Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Power serge I have a Mitsubishi WD52825 52" DLP TV. We had a power serge the the other day and although we had the TV plugged into a power stip, the serge affected the TV. The TV was off at the time but after the serge the timer light started flashing and wont stop and the TV wont power up. We pressed reset button and tried unplugging and TV just wont go on. The TV is not working and the green light wont stop blinking. PLEASE HELP ME!!!
  • 1 more comment
  • Leahbrand Jan 20, 2008
    I tried the above and it didnt work. Do you have any idea about how much this should cost to have repaired. I dont want to put a lot of money into this TV. THank you very much!!!! Leah
  • Anonymous Mar 14, 2008
    My tv suddenly die-out. The timer LED keeps flashing but tv not even turn on. I replaced the lamp but still the same. I already did a system reset as well as press all other buttons. Nothing help... what is going with my tv, anyone know?
  • daryl112 Nov 19, 2008
    I have the same issues. If i uses the reset over and over sometimes it will stop flasing and then I am able to power it on. Has anyone resoled this issue without spending lots of money?
    Genius:
  • 1,030 Answers
Ok First question does the led continue to blink after 70 seconds after u plug it in. it is common for a cuircit board called the dm(digital module) to go bad in these units. this set has a keyboard lockout feature. Press menu for 10 seconds on front panel. if that does not release control then u more than likely have a problem with dm module. there are several bullitens about this and several things a tech can do to repair this set
Posted on Jan 16, 2008
  • Willie Howell Jan 21, 2008
    If you can get dm board which is getting hard to find the average cost to repair such is 300 to 600 dollars.
6ya staff
SOURCE:
Mitsubishi DLP 52525 contant green blinking light
This could be a problem with any of the capacitors....from the power supply to the FMT board. If you have the means to do so, I would check them all. But at the end of the day, even if you fix it, you are still going to have a MIT DLP POS. LOL! Sorry....Hope this helps, Chad
Oct 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd65737 Mitsubishi 65 in dlp tv, Does not go past blue welcome screen
Can you call up the settings menu? Check to see if the ANT-1, DVD, and other ports are properly activated. You may need to re-scan for channels and to activate the HDMI ports for your other devices. Regards.
Aug 13, 2015 | Mitsubishi WD65737 65" DLP TV
Why does my DLP 60 inch Mitsubishi TV keep turning off and flashing a red light?
Your repair tech hinted correct. Although the bad connection will likely be in the power supply, it actualy can sit everywhere the power goes. Can be anordinary plug / connector with a little oxidatin, or a dab soldering point. Or perhaps a electrolitic cap, slowely dying.
Let the tech do his job. He has the tools, education and skills to keep your beloved TV alive.
Apr 01, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
Mitsubishi WD 82737 Replaced bulb has about 10 hrs on it then one day the TV just quit working and would not display a picture.
What do the indicator lights on the tv do?
Did you try a reset or unplug the power cord of the YV then try again?
Apr 18, 2014 | Mitsubishi WD-82737 82" DLP TV
Mitsubishi DLP 60" - power
Unplug the television, let it sit for an hour an try to plug it back in. That should resolve the problem. if it still flashes green after you do this, use the "reset" button again. Let me know if that works.
Nov 23, 2010 | Televison & Video
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
309 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
