID LEVEL GOOD] [BRAKE PEDAL PULLED UP] IN DASH BRAKE LIGHT STAYS ON
Check your emergency brake. Make sure it isn't partially pressed in. Try unplugging the switch to the emergency brake and see if the light goes out; if it does the switch is bad.
Jun 24, 2011 | 1989 GMC Sierra
Break light wont come off
hello
first i would check and see if the brake fluid is low if it is you should have a brake inspection probably needs front or rear brakes or both, if you fill the master cylider with fluid lighty tap on it sometimes the sensor gets stuck down and it thinks the fluid is low next i would check that the emergency brake is not applied pull the release handle and lift with your foot or if it is a hand brake make sure it is down,lastly make sure that there is no brake fluid leak they should notice that during a brake inspection
good luck
chris
Mar 11, 2011 | Saturn Ion Cars & Trucks
I dont know whats wrong with my valor 169T dvd player i can hear it but i cant get to see it in my monitor
You have to disable the emergency brake bypass. From what I remember there are two wires on the back of the radio one for the brake and one for the emergency brake. One of the wires is a blue yellow and the other one may be a light green. But you have to trigger the brake wire twice and trigger the emergency brake wire once in order for the video to play. The brake has a positive trigger and the emergency brake has a negative trigger.
Mar 10, 2011 | Alpine CVA-1003 Car Video Player
How would one bypass the emergency brake to view a dual 7 inch touch screeen while driveing
On the radio wiring harness grond the wire that is marked emergency brake sensor/light wire. Be advised that it is illegal to have a dash mounted video player active while a vehicle is in motion, reason emergency brake has to be applied in order to watch.
Dec 26, 2009 | Panasonic CQ-VD7001U 7 Inch (Diagonal)...
90 Camry emergency brake does not engage
sounds like the cables are sezed up.Nothink you can do but replace them. They might just need adjusting. Also if you have drums on the back the shoes might be worn right out causeing the hand brake to pull up to much. unless you can diagnose and repair the proplem you self best bet is to get a good garage to sort it.
Jun 01, 2009 | 1990 Toyota Camry
2000 pontiac emergency brake stuck. how do i
Are you in a Northern Climate were road salt is used during winter? The emergency brake problems I have encountered tend to be due to rust and corrosion accumulating on the wires and metal pivot points that operate the brake via the emergency handle on the center console.
Get underneath the car (chock the wheels---ALL FOUR! with bricks or large chunks of wood---be sure the car is in PARK!) and find the wire that connects to the handle of the brake---follow it to the rear brakes, and you will see a split where it goes to the L and R sides via a sliding clasp of steel that looks like a C, and has wires running over the top, and to each rear brake.
At this point, grab the wire on one side of it and PULL HARD several times, slack between pulls. Do this for each side---that should release the assembly, and the shoes from holding the drum.
After you have done this, lubricate the pivot points and the wire connection to the brake handle with TRI-FLOW (NOT WD-40)or another teflon based lubricant.
Mar 27, 2009 | 2000 Pontiac Grand Prix
Brake light stays on even when emergency brake is off
check the brake light switch at the top of the brake pedal
Mar 05, 2009 | 1998 Ford Windstar
Bypass emergency brake switch on 92 Legend w/Kenwood DNX7100
ground the green emergency brake wire just hook it into the radio ground and that will fix it
Nov 29, 2008 | Kenwood DNX7100 Car Video Player
How do i bypass the emergency brake wire on a dual xdvd700
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Jun 13, 2008 | Jensen's VM9312 Car DVD Player
Car Audio & Video Logo
64 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
